ArcGIS Pro 3.4 was released November 7th, 2024 and we’re excited to share all of your ideas that you’ll find when you update. ArcGIS Pro 3.4 includes more than 70 user ideas totaling more than 1,300 kudos.
This video covers many ideas - to see the full list of what you can expect when you update to ArcGIS Pro 3.4, continue reading below.
Top 10 Most Requested
Symbology - changing the Value should NOT update the Label
Minimize Floating Attribute Tables in ArcGIS Pro
Selection to Definition Query
Toggle visibility for individual Categories on Symbology tab
ArcGIS Pro copy symbology from layer
Incorporate the 4-color tool into ArcGIS
Scale bar fixed size
Messages in Model Builder
Allow users the ability to select the version of ArcGIS Pro software they want to update too in app, not just the latest release.
Add the ability to move multiple annotations in Pro without losing the anchor point for annotation leaders.
Content and Data Management
Export Layout to Project Folder
Allow the ArcGIS Pro Ribbon to be Resizable
Search box for “Options” ArcGIS Pro
in arcpy, add a way to detect if a feature class or table is branch versioned using Describe
Zoom to selected vertice in sketch properties list
How to display the full path of the aprx file on the title bar?
Make it Easier to Replicate the ArcGIS Pro Workflow for Publishing with arcpy
Allow users to validate topology within a defined extent via python
View exported folder when exporting
ArcGIS Pro Named User License Borrowing
Remove Addin from user instead of deleting .esriAddinx
Attribute Rules: Update only on geometry change
Reduce topology selection width when using Reshape
User-Defined Topology Color in Editing Tools
Favicons for side panel tabs in ArcGIS Pro
“Close All” and “Close Other” Panes in ArcGIS Pro
Add “Add New Database Connection” to New Menu outside project
Modify (or change) margins Arcgis Pro Report
Read Only Warning in ArcGIS Pro
Exported PDFs do not appear in Windows ‘Recent Files’
Additional automatic query option in the Manage Records pane
Attributes - Editor toolbar : focus with multiple selection
Field edit errors should detail the attribute rule name used (Error 002810)
OAuth2 option when connecting to WMTs or WMS services within ArcGIS Pro
“Create Feature” step in Task (.esritask) doesn’t return error if Attribute rules are violated.
Catalog view - rename a feature class (while previewing table)
Catalog Pane — Context menu option to export annotation FC
Catalog Pane — Load option in annotation FC context menu
Mapping and Visualization
Modify Annotation Feature Class With ArcPY
Create or Import New Legend Patch Shape
Pro: Change Data Source for XY Event Layer should present geometry options (Like ArcMap)
Add black & white option to Color Vision Simulator
ArcGIS Pro, Attribute table - Show count of highlighted features
Copy/paste layer properties — Choose individual properties
Expand ‘Field’ dropdown on labeling tab to be taller
Map Series based on Bookmarks should not change scale
Drag & Drop layers between maps frames in Layout View
Hide a table frame if no records are present on a map within a map series
When changing the source map in a layout maintain the current scale
Change of Map Frame - Set to Bookmark Instead of Zoomed to Full Extent
Allow F2 as next operation after “Group”
Use consistent hints and naming in menus for Ctrl-T to open a Table
Attributes pane > Annotation tab – when clicking into angle field, select text
Remove basemap when determining appropriate datum transformation
Update the docs: .LYRX layer files support standalone tables, not just layers
Auto Text Tool/Click-to-Label: specify the layer and label class
Setting the lower limit of graduated color symbols in Python
Add WMTS (Webp format tile) support for ArcGIS Pro
Improve ‘Add Row’ behavior of Abbreviation Dictionaries interface
Resize 'Insert Table Attribute' (dynamic text) box
Analysis and Geoprocessing
Add Trend Analysis Tool in ArcGIS Pro
Enable Undo for Python based editing tools
Add Undo option when calculating geometry
Create map package with one file geodatabase
Make Gaps and Overlaps able to be turned on/off, exportable and scriptable.
Add an ‘Ignore Error’ Option to the Append Tool
Add a rotate features method to arcpy allowing the angle and pivot coords to be specified
Make silent datum transformations explicit when importing to a feature dataset
Adjusting the ‘Add Notebook’ Button for Consistency
“Add and Open” Notebooks from Portal in ArcGIS Pro
Combo Charts in ArcGIS Pro
Add flip direction method to Polyline class
read Excel Named Ranges
Better type hinting for arcpy.env
ArcGIS Pro Dissolve Tool: provide MAJORITY option for string attributes
Allow easier typing in field properties
Update shapely version available to package manager
Tabbing through tool parameters and info tooltips
Thank you all for sharing your ideas about how to make ArcGIS Pro better for you, your work, and the work of other users. I would like to extend a special thank you to the following community members who had ideas implemented this release:
@StephenLead @PatrickMoulden @ValCannon1 @MaraKaminowitz @MichaelBishopp @BrettFrahm @TylerLarson @SterlingLoetz5 @LeoLadefian3 @JeanBissonnette @JustinRego @GabrielMarcus1 @AndrewRudin1 @MikePing @ThomasColson @AaronKoelker @JamalNUMAN @MatthewGeorge @SarahMoussadji @AmberWittner @YoannRONCIN @GJY @mj_gis @JoshuaBixby @ DavidVelhartický @Bud @wayfaringrob @GISTeam4 @CarolineLindhe @MiguelMartinezYordan @RobClark3 @MichaelSnook @LouisDECOMBE @EricBushee @NoahWasserman @OldManZ @CathyAppleton @XavierLOZUPONE @jcarlson @MattHowe @TylerGrosshuesch
We welcome the community's continued participation in helping us define ArcGIS Pro's development priorities for the future! Search, Participate, and Create in the ArcGIS Pro Idea Exchange!
To learn more about what's new in ArcGIS Pro 3.4, head over to the What's New documentation.
