Data update from geojson
Good day, Does anyone have experience with updating data in Arcgis online from geojson? Because we have a problem that when updating data on the website, the update does not appear in Arcgis online, even though the option "create hosted feature layer and add it to the map" is selected Thank you
Adding geotagged photos to the ArcGIS Online map
<\/HEAD> <\/P> <\/P> Technically oriented "smartphone features" certainly include creating photos that also contain location stored in the form of GPS coordinates in exif metadata<\/A>. This feature can be set on every modern smartphone equipped with GPS and a camera.<\/P>If phones produce such photos, GIS users may ask -…
Story map of the new edition with an educational video at the end
For one of my friends, who somehow cannot decide on using story maps, I decided to prepare a simple map of the new edition, where I demonstrate the use of express map and sidecar elements. This approach is suitable for presenting locations that have multiple multimedia materials. The last multimedia element is an…
No recommendations for the dashboard proposal (overview board)
<\/HEAD>Dashboard is one of the most important web applications of the ArcGIS platform. The full name of the application is <\/SPAN>Operations Dashboard for ArcGIS<\/SPAN> and it was released on February 7, 2018. In practice, we mostly use the shortened name "dashboard", or if we want to use a Slovak expression, it can be…
Story map by a student from Hodruša-Hámre
<\/HEAD> Peter Fridrich is already a well-known personality to many people from Slovakia thanks to his hobby, which keeps him busy every day. He takes care of the local historic mining clapper - not only does he wind it manually every day, but he also repaired it. He appeared in a television report on RTVS, and there are…
Final task of boundary accuracy in object mapping
Man learns from his own mistakes. In Hodruša-Hámre, I prepared a Survey123 form for a friend from PF so that he could collect folk architecture objects in the field using a mobile application on an Android smartphone. Everything went according to plan - objects were gradually added including photos and accompanying text as…
Do you use sidecar in new story maps?
A fascinating feature in the new story maps ArcGIS Story Map is the so-called sidecar. (old motorcycles with a seat next to the rider were called sidecars in our region). Sidecar is based on the principle of a main panel for different types of media such as map, image, video and a side narrative - descriptive panel, in…
ArcGIS Story Maps available
July 3, 2019 Esri officially released ArcGIS Story Maps as a new generation of story maps. You can find basic information here: The new ArcGIS StoryMaps has arrived, marking a new era in digital storytelling This new generation of story maps, which has one universal builder, now has its own product page: Digital…
ArcGIS Online Assistent
Dakujem za informáciu, podarilo sa mi vzorku nahrat do AGOLU v pozadovanej farbe podla uvedeného postupu. Len som narazil na problem, týkajúceho sa prihlasenia do ArcGIS Online Assistent, stranka vôbec nereaguje. Zrejme tu sa da editovat vzorka, napr. výber farby. Len s tým nemozem pohnut. Ešte by som sa chcel informovať,…
Polygon fill with a color pattern in AGOLE
Good day, I need to fill one polygon with a pattern because two polygons overlap. In AGOLE, I did not find this option; there is only the option to fill with color. I created a pattern fill in ARCGIS PRO, and after loading it into AGOL, the pattern fill did appear, but with a different pattern color. Is there any way to…
ArcGIS Pro
<\/HEAD>Welcome to the discussion about ArcGIS Pro. If you need help with something, want to ask a question, or have an idea/suggestion for improvement, write to us about it.<\/SPAN><\/P><\/BODY><\/HTML>
Python in ArcGIS
<\/HEAD>In this discussion, we are happy to answer your questions regarding Python in ArcGIS.<\/P><\/BODY><\/HTML>
Problem loading layers in AGOL
Good day, I cannot load all layers into one map in ArcGIS Online (see attachment) . Every time it loads only a few layers, and each time a different combination. This problem persists even though I have checked the option "prevent accidental layer removal." I also restarted the system and still nothing. This problem has…
Vector Tile Cache
<\/HEAD>I would like to invite everyone to a discussion about Vector Tile Cache. Anyone who has any questions, ideas, or inquiries can share them here. <\/P><\/BODY><\/HTML>
First insights from using ArcGIS Story Map Beta.
It will be fascinating to follow the development of the new universal ArcGIS Story Map template (let's call it "new template"), which is intended to eventually replace the group of Esri Story Map templates, among which the most well-known and widely used in Slovakia are the Tour, Journal, and Cascade templates. At the…
Merging different geometries into one layer
Good day, I kindly ask for the publication of a detailed procedure for merging layers of different geometries into one layer using Vector tile. Thank you.
Mapy s príbehom - Story Maps
Mapy s príbehom majú za sebou veľmi úspešný príbeh. Bude zaujímavé sledovať, ako bude tento príbeh pokračovať v našom priestore na GeoNete.
Survey123
<\/HEAD>I hope that all current and future Slovak-speaking users of Survey123 welcome the possibility of this common discussion forum. <\/P><\/BODY><\/HTML>
Living Atlas of the World
Write your experiences with sharing your data to the Living Atlas of the World.
I want to become a member of the group ArcGIS Users. How should I proceed?
What steps do I need to take to be able to fully communicate in the group ArcGIS Users?
<\/HEAD>Did you know that there is a rich source of map layers available online? That in it you can search and add layers to the map and thus solve problems you couldn't handle before? <\/P> Imagine volunteers planning an educational trail. They surveyed its route in the field and display it on the map. They attach the…
GeoNet Community Guidelines
Welcome to the GeoNet pages, a community created by Esri. We are glad that you have joined us. Before you start participating, we would like to ask you to read the following information about the goals of our community, member rules, and tips on how to get started. What is GeoNet? GeoNet is a place where members of the…
Výber správneho druhu obsahu
V rámci komunity GeoNet sa využíva niekoľko rôznych druhov obsahu a je dôležité zvoliť si ten správny druh obsahu (Otázky, Diskusie, Blogy, Dokumenty, Hlasovania, atď.), aby ste dosiahli želané ciele. Nižšie uvádzame hlavné druhy obsahu, ktoré sú k dispozícii a navrhované optimálne postupy, ktoré s nimi súvisia. Tím…
Greeting
We welcome all new members of our group. In this blog, you can write something about yourself and also about the purpose for which you use ArcGIS.
