Introduction
This is a quick blog post to show how easy it is to integrate beautiful graphs into your JavaScript application using the 4.x API. If you are new to the ArcGIS API for JavaScript, we provide an easy way to get started making web mapping applications. Head over to the ArcGIS API for JavaScript site to get started. For this sample we will be using a third party library called Chart.js. Chart.js is a simple yet flexible JavaScript charting library which makes it easy to make simple graphs for your data.
Load in the Chart.js library into your JavaScript application
In order to use Chart.js in our application we need to load it in as a module. This is because Dojo uses Asynchronous Module Definition (AMD) format to load in modules as supposed to loading in a file using a script
tag. To achieve this we can use dojoConfig
to load in our custom JS package as a module.
As you can see from the sample code above, we are going to tell dojo to load in a module from a Content Delivery Network (CDN). In this case we are using the CDN that Chart.js provides for us. You can also install the files through a package manager like npm or Bower. You can learn the different ways of installing Chart.js through their Installation documentation. To avoid any potential errors, ensure the dojoConfig
is declared before the ArcGIS for JavaScript API.
Integrating Chart.js in your JavaScript application
Once you have completed the above steps, we can now use Chart.js in our JavaScript file...
require([
"esri/Map",
"esri/views/MapView",
"esri/PopupTemplate",
"esri/layers/FeatureLayer",
"esri/widgets/Popup",
"esri/tasks/support/Query",
"https://cdnjs.cloudflare.com/ajax/libs/Chart.js/2.7.2/Chart.js",
"dojo/domReady!"
function (Map, MapView, PopupTemplate, FeatureLayer, Popup, Query, Chart)
In the require array we put in the CDN link to the library. We then name the module Chart
so that we can create a new instance of it later on in our code.
Querying data from a Feature Layer
In this example I am using a Feature Layer of California from ArcGIS online . Each time I click on a county, I want a pop up to show information about the demographics of the area. For this we can use a Query, which will allow us to get information from our Feature Layer and spatially query the layer to only show data where we clicked. Once the promise has resolved, we will call the view's PopUp
and send the data to setContentInfo
. This is a function that will create the chart for us. The setContentInfo
function will be explained more in detail on the next section. Here is the code snippet that shows this.
var query = new Query();
query.returnGeometry = true;
query.outFields = ["STATE_NAME", "WHITE", "BLACK", "ASIAN", "HAWN_PI", "OTHER", "HISPANIC"];
query.where = "1=1";
query.num = 50;
view.on("click", (e) => {
query.geometry = e.mapPoint;
featureLayer.queryFeatures(query).then((results) =>{
if(results.features[0].attributes.STATE_NAME === "California"){
view.popup.visible = true;
view.popup.open({
title: "Doughnut Graph Example",
content: setContentInfo(results.features[0].attributes)
Create a graph using Chart.js
We now get to include the Chart
module that we instantiated awhile ago. In the previous code we set the content
parameter to a function called setContentInfo
and passed in the data. In the next code snippet, we are going to create this function and use it to initialize our charts inside the pop up. To start off we are going to create a new canvas
element and give it the id
of myChart
var canvas = document.createElement('canvas');
canvas.id = "myChart";
Then we are going to set up the Data Structure
object with our own data. In this particular case we are using a doughnut graph
which would have a different Data Structure than a line graph
. For more information about the different types of charts you can use, please see the following documentation on the Chart.js website. For a doughnut graph the object would look like the following code snippet below.
var data = {
datasets:[{
data: [results.ASIAN, results.BLACK, results.HAWN_PI, results.HISPANIC,
results.OTHER, results.WHITE],
backgroundColor: ["#4286f4", "#41f4be", "#8b41f4", "#e241f4", "#f44185", "#f4cd41"]
labels: [
'Asian',
'Black',
'Hawaiian',
'Hispanic',
'Other',
'White'
You can see that in the data
array, we are setting the results that we got from our feature layer. Each result will represent one piece of the doughnut graph, the backgroundColor
is also set for each result value. Additionally, the labels
attribute is set for each item in the data
array.
Finally, our last step is to create a new Chart
object with the data
and type
properties. Then we return the Chart
object.
var myPieChart = new Chart(canvas,{
type: 'doughnut',
data: data
return canvas;
Once the object is return we should get a chart inside our pop up showing demographic information each time we click on a county. You can also create this sample using TypeScript. Here is a link to the sample, if you are wondering how it would look in TypeScript.
Tip: Here is a quick video showing how the sample works.
Conclusion
The ArcGIS API for JavaScript makes it super simple to integrate beautiful graphs from third party libraries like Chart.js. There are many more libraries that you can integrate into your JavaScript application like this that allows you to make powerful maps with additional functionality. Feel free to head over to the GitHub Gist page for the full sample.
