How to identify branch versioned feature classes from SDE Business Tables?
5149
7
11-01-2023 12:52 PM
Labels (2)
AndrewRudin1
I'm looking for a way to easily detect all feature classes in an enterprise geodatabase that are configured with branch versioning.  Anyone found a straightforward way to do this in an automated fashion?
Arcpy's describe provides a way to determine if the feature class is versioned, but no way to distinguish between traditional vs branch. So that's led me to look at the SDE business tables, and I found two possible candidates.  I'm curious if anyone has had more experience with these since I can't find documentation on what each do.
BRANCH_TABLES_MODIFIED  is the first candidate. It has a BRANCH_ID column with many of the rows having a zero in this column. Then there is a REGISTRATION_ID which seems to be the same ID as on SDE.TABLE_REGISTRY.  I assume that BRANCH_ID = 0 equates to default version for each table.  So if I filter to BRANCH_ID=0 and join to TABLE_REGISTRY does that get me the comprehensive list?
MULTIBRANCH_TABLES is another candidate with a REGISTRATION_ID and a START_MOMENT date column.  I seem to get fewer tables back from this.
DavidSolari
MVP Regular Contributor
From the SQL end, any registered table that's branch versioned will have some special fields to track the branch version info. In my environment the GDB_IS_DELETE field is a solid indicator, your EGDB configuration may create different fields. I'm not a SQL wizard but if you can get the schema for every table programmatically that should do you.
MobiusSnake
The XML definitions in the GDB_ITEMS table might have something?  (I don't actually know, but it's probably worth a look.)
MarceloMarques
SQL access to enterprise geodatabase data—ArcMap | Documentation (arcgis.com)
Geodatabase system tables—ArcMap | Documentation (arcgis.com)
Example: Determine which datasets are versioned in a geodatabase—ArcMap | Documentation (arcgis.com)
SQL SERVER
SELECT *
FROM sde.GDB_ITEMS
GO
--Versioned
SELECT NAME AS "Versioned feature class", definition
FROM sde.GDB_ITEMS
WHERE Definition.exist('(/*/Versioned)[1]') = 1
AND Definition.value('(/*/Versioned)[1]', 'nvarchar(4)') = 'true'
GO
--Not Versioned
FROM sde.GDB_ITEMS
WHERE
AND Definition.value('(/*/Versioned)[1]', 'nvarchar(4)') = 'false'
GO
--Branch Versioned
FROM sde.GDB_ITEMS
WHERE
AND Definition.exist('(/*/IsBranch)[1]') = 1
AND Definition.value('(/*/IsBranch)[1]', 'nvarchar(4)') = 'true'
GO
--Traditional Versioning
FROM sde.GDB_ITEMS
WHERE
AND Definition.value('(/*/IsBranch)[1]', 'nvarchar(4)') = 'false'
GO
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
ChrisStiwinter1
A little late but may help someone, as stated in OP...
ORACLE:
select distinct(TABLE_NAME), OWNER from SDE.TABLE_REGISTRY a
inner join SDE.BRANCH_TABLES_MODIFIED b
on a.registration_id = b.registration_id
filter on branch_id,
JBeasley
I am only sharing this in case it was missed, but at ArcGIS Pro 3.4+, Describe now has properties isTraditionalVersioned and isBranchVersioned. I wish there weren't three different properties to go through to find what versioning type a dataset is, but better than digging through the RDBMS...
https://pro.arcgis.com/en/pro-app/3.4/arcpy/functions/dataset-properties.htm
MichaelAdornetto1
isBranchVersioned, and isTraditionalVersioned is only in the Dataset properties documentation but it appears to work on feature classes.
MichaelAdornetto1
retracted
