A List of Custom Widgets
10315
21
03-17-2025 08:47 AM
ShareUser
Esri Community Manager
4 21 10.3K
If you are on Developer Edition, here is a set of links to custom widgets you may find useful. Please post any other widgets you find useful in the comments.
  • ABLS - A Better Layer Switcher. Change between sets of layers, including timeline filters.
  • Add, Map and Edit Data - Import a dataset, do some field mapping and then edit the data.
  • Add/Remove By Group - Allows end users to add/remove sets of related layers as groups. The Add/Remove 2.0 Version creates the layers as an Experience Builder datasource. The 3.0 Version includes an option for end-users to make their own groups and makes it fully configurable from the Settings Panel.
  • Basemap Gallery - A Basemap Gallery with more functionality and customization options than the OOTB Widget.
  • Basemap Toggle - Imports the Basemap Toggle Component from the JavaScript API.
  • Calendar - Uses calendar format for filtering, zooming and other Actions.
  • CamViewer - Allows viewing of .m3u8 camera streams.
  • Clock - A real-time clock with multi-time zone support.
  • Cloud Widget - Allows users to save a map state and share it with other users.
  • Create Group Layers - Allows end users to create their own layer groups that can be visually toggled as groups.
  • CSV Geocoder - Converts a CSV file into GeoJSON, KML or shapefile format.
  • Custom Editor - Adds measurements in acres and improved snapping.
  • Custom Pill Filter - A copy of the built in Filter Widget with additional styling options.
  • Draw - The latest version of this Draw Widget offers a long list of features not currently offered by the ESRI Draw/Measure Widgets, including line segment measurements, multiple import/export option, local file storage, buffers, point symbol rotation, arrowheads on lines, make your own units, a list of drawn graphics and more. Older versions: the original, the facelift of the original and the 1.17 version.
  • Enhanced Coordinate - Displays coordinates, zoom, scale, tilt and rotation and links to Google Maps.
  • Enhanced Locate - Search for a location in any spatial reference and reverse geocoding.
  • Enhanced Measurement - Measure stuff in many different ways and export the results.
  • Fancy Filter - Automatically creates a set of filters for layer with a Unique Value Renderer. Two versions: one optimized for a single layer designated by Builder and the other allows for the end-user to change layers at runtime.
  • Feature Panel - Retrieves data for all features at a clicked mouse location. Can be placed in an auto-opening sidebar. (Note: has been broken since 1.13. It will take extensive modifications to work in the latest versions.)
  • FeedSimple - View data and feature layers from RSS, GeoRSS, XML and Atom feeds.
  • Grid - Put an overlay grid on your map.
  • Identify - Much like the Feature Panel widget, but with a tabbed presentation, ability to be enabled/disabled by the end-user and can be triggered by the related search widget. Identify for Experience Builder 1.14.
  • Identify By Query - A more advanced version of the Identify Widget. Primarily designed as a popup replacement. Accepts the Record Selection Change Action from OOTB Widgets. Integrated with the Custom Draw Widget. Many user and Builder options.
  • Interactive Legend - Imports the Interactive Legend Component created for the Interactive Legend Instant App
  • Layer Focus - Turns off visibility of all layers but the focused layer.
  • Layer Toggler Button - Designed to visibility on and off sets of layers with a single button.
  • Mailing Labels - Generate a set of mailing labels from selected data.
  • Map Layers - A customized version of the Map Layers Widget with smart expansion of layer groups.
  • Map Switcher - Designed for switching between Experience Builder projects and zooming to the same map extent.
  • Mapillary Explorer - Designed for viewing crowd sourced street level imagery.
  • Measurement - Since the June 2024 Online update, many users have been reporting poor performance with the built in Measurement Widget/Map Tool. Here is an alternative.
  • NearMap - Displays NearMap aerial imagery with option to compare two images in a swipe. Re-built for Experience Builder 1.19.
  • New-Radar - For viewing time enabled weather radar.
  • Parcel Drafter - Designed for making parcel polygons using traverse measurements.
  • Print Advanced - Use a Pro Layout file or Print Service to generate a print out. End users have more styling options than in the standard Print Widget.
  • Print With Overview Map - Makes a printable map layout with an zoomed out overview map.
  • Previous Extent - Back and forward buttons for your map.
  • Property Report - For accessing a wide variety of information related to a property, including related records and nearby features, using text, charts, and graphs and exporting it to a PDF.
  • QuerySimple - For building complex queries with many user facing options.
  • Radio Layers - Controls your map layers with radio buttons.
  • Rain Radar - Live weather radar.
  • Right Click Widget - Adds a context menu with many functions when right clicking on map.
  • Save Instance - Save the current state of an application to resume later or download and share.
  • Search Custom - Version of OOTB Search Widget with additional customization.
  • Sharepoint - For interacting with Sharepoint documents.
  • Show On Map Widget - Gives end users control over the Show On Map highlighting and ability to save these subsets.
  • Sidebar Custom - A modified Sidebar Widget that auto-opens when Add To Table or View In Table Actions are triggered.
  • Single Layer Opacity Slider - Control the opacity of a single layer including basemap layers.
  • Slider Filter - A filter with slider a based user interface designed for value ranges.
  • Traverse - Designed for building polygons based on survey descriptions.
  • What3Words - Get the What3Words location of a mouse click.
  • What's New? - Communicates to users recent changes to an application.
  • XBUI and XBUI Search - XBUI is intended as an all-in-one user interface with Table of Contents, Bookmarks, Advanced Search and Selection options and Tables. XBUI Search is focused on the search and selection aspects of the widget. Note: these widgets are developed by a consulting firm, Engineering Mapping Solutions, contact them at [email protected] to learn more.
  • Zone Lookup - For finding what polygon an address in located in.
  • Zoom - Allows users to manually set the map extent.
21 Comments
