A custom widget for ArcGIS Experience Builder. A resident enters an address, the widget returns which polygon zone the address falls in, then renders a configurable template populated with that zone's fields.
Workflow is generic: address in, polygon match out, template populated with matched zone attributes. Possible use cases include council districts, polling places, school boundaries, snow routes, code enforcement zones, leaf pickup areas, garbage day, or anything point-in-polygon.
Configurable via the settings panel or XML import/export.
Repo: https://github.com/brianmcleer/zone-lookup-widget
A couple notes:
The spatial query does an exact intersect first, then a 30m buffered retry if nothing hits. Helps with geocoders that return points slightly off the parcel.
