I am trying to create a python script to catalog all items in our geodatabases and their configuration using arcpy.Describe. Currently there is no way to determine if a feature class, table, or other item is branch versioned. The closest thing is the '.isVersioned' property for datasets (link). However, this is just a boolean value. So if a dataset is versioned there is no way to return if it's configured for traditional versioning or branch versioning.
This is becoming important for us as we transition many of our geodatabase items into a ArcGIS Enterprise web services model for editing. It would be helpful to run a scan of all geodatabase items and return a table documenting which are not versioned, which are still traditional, and which are now branch to assist with our transition.
I guess the best way to add this information to Arcpy is to add a new property named "versionType" to the dataset object(link). If the dataset is versioned it would return the value "Branch" or "Traditional". And if the dataset isn't versioned then I guess this property could have a null value or just not be present at all on the object.
