Expand 'Field' dropdown on labeling tab to be taller
1361
10-26-2022 07:48 AM
Status: Implemented
wayfaringrob
Honored Contributor
Right now, whether you have 4 fields or 400 fields, the Field dropdown on the label tab only shows you 4 at a time, and you have to scroll to see the rest. Not even resizable. This is a huge PITA when you're trying to quickly identify the right field and switch your labeling - it's literally impossible; another huge drag on efficiency in Pro. You have to sit there and scroll, read, scroll, read -- or go open a pane, click into the expression, delete the expression, and use that field list, which shows you a whopping 8 fields at a time -- 10 if your ribbon is collapsed...how many clicks am I at? Just make it full-height, please. As tall as it can be.
3 Comments
WendyHarrison
KoryKramer
WendyHarrison
This is implemented in ArcGIS Pro 3.4. Go to Your Ideas in ArcGIS Pro 3.4 to see other ideas implemented this release and check out the What's New help to learn about everything that is new and improved in ArcGIS Pro 3.4.
