A List of Custom Widgets
19792
22
10-24-2023 08:43 AM
JeffreyThompson2
MVP Frequent Contributor
18 22 19.8K
If you are on Developer Edition, here is a set of links to custom widgets you may find useful. Please post any other widgets you find useful in the comments.
  • ABLS - A Better Layer Switcher. Change between sets of layers, including timeline filters.
  • Add, Map and Edit Data - Import a dataset, do some field mapping and then edit the data.
  • Add/Remove By Group - Allows end users to add/remove sets of related layers as groups. The Add/Remove 2.0 Version creates the layers as an Experience Builder datasource. The 3.0 Version includes an option for end-users to make their own groups and makes it fully configurable from the Settings Panel.
  • Basemap Gallery - A Basemap Gallery with more functionality and customization options than the OOTB Widget.
  • Basemap Toggle - Imports the Basemap Toggle Component from the JavaScript API.
  • Calendar - Uses calendar format for filtering, zooming and other Actions.
  • CamViewer - Allows viewing of .m3u8 camera streams.
  • Clock - A real-time clock with multi-time zone support.
  • Cloud Widget - Allows users to save a map state and share it with other users.
  • Create Group Layers - Allows end users to create their own layer groups that can be visually toggled as groups.
  • CSV Geocoder - Converts a CSV file into GeoJSON, KML or shapefile format.
  • Custom Editor - Adds measurements in acres and improved snapping.
  • Custom Pill Filter - A copy of the built in Filter Widget with additional styling options.
  • Draw - The latest version of this Draw Widget offers a long list of features not currently offered by the ESRI Draw/Measure Widgets, including line segment measurements, multiple import/export option, local file storage, buffers, point symbol rotation, arrowheads on lines, make your own units, a list of drawn graphics and more. Older versions: the original, the facelift of the original and the 1.17 version.
  • Enhanced Coordinate - Displays coordinates, zoom, scale, tilt and rotation and links to Google Maps.
  • Enhanced Locate - Search for a location in any spatial reference and reverse geocoding.
  • Enhanced Measurement - Measure stuff in many different ways and export the results.
  • Fancy Filter - Automatically creates a set of filters for layer with a Unique Value Renderer. Two versions: one optimized for a single layer designated by Builder and the other allows for the end-user to change layers at runtime.
  • Feature Panel - Retrieves data for all features at a clicked mouse location. Can be placed in an auto-opening sidebar. (Note: has been broken since 1.13. It will take extensive modifications to work in the latest versions.)
  • FeedSimple - View data and feature layers from RSS, GeoRSS, XML and Atom feeds.
  • Grid - Put an overlay grid on your map.
  • Identify - Much like the Feature Panel widget, but with a tabbed presentation, ability to be enabled/disabled by the end-user and can be triggered by the related search widget. Identify for Experience Builder 1.14.
  • Identify By Query - A more advanced version of the Identify Widget. Primarily designed as a popup replacement. Accepts the Record Selection Change Action from OOTB Widgets. Integrated with the Custom Draw Widget. Many user and Builder options.
  • Interactive Legend - Imports the Interactive Legend Component created for the Interactive Legend Instant App
  • Layer Focus - Turns off visibility of all layers but the focused layer.
  • Layer Toggler Button - Designed to visibility on and off sets of layers with a single button.
  • Mailing Labels - Generate a set of mailing labels from selected data.
  • Map Layers - A customized version of the Map Layers Widget with smart expansion of layer groups.
  • Map Switcher - Designed for switching between Experience Builder projects and zooming to the same map extent.
  • Mapillary Explorer - Designed for viewing crowd sourced street level imagery.
  • Measurement - Since the June 2024 Online update, many users have been reporting poor performance with the built in Measurement Widget/Map Tool. Here is an alternative.
  • NearMap - Displays NearMap aerial imagery with option to compare two images in a swipe. Re-built for Experience Builder 1.19.
  • New-Radar - For viewing time enabled weather radar.
  • Parcel Drafter - Designed for making parcel polygons using traverse measurements.
  • Print Advanced - Use a Pro Layout file or Print Service to generate a print out. End users have more styling options than in the standard Print Widget.
  • Print With Overview Map - Makes a printable map layout with an zoomed out overview map.
  • Previous Extent - Back and forward buttons for your map.
  • Property Report - For accessing a wide variety of information related to a property, including related records and nearby features, using text, charts, and graphs and exporting it to a PDF.
  • QuerySimple - For building complex queries with many user facing options.
  • Radio Layers - Controls your map layers with radio buttons.
  • Rain Radar - Live weather radar.
  • Right Click Widget - Adds a context menu with many functions when right clicking on map.
  • Save Instance - Save the current state of an application to resume later or download and share.
  • Search Custom - Version of OOTB Search Widget with additional customization.
  • Sharepoint - For interacting with Sharepoint documents.
  • Show On Map Widget - Gives end users control over the Show On Map highlighting and ability to save these subsets.
  • Sidebar Custom - A modified Sidebar Widget that auto-opens when Add To Table or View In Table Actions are triggered.
  • Single Layer Opacity Slider - Control the opacity of a single layer including basemap layers.
  • Slider Filter - A filter with slider a based user interface designed for value ranges.
  • Traverse - Designed for building polygons based on survey descriptions.
  • What3Words - Get the What3Words location of a mouse click.
  • What's New? - Communicates to users recent changes to an application.
  • XBUI and XBUI Search - XBUI is intended as an all-in-one user interface with Table of Contents, Bookmarks, Advanced Search and Selection options and Tables. XBUI Search is focused on the search and selection aspects of the widget. Note: these widgets are developed by a consulting firm, Engineering Mapping Solutions, contact them at [email protected] to learn more.
  • Zone Lookup - For finding what polygon an address in located in.
  • Zoom - Allows users to manually set the map extent.
22 Comments
KearaMcKay1
Having an issue with the eLocate, getting a 404 error when trying to configure in Experience Builder, any tips?
JeffreyThompson2
@KearaMcKay1 That is not a widget I have used. Please ask your question over on the widget page where you may get some help for the users of that widget. Also, be aware that that widget was developed by @RobertScheitlin__GISP who is no longer providing active support.
EggandNog
It seems the Measure Tool in AGOL Exp builder is not working well. We are submitting a ticket, but I am wondering is anyone has a stand alone measure tool web app?
JeffreyThompson2
@EggandNog A custom Measurement Widget was released by @ericsamson_tract last week. I have added it to the list above.
JoshuaClanton
Are these specific to Developer edition? Or can they be added to ArcGIS Enterprise too
Brian_McLeer
MVP Regular Contributor
@JoshuaClanton it looks like starting at 11.0 you can add custom widgets to Experience Builder on Enterprise.
Add Experience Builder Custom Widgets In ArcGIS Enterprise
JeffreyThompson2
@JoshuaClanton If you are on a 11.X version of Enterprise, you should be able to register custom widgets. You will need to use the compiled versions and ensure that the widget is not developed/compiled in a higher version of Developer Edition than your Enterprise can support. See this post for more details.
https://community.esri.com/t5/experience-builder-tips-and-tricks/registering-a-custom-widget-in-arcg...
youknowww
This really should be pinned. Started making a list on Git and @Brian_McLeer pointed me here.
Are mods able to pin this to the top of the community?
Adding your list to mine here: https://github.com/you-knowww/awesome-exb
JeffreyThompson2
@youknowww I have shared this post over to the Custom Widgets Group so it can exist in both spaces. I will pin it in the Custom Widgets Group, where it makes a little more sense, if I can figure out how.
ShareUser
Esri Community Manager
Thank you for posting and pinning! This is a VERY helpful resource.
Here is my list:
Here is what I have on my list that is missing from the pinned list:
  • Annotate
  • Layer Focus Button
  • Sharepoint Documents
  • Sketch
  • Zoom
The linked github reamde has links and descriptions.
ShareUser
Here is my list:
  • Annotate
  • Sketch
  • Zoom
Danfranco
    this loads as expected, but the actual widget just looks like this and doesnt show time:
LuciusCreamer1
Frequent Explorer
I've been using the Rain Radar widget in some of my maps. However, looking at the documentation that Rain Viewer has provided for their API, it looks like the data source will no longer be available as of January 1, 2026.
I've been looking for alternative API's, as well as trying to rework the widget to be able to use NOAA radar, or even data from the MRMS program (https://mrms.nssl.noaa.gov/qvs/product_viewer/). Does anyone have experience with the current radar widget, or any other good radar alternative widgets for experience builder? The built-in timeline widget just does not cut it for swiping through a radar timeline.
WilliamTarpai
WOW, so amazing how many important contributions are being made.  Allow me to add an opportunity to think about how to rev up contributions:
https://files.unsdsn.org/THE%20CONTRIBUTION%20OF%20LIBRARIES%20TO%20ESD.pdf
SunshineLuke90
@JeffreyThompson2 - I really appreciate all of the work that you have done to put all of these widgets together. I've been working on a few custom widgets of my own, and I wanted to share them to this group. Feel free to choose the ones that are the most interesting/useful to add to the list, but I'll leave a link to my public Github repository for custom widgets for anyone who is interested.
Of note, I was able to re-create the Rain Radar widget created by Esri Australia, using a public WMS service, implementing a custom service worker. This might be useful to those who work with weather/emergency operations, but as of right now it only works for the US (Could be adapted to use basically any time-enabled wms).
https://github.com/SunshineLuke90/widgets/tree/master
JeffreyThompson2
Thank you for your contributions, @SunshineLuke90. Please consider adding images or demo apps to your GitHub so we can better understand what your Widgets do. I know there is demand out there for a Calendar Widget like you developed.
SunshineLuke90
Great suggestions. I added some images and demo apps to the GitHub Readme. Thanks for adding them to the list, and if you know anyone who might have more use cases for the Calendar widget feel free to send them a link. Unfortunately I misconfigured the repo initially, so I had to delete and republish, but the links should be the same.
RoderickPerendy
@JeffreyThompson2 @ShareUser
I think it would be pretty sweet if we had a main awesome list repo that behaved as the source of truth. Maybe ESRI be the owner of it?  Others can fork and provide insights on validation the widets are working against certain exb versions, furthermore others can update the list with new widgets discovered. Love awesome lists just sometimes they can get fragmented when you have multiple competing lists.
SunshineLuke90
I would also be interested in a unified custom widgets Git Repo, sort of an open-source widgets repository for people to be able to add to. A huge difficulty would be to maintain it appropriately, and ensure that widgets that get added work, and continue to work. I think this list works really well as a step towards the goal of having a main list, especially because not everyone who's developing these custom widgets is putting their code on GitHub.
@JeffreyThompson2, I feel like you're the GOAT of Experience Builder custom widgets, plus you maintain this list already. Do you think that a unified repository (With suggestions/improvements made through community PRs) would work for Experience Builder? Or do you think the effort to maintain that repository would be too taxing for a handful of people to take on? I would certainly be interested in contributing and helping maintain a unified list, but it would also be my first time tackling such a large endeavor, so maybe I'm being naive.
ShareUser
@RoderickPerendy @SunshineLuke90 I don't think a shared Git Repo would be a good idea. There are many practical and security issues that would be involved with creating such a repo. Many of us work in high security organizations. Personally, I would not be willing to pull code from a public, open repo. It is way too high a risk.
RoderickPerendy
@ShareUser I totally respect that, anything opensource should always be treated as zero trust and a proper disclaimer notice could be leveraged to dissociate any legal risk, but a ESRI provided "awesome" repo is just a pointer to other repos.
ShareUser
I wrote a really long response and decided that shorter might be better.
I think that this community needs a catalyst to spur serious adoption of the development capabilities of Experience Builder and I think that a shared git repository could be that catalyst. My hope is it would also be an example of what software development best practices look like and encourage their adoption.
Contributors
About the Author
A frequently confused rock-hound that writes ugly, but usually functional code.
