A global community of Esri users where you can find solutions, share ideas, and collaborate.
When i copy list widget from out box to custom widgets , I am getting the error in 1.21. Could you please suggest
Parcel Drafter widget ported from Web AppBuilder to Experience Builder The WAB Parcel Drafter widget has no Experience Builder equivalent. I ported it as a custom widget for ExB Developer Edition 1.21. Posting for community testing. GitHub: https://github.com/brianmcleer/parcel-drafter-widget (source and downloadable…
layer_toggler_button is a simple custom ArcGIS Experience Builder widget that lets you control the visibility of (some) multiple map layers with a single click. In the widget settings, you can configure layers and assign each one to either Group A (turn ON) or Group B (turn OFF). When the user clicks the button, all…
My team has been devising a system to log user sign in and some specific activity beginning with deleting features. We could use webhooks to track delete and we are evaluating that as an alternative to a custom logging widget as well. The current strategy is to set up a simple nosql or other log db, a…
Overview This widget brings ArcGIS Pro style map printing into ArcGIS Experience Builder without needing a print service. You share a layout from ArcGIS Pro as a layout file (.pagx), import it once in the widget settings, and the widget rebuilds that page in the browser against your live map: map frame, title and text,…
ExB Developer Edition 1.17.0 I'm working through a bug where a set of map service layers in a Scene is filtered out of my DataSourceSelector. My "hideDs" function takes in the current DataSource JSON, the dataSourceId of the JMV and a geometry type string, then does this: const hideDataSource = (dsJson: IMDataSourceJson,…
Overview GitHub: https://github.com/brianmcleer/add-edit-etl-widget Add, Map & Edit Data is a customized widget that combines two of Esri's out of the box widgets, Add Data and Edit, and drops a field-mapping step in between them. It came out of a recurring headache I kept running into. Someone has a spreadsheet or a layer…
A custom widget for ArcGIS Experience Builder. A resident enters an address, the widget returns which polygon zone the address falls in, then renders a configurable template populated with that zone's fields. Workflow is generic: address in, polygon match out, template populated with matched zone attributes. Possible use…
Custom Experience Builder widget. Upload a CSV or Excel file of addresses, geocode them against any ArcGIS Locator, and see the matched points on a connected Map widget. Results export as GeoJSON, KML, or Shapefile. GitHub: https://github.com/brianmcleer/csv-geocoder-widget Built and tested on Experience Builder 1.19 and…
I'm working on a widget for ExB 1.17 that will select a point and a polygon feature from the map's data sources if a selection action is added to the widget. I was able to get the Extent Change message type handled pretty easily so I figured this would be fine too, but instead I get this error after the message is…
It looks like you're new here. Sign in or register to get started.
