Map Switcher Widget for ArcGIS Experience Builder
1336
11-13-2025 02:33 PM
Brian_McLeer
MVP Regular Contributor
3 3 1,336
Overview
https://github.com/brianmcleer/mapswitcher-widget
The Map Switcher widget provides a dropdown interface for navigating between different Experience Builder applications while preserving the current map extent and zoom level. The widget captures the URL hash fragment from the source application and appends it to the destination URL.
Note: An earlier version of this widget had hardcoded URLs in the code, which prevented it from being shared on the Esri Community. Experience Builder 1.19 introduced breaking changes that required the widget to be redeveloped. This version allows administrators to configure URLs through the widget settings panel, making it suitable for broader distribution.
Configuration Settings
The widget settings panel contains the sites configuration:
Sites Configuration:
  • Label: The display name that appears in the dropdown
  • URL: The full URL to the target Experience Builder application
Multiple sites can be added using the "Add Site" button. Sites can be removed using the "Remove" button for each entry. The widget does not require a map widget connection.
Widget Functionality
The widget displays a dropdown menu with the configured site options. The placeholder text reads "Select map to view".
Functionality:
When a user selects a destination from the dropdown:
  1. The widget captures the current URL hash fragment (everything after the # symbol)
  2. This hash contains map state parameters: center coordinates, zoom level, scale, rotation, and spatial reference
  3. The widget appends this hash to the selected destination URL
  4. The browser navigates to the new application
Features:
  • Works with any coordinate system (Web Mercator, State Plane, WGS84, etc.)
  • Preserves center point, zoom level, and rotation
  • URLs configured in settings panel
Changelog:
07/23/2026: Updated the Map Switcher widget for Experience Builder 1.21 to resolve TypeScript editor errors, including React component typing and immutable configuration imports. The widget version was also bumped and the latest release is now available on GitHub.
06/04/2026: Added package.json and package-lock.json to the widget. This widget has no third-party dependencies, so there is nothing extra to install. Setup is just the standard npm install in your client folder that you are already doing. Thanks to @SunshineLuke90  for the suggestion and for walking through the packaging approach.
3 Comments
Contributors
About the Author
GIS Administrator/Developer at City of Grand Junction, CO.
