Planned support for local LLMs and ArcGIS Enterprise
For developing custom geospatial agents, we require ArcGIS Enterprise connectivity and locally hosted LLMs, such as Qwen through Ollama, to keep data and AI processing within the organization’s infrastructure. My understanding is that these capabilities are not currently supported in the beta. Are they planned for a future…
Map not displaying graphic (React)
Hiya, I'm building a map app in React/TypeScript and I'm struggling with displaying a point on the map. I had several setbacks and errors but the code is clear of errors (for now…). However, I get an error in the console: [@arcgis/core/views/support/LayerViewManager] Failed to create layerview for layer title:'no title',…
Polygon label placement for feature layers in Map Viewer: straight, curved, and along the boundar
Feature layers in Map Viewer only place polygon labels horizontal, at the centroid. That is not enough for parcels and for public-land section grids. Please add these placement options for polygon labels on a feature layer in Map Viewer, and in the ArcGIS Maps SDK for JavaScript labeler that Map Viewer uses: * Straight…
Editor Component & .layerInfos
This is to freshen up the 'solved' question, here: Editor Component and layerInfos - Esri Community And in particular, reviewing the suggested pattern at that time, **Set layerInfos on Editor component —————- Context: The issue (from Javascript through to ExpBuilder): our Services include multiple editable layers that…
Npm app with React template, calcite panels not working
Hello, I have followed the guide here https://developers.arcgis.com/javascript/latest/get-started/#create-an-app-with-npm choosing the React template, I fix some errors on the install and launch the template, which is working as expected. When I try to add calcite components, in particular when I try to follow this guide…
Explain Arcade Cache
Can someone please explain to me what is arcade cache function in javascript sdk and how to use it? I've checked the documentation and there is no further information about it (https://developers.arcgis.com/javascript/latest/references/core/arcade/#ArcadeCache).
Support Identify on Vector Tiles in JavaScript API
As far as I know, identifying Vector Tile layers is not supported in online map viewers that use the JavaScript API. I think that any query could easily be performed on the original data source that the vector tiles are based upon
SDK version 5.1. The popup does not work with GeoJSONLayer in FireFox (Gecko)
Hello, In SDK version 5.1, popups no longer appear when clicking on features in a GeoJSONLayer containing point geometries in Firefox (Gecko) I have not yet tested other geometry types, so I don't know if the issue is specific to points or affects all GeoJSONLayer features. I also haven't tested previous SDK versions. Is…
FeatureTable improvements + based on Calcite instead Vaadin
We suggest some improvements regarding the featureTable: * base it on the calcite design system as every other webComponent instead of currently using vaadin* allowing variable / automatic height * add some more slots (e.g. for actions next to the column selection to work with every selected row) + further ones may be…
Seamless authentication for standalone JS app consuming ArcGIS Enterprise WebMap with SAML
Hello, we have a standalone non-GIS JavaScript application that consumes a WebMap from ArcGIS Enterprise to provide spatial context. Our ArcGIS Enterprise deployment uses SAML for authentication, and the standalone application is also integrated with SAML-based sign-in. At present, when users access the WebMap from the…
Select All on Map Component Feature Table
The Select Features by Rectangle sample has no way to select all in the table. Could this be added as a component option? For example, the column visibility menu allows you to.
Are you ready for some Football?
Enjoy this example of a fun Digital Twin built with data processed using ArcGIS Reality and showcased with the JavaScript Maps SDK. Check out the live app or watch the video demo The app showcases two captures from drone and handheld sensors processed as Gaussian Splat and 3D Mesh layers, georeferenced into a SceneView,…
Select All on Table
https://developers.arcgis.com/javascript/latest/sample-code/highlight-features-by-geometry/ In this sample, you make your selections one at a time in the table. Can a "Select All" be implemented in the table such as it is in AGOL?
How do I replace just the ArcGIS World Geocoding Service when using arcgis-search component?
Using the core Search widget I can use a function with searchViewModel.includeDefaultSources to replace just the default ArcGIS World Geocoding Service with another geocoding instance or remove this geocoder from the Search widgets sources. E.g. search.viewModel.includeDefaultSources = function(sourcesResponse) {…
5.0 -> 5.1: New Error
As the title says, updated the test environment to 5.0 to 5.1 (…99% because we needed the popup.effectiveHeading, a whole 'nother discussion). Now we're getting a really spammy console error, seems to be tied to the LayerList createItem or similar. The error doesn't appear to cause any issues with our app (why would it:…
MapImageLayer with customParameter "spatialQuery"
Hi all, I have following problem with this query:…
Issue with some type of feature layers
We tried to load the following public service "https://services.arcgis.com/Lq3V5RFuTBC9I7kv/arcgis/rest/services/annual_count_of_tropical_nights_projections_local_authority_v2/FeatureServer/0" in the sandbox but we are getting a number of errors and the layer does not render. It works fine in arcpro. Is it something linked…
Calcite Date Picker Year Dropdown
Hi. For the calcite date picker component (calcite-input-date-picker), the year is a text input control. I'd like to request that a new property be added to the component that would make the year input display as a dropdown (best to allow text input and dropdown picker). It's not very user friendly to switch back and forth…
OAuth popup authentication failure due to reliance on window.opener in Esri callback sample
Hello JS API team, I am facing an issue where our SSO applies hardened security measures and intentionally clears `window.opener`. I am currently working on an integration with Octave (aka EAM) which provides an ArcGIS Plugin. Their client application follows the sample and documentation provided by Esri, but as a…
Allow sorting layer list items without changing draw order
I have found discussion on this topic in couple of other threads (Permanently change the order in layer list widget , Choosing my own ordering of the layer options in a LayerList... ), but I'd like to bring it up here again as a concrete idea/request: I've heard from users several times that it would be handy for them to…
[esri.renderers.UniqueValueRenderer] #getSymbol() Please use getSymbolAsync if valueExpression is used
The following content comes from a translator, please forgive any inaccuracies. Thank you very much. Title SceneLayer throws "Please use getSymbolAsync if valueExpression is used" when swapping a UniqueValueRenderer with valueExpression at runtime Environment * ArcGIS Maps SDK for JavaScript version: 4.32 * Layer…
Popup Component Title Font Size
Hi. For my app, I need control over popups such that some open and close on hover and others on click. Therefore, I have disabled default popup for the view and am creating new popup components like below. Note that I'm intentionally using the component as my understanding is that widgets will be retired soon: //Create…
Runtime Feature Layers Not Detected by fetchPopupFeatures() in 5.1
I have been trying to build an application that can work even if the Enterprise Portal goes down. Because of this limitation, layers must be added at runtime. I cannot depend on a Webmap. I have not been able to find a non-deprecated way to get a Popup, Feature, or Features Component to detect a Feature or Map Image Layer…
Select graphics and features in layers with Sketch and Editor components
You can select graphics created from sketch in addition to features from existing layers on the map natively without any custom configuration, just with <arcgis-sketch> and <arcgis-editor> components. Here is an example app using <arcgis-sketch /> and <arcgis-editor />: *…
Query in PBF Format Returns Incorrect Geometry for POINT ZM Features
Hi Team, We're seeing an issue when querying a feature layer using PBF (f=pbf) output format. The returned geometry is incorrect for a specific POINT ZM feature, while the same query using JSON (f=json) returns the correct geometry. Feature Details Feature ID: 1596769 The geometry stored in the database is: POINT ZM…
