Your Ideas in ArcGIS Pro 3.3
8011
05-10-2024 07:38 AM
KoryKramer
Esri Community Moderator
8 5 8,011
It's that time again when we have the privilege of sharing your ideas that were implemented in the latest release of ArcGIS Pro. ArcGIS Pro 3.3 includes more than 70 user ideas totaling more than 1,600 kudos.
This video covers some of the most popular. Continue below to see the full list of what you can expect when you update to ArcGIS Pro 3.3.
Top 10 Most Requested
Georeferencing PDFs in ArcGIS Pro
Batch attachment export
Publish a standalone to Enterprise (by reference)
"Quantity by category" symbology in Pro
Geoprocessing History in Metadata
Allow Rectangle Textbox to Grow/Shrink and Vertically Justify Text
Insert | Text and/or Text Element Properties to support text wrapping
Vertical Scale Bar
Reproduce Extract Data Wizard workflow in AGP
Choose your default scripting language
Analysis and Geoprocessing
Improve Usability of arcpy.da.walk
Select by Attributes should only query for distinc...
Extend Attachments toolset to the Basic License (A...
Consistent Monospace Font for Python Window
Have ArcGIS Pro's Layer to KML behave like the Arc...
Bar Graph Charts based on Symbology Classes
Processing Extent - same as layer should honour s...
ArcGIS Pro's Select tool should respect Current Wo...
Bar Chart - Shows Nulls in X-axis and Y-axis
GP tool error text "Parameter is missing or invali...
Cross Correlation
Choose if join will be one-to-first or 1:Many
Set Processing Extent by drawing polygon in map
Content and Data Management
Parcel Editing Workflows - Copy Parallel Tool
Licensing to allow ArcView to edit/create relation...
Fix this Pro Bug: Import XML is missing schema pre...
Change location of Pro 3.2.x Project Index folder ...
Traverse Tool to Use Azimuth Types
Enable ArcGIS Pro to Print a Table
Enhancements to the Merge Parcel Points tool
Add the ability to create alignment links by drawi...
Allow the selection of earlier version of Parcel F...
ArcCatalog Show/Hide Hidden Files
Copy and Paste domain values (code, description) f...
ArcGIS Pro Parcel Fabric Traverse Tool point numbe...
automatically generate domains
Use ArcPy to Determine Underlying Database
When Align Parcels merges points, it should preser...
Traverse Closure Tolerance
Merge Boundaries and SLACA should have option to p...
Preview for Pro Reports
Clip (Edit) Input Features should be non-editable
Expose GlobalID of records layer by default
Catalog Pane — Copy text from item properties wind...
Optionally package history including errors
Copy attribute table row count
3D snapping
Snapping for XY Event Layer
Query Layer — Keyboard shortcut to SQL editing win...
Manage Record Pane Improvement Suggestion
Add keyboard shortcut for "Show in File Explorer",...
Mapping and Visualization
ArcGIS PRO Cursor Identify tolerance
Using Python to Change Layout Templates
De-selection before exporting your layout
Implement 'Create Flyby from Path' in ArcGIS Pro
Add Pause Drawing function to arcpy
Create Bookmark Toolbox
Make map grids and graticules scale dependent
Line thickness, color Frame Access with arcpy.mapp...
Create new label classes with Arcpy
Refresh table Graphic in layout via arcpy
Fitting strategies for layout text elements and le...
"Show Layer at all scales" in ArcGIS Pro
 Layer Page Definition in ArcPy
Arcpy: Enable Time on tables
Refresh MapView in Pro - ArcPy
ArcGIS Pro Visibility Range control
Find layer in Contents pane
Query Layer Properties window: Move the edit butto...
Add Refresh Map Series option to the layout contex...
Arcpy class for importing styles
Provide map surround type of Table Frame
Print in PURE black and white. Not 8 bit 2 bit.
Show class ranges using feature values
Creating new Layer from joined table with the ArcG...
ArcGIS Pro measure tool - option to turn off the s...
Measure Tool: add an option to display a single me...
Thank you all for sharing your ideas about how to make ArcGIS Pro better for you, your work, and the work of other users. I would like to extend a special thank you to the following community members who had ideas implemented this release:
@KetiKonstantinova @MarkSmith1 @AlexBrasch @BillMyers @LucasMurray2 @GraemeBrowning @ChrisMathers @HilaryCampbell @JeffreySchmidt3000 @JohnDye @RobertGraham @KacieVanasse @IlkaIllers1 @Johnvan_Smaalen @SusanHenton @JeanBissonnette @RayWeiser2 @RichardHowe @MichaelKraus @ThomasColson @KarenAnderson @MikeZummo @DavidWheelock2 @MizukiKayano2 @SeanLyons @RyanPaquette @TedCronin @GusMartinka @MErikReedAugusta @RandyCasey @MarcBate1 @SavageTrimble @RichardHughes2 @JeffThomasILM @Joel_Marshall @KristinAndersson @MPC_KineticGIS_Department @Ceesvan_Altena @RenePretorius @PhilLarkin1 @geodoozer @DuncanHornby @JakeKrall @PatrickAllen3 @NickN @AlfredBaldenweck @jyh @MarcelSt-Germain
We welcome the community's continued participation in helping us define ArcGIS Pro's development priorities for the future! Search, Participate, and Create in the ArcGIS Pro Idea Exchange
To learn more about what's new in ArcGIS Pro 3.3, head over to the What's New documentation and What's New blog
5 Comments
Contributors
About the Author
With an undergraduate degree in Biology and Environmental Studies from Kalamazoo College, I became interested in GIS when working as a land stewardship manager on the Osa Peninsula, Costa Rica. After returning from Costa Rica, I earned a graduate degree in GIS with a focus on Sustainability Management from the University of Washington. As a Product Manager for ArcGIS Pro, collaborating across multiple teams to contribute to the direction of product development, I am dedicated to listening to users and finding ways to convert that feedback into a product that continues to add customer value.
