WV Legion in Mosaic Dataset
I have a World View Legion map-ready image. Metadata shows 4 bands, 8 bit, Orthorectified3. I cannot add the IMD file to a mosaic dataset using the WV Legion Raster Type. I tried all the templates but it returns the Error: 8004818c: No new mosaic dataset item was added. Any advice how can I make it work? Thanks
For any Raster product enable the use of a Snap Raster.
We deal with Aerial Lidar and for many QC procedures having the multiple rasters we produce properly aligned by using a snap raster is important. We are using argis 3.6.2 as of this posting. Our example is the LAS Point Statistics as Raster. It is run once for the elevation range and then again for the point count. These…
Working with geospatial video in ArcGIS
With drones, aircraft, vehicle-mounted cameras, 360-degree “action” cameras, and smartphones capturing more video than ever, organizations increasingly want to use video as part of their GIS. Video not only provides a visual, dynamic record of conditions, assets, and events; it captures movement, context, and change over…
Spectral Unmixing and Endmember Question
Does anyone know if there are any recent/updated tutorials (other than the ESRI ArcGIS Pro webpage for Linear Spectral Unmixing) for endmember development and using the Linear Spectral Unmixing tool in ArcGIS Pro? I wanted more clarification on how to use the tool.
This person or not?
Good afternoon. This is a snapshot from the summer of 2025. Could this be a person lying on their right side on the roof of a private house? Could they be glowing white like that?
Add support to clip and download from WMTS service in ArcGIS Pro
Add support to clip and download an area of interest from a WMTS service in ArcGIS Pro. WMS would also be good. Output would be to GeoTIFF or other common formats. For WMTS; An easy way to instruct it to grab the maximum tile cache level (lowest zoom) automatically would be great. Most imagery vendors serve as WMTS.…
add support for WMTS for Deep Learning
Add support for WMTS as an input for Deep Learning. Most imagery companies provide imagery via WMTS. Currently, a user has to download the imagery. Which is also difficult in ArcGIS, as related to my other Idea / ENH: Add support to clip and download from WMTS service in ArcGIS Pro - Esri Community Even after users…
I&RS at UC 2026- What Did you Think?
Thanks to all that joined us at UC this year, and if you are new to the community, WELCOME! Special thanks to all the Esri imagery experts and our panel guests this year: Gary Parker (National Geographic) James Pierce (Ameren Electric and Gas) and Rob Waterman (Esri Living Atlas Team). It was wonderful to get to meet so…
Mapping Particulate Matter using Landsat 8 Image
Any body please guide indices used for this purpose.
Duplicate Rasters in Derived Mosaic Dataset after Synchronize Mosaic Dataset
Hi everyone,I'm running into an issue with duplicate rasters appearing in a derived mosaic dataset, and I’m hoping to get some guidance on best practices, specifically around the Synchronize Mosaic Dataset tool settings. Environment / Setup* Enterprise GDB (SQL Server) * Orthomosaics (COG) stored in S3 * ArcGIS Pro 3.5.4 /…
Error 80048165: Camera information not found using Match-AT import
Hola, tengo un problema al trabajar con imágenes estereoscópicas en ArcGIS Pro al importar un archivo de ajuste de bloques generado en Match-AT de Inpho Trimble v12. Flujo de trabajo que sigo * Creo una File Geodatabase. * Dentro de ella creo un Mosaic Dataset. * Agrego los ráster. * En el tipo de ráster selecciono…
ArcGIS Collaboration with Paladin Drones Inc. for Public Safety (PD)
Hi All, I spoke with Tom Sweet yesterday about Paladin Drones and how ArcGIS supports Drone Programs. He encouraged me to add a post in here for thoughts and feedback. I am wondering if anyone has worked with, or is familiar with, Paladin Drone Inc. using ArcGIS to support and enhance the program. Any collaboration with…
Wayback imagery and wayback metadata do not tally, any explanation?
I'm accessing wayback imagery to update a dataset of glacial fronts on South Georgia. ArcPro and the wayback imagery offer a convenient dataset to digitise against, but ONLY if you know the date of the image. Hence I also access the equivalent wayback metadata for the same release of the imagery. Now I know and expect some…
Analyzing the Next Generation of Satellite Content (FedGIS 2026)
See the attached document for the Session Resources and Links Advanced remote sensing satellites are revolutionizing our understanding of the earth by providing enhanced perspectives. These satellites deliver new data types that are often combined with analysis-ready data (ARD), making them easier and quicker to use. This…
Image_Mgmt_Workflows Toolboxes
Is there a location where I can download a complete version of the Image_Mgmt_Workflows tools like OptimizeRasters, MDCS, etc?
ArcGIS Pro Classification drops a class
I'm trying to classify an image using the classification wizard in ArcGIS Pro 3.5.4. The imagery does not come from the Living Atlus. When I run the classification wizard it runs but when it gets the the preview classificed image it drops one of my classes. That class has 169 samples and growing. I have reached out to Tech…
XML file format for Statistics and Histogram raster function
I am trying to construct an XML file to give as input to the "Statistics and Histogram" raster function. I found that the correct formatting for the statistics was : <?xml version="1.0" encoding="utf-8"?><RasterStatistics> <Band> <min>...</min> <max>...</max> <mean>...</mean> <stddev>...</stddev> </Band> However, I am…
Downloaded lidar data (.laz) from NOAA can't be rasterized in ArcGIS
USGS Lidar Explorer hasn't been working properly for a week and won't let me download the .laz files from their site. However, it shows which 2500 sq ft grids are within my AOI and the NOAA website has the identical .laz files to download. The end goal is to have contours in .dwg for some CAD projects. Unfortunately, once…
MDCS removing $ in file
I have a completed MDCS XML file that I am looking to run. However, I have run into an issue running this script as the filepath to the imagery has a $ in the pathname. I've noticed that any of these figures in the XML file are removed during runtime. I couldn't see anything in the documentation about how the running code…
Create Spatial Asset Management Catalog - Not populating
I'm using esri's new Spatial Asset Management Toolbox to try and generate an asset catalog. Unfortunatly, it doesn't appear to be populating the table even though I get a successful completion of the tool. Has anyone come across this before? The documentation mentions that not all raster types are supported. However, I am…
Looking for Guidance in Remote Sensing for Dike Mapping
Hi, I’m a Master’s student in geosciences working on dikes in southern Jordan as part of my thesis, which focuses on classifying them to better understand the region's tectonic history. Right now, I’m manually digitizing dikes from Google Earth and Esri base maps. They sometimes can be 1 m thick, so quality matters, but…
NISAR Successfully launched!
If you are a GIS user interested in monitoring agricultural fields, understanding natural hazards, changes in ice sheets or forest and wetlands... soon you will have access to free SAR analysis ready products to use in ArcGIS. Analysis-ready datasets allow GIS users to leverage existing geoprocessing tools and raster…
Images don't follow seam lines at all scales
I added 5 images to a mosaic dataset (tif) > generated seamlines > recreated pyramids > changed mosaic method to seamline from properties. The images do not follow the seamlines at all scales. How can I make the mosaic use seamlines at all zoom levels? PS: no color balancing is applied to the MD Thanks
Error: 8004818c when adding Pleiades Neo Primary to Ortho Mapping
Hi, I am trying to add Pleiades Neo imagery to Ortho Mapping, at primary level and DIMAP format, to process it. It doesn't matter which Processing Template I use, they all return the error: "Error: 8004818c: No new mosaic dataset item was added", and nothing appears. I am running ArcGIS Pro 3.3.0. Any help is welcome!
Is is possible to make a map tile package of imagery that has some areas of the imagery masked out?
I am using ArcGIS Pro 3.4. I am wanting to create a map tile package of imagery where certain areas of the tile package would be masked out. For example, I have a Mosaic Dataset of a county. The source imagery is in tiles and the imagery in the mosaic dataset extends a bit outside of the county boundary. What I want to do…
