Implementing ArcGIS Blog
Other Boards in This Place
Latest Activity
(186 Posts)
AaronLopez
Updating and exporting subnetworks are two critical functions in a utility network. Understanding how these methods perform or scale represent important information to GIS administrators and developers as it can affect business requirements which could in turn impact deployment architecture. This Article discusses strategies for testing updateSubnetwork and exportSubnetwork functions in a JMeter test and approaches on how analyze the results to determine performance requirements.
The procedures and examples in this Article use the Naperville Electric dataset but the process could be applied to any Utility Network.
Table Of Contents
  • Subnetwork Scalability Analysis
    • What is Subnetwork Scalability Analysis?
    • Our Utility Network Objective and Goal
    • Why Perform Update/Export Subnetwork Analysis?
    • How to Accomplish Subnetwork Scalability Analysis?
      • List of Subnetworks
      • Apache JMeter
      • Utility Network Dataset -- Naperville Electric
  • Update Subnetwork
    • The Update Subnetwork Test Plan
    • Key Components of the Test Plan
    • A Closer Look at GenerateToken
      • The Generate Token Request
      • Capturing the Token
    • Update Subnetwork Test Plan Data File​ -- List of Subnetworks
    • If Controller Logic
    • The Update Subnetwork HTTP Request
    • Test Execution
    • Analysis -- Reporting and Evaluation
      • Aggregate Report Element (Test Debugging)
      • The Results File
      • Aggregate Report Element (Post-Test Analysis)
      • Taking the Analysis Further
  • Export Subnetwork
    • The Export Subnetwork Test Plan
    • The Export Subnetwork HTTP Request
    • Advanced JMeter
      • Getting the Size of the Export Subnetwork Output
      • Getting Individual Subnetwork Response Time from an Asynchronous Job
        • The Asynchronous Execution Style
        • Groovy to the Rescue (Again)
  • Additional Strategies
    • Time vs Resources
  • Final Thoughts
    • Things to Consider
Read more...
more
4 0 1,278
AaronLopez
Learn how to analyze existing access logs in your deployment to help quantify ArcGIS Enterprise site usage and performance. Such information is critical for developers who are building a site or GIS administrators who are currently managing one. This Article focuses on ArcGIS Utility Network services but can be applied to other GIS deployments, such as branch versioning and Parcel Fabric.
Table Of Contents
  • ArcGIS Enterprise Logs and System Log Parser
  • Performance Analysis of ArcGIS Enterprise Logs
  • Example Scenario for Log Analysis
  • Why Perform Log Analysis?
  • How to Accomplish the Analysis?
    • Log Analysis Strategies
  • Running System Log Parser
    • Graphical User Interface
    • Command-line Automation
  • The Log Report -- Understanding System Log Parser output
    • Summary Worksheet
    • Statistics By Method Worksheet
    • Request Counts By Resource Worksheet
    • Capability - Server Worksheet
  • Summary
Read more...
more
5 1 1,874
AaronLopez
For evaluating Site performance and quantifying service popularity, System Log Parser (SLP) has several report offerings to conduct ArcGIS Enterprise log analysis. When selecting Analysis Types such as Simple, WithOverviewCharts or Complete, there is an
option called "Add Statistics By User to Report" which will include an additional worksheet called Statistics By User into the generated report. The information on this worksheet includes a statistical summary
of successful Portal member requests (as reported by ArcGIS Enterprise). This can be quite helpful for GIS administrators to understanding who is asking for what.
Sometimes however, the listed User on this worksheet may show the value of "anonymous". For a Site with secured services, this might be a puzzling username to observe. This Community Articles helps explains why this can occur.
Read more...
more
7 0 4,757
AaronLopez
The purpose of this article is to discuss strategies and concepts for using a JMeter Test Plan to exercise branch versioning editing. The test takes a programmatic approach for creating and capturing the data of important key/value pairs for several of the critical requests.
While a GIS editing test can be complicated since there are many moving parts to keep track of, this Article attempts to simplify the process as much as possible.
The tested workflow utilizes the Natural Earth dataset that is published as a web feature layer with branch versioning enabled.
Table Of Contents
  • Branch Versioning
  • Why Test Branch Versioning?
  • Branch Versioning Editing Testing Challenges
  • How to Test Branch Versioning Editing?
    • The Natural Earth Dataset
    • The ArcGIS Pro Feature Cache
  • The Editing Workflow via ArcGIS Pro
  • The Branch Versioning Editing JMeter Test Plan
    • Components of the Test Plan
      • CSV Data Set Config
    • (User Test Thread) Initialization Transaction
    • Open ArcGIS Pro Project Transaction
    • Create Version and Switch Version Transaction
    • Add Point Spatially Transaction
    • Update Point Attributes Transaction
    • Polygon Transactions
    • Save Edits (to the Named Version) Transaction
    • Reconcile With Default Transaction
    • Post To Default Transaction
      • Managing the Named Versions
    • Zoom Out (to Scale 1 Million) Transaction
  • Final Thoughts
    • Running the Load Test
    • Historic Moment Testing Details
    • Operation Concurrency
Read more...
more
2 0 5,399
DannyKrouk
This article describes a process for GIS and IT to collaborate to configure F5's BIG-IP to provide access to  an ArcGIS Enterprise deployment.  The goal of the article is share some of the foundational concepts for a "basic" case.  "Basic" does not mean "simple", however.  This configuration objective involves understanding and using many advanced concepts from several different information domains.
Read more...
more
10 16 11.4K
AaronLopez
Performance with your services and map are extremely important. Better performance means higher scalability which translate to your Site supporting more users. However, there are challenges GIS Administrators face when dealing with performance. This Article discusses some common performance challenges and strategies used to overcome them.
Table of Contents
  • Performance: Challenges and Strategies
  • What is Performance?
  • Why is Performance Important?
  • What is Acceptable Performance?
  • How is Performance Measured?
    • Capturing Response Times -- Web Browser
    • Capturing Response Times -- ArcGIS Pro
  • Are Goals Required for Improving Performance?
  • Common Performance Challenges and Potential Strategies
    • Service Pool Types and Instances
      • Selecting the Appropriate Type
    • Focus the Map
      • Map Strategies
    • Software Releases
    • Resource Contention and Expansion
      • Scalability
      • Performance
      • A General Approach to Scaling
    • Observability
      • A Challenge with Common Observability Tools
  • Conclusion
Read more...
more
15 12 16.2K
DannyKrouk
GIS Enterprise Reporter now has a companion application “er_compare.exe” that allows you to compare two ArcGIS Enterprise systems.
Read more...
more
4 0 4,923
AaronLopez
Measured transaction throughput and response times are critical data of any ArcGIS Enterprise load test, but captured hardware utilization of the deployment machines provide vital information as well. Together, these test artifacts allow for the proper analysis of the capabilities and efficiencies of the Site.
Determining that an application or feature service has achieved a particular level of throughput is good, but confirming the scalability characteristics while also examining the captured processor utilization of the tested workload is even better.
This Article will discuss several ways to capture the machine hardware utilization. This resource usage is a great compliment to the results of an Apache JMeter load test of ArcGIS Enterprise and can help further the analysis. The Article will focus on the most common scenarios using free tools and utilities for Windows and Linux.
Table Of Contents
  • Capturing Hardware Utilization During an Apache JMeter Load Test
  • Capturing Strategies
    • What Information Should the Load Test Capture?
    • Sample Interval
    • The Difference Between Capturing and Monitoring
    • Test Clients (Load Generator Machines)
    • Understand Your Server Baselines
    • Common Utilization Capturing Examples
      • Using Perfmon (To Capture Utilization Outside of Load Test)
      • Using dstat (To Capture Utilization Outside of Load Test)
      • Using Apache JMeter (To Capture Utilization Directly From Load Test)
  • The SampleWorldCities Test Plan With Metric Collection Support
      • jp@gc - PerfMon Metrics Collector Extension
    • Validate the JMeter-to-ServerAgent Connectivity
  • Test Execution
  • General Methodology Guide
  • Common Utilization Collection Challenges
  • Final Thoughts
Read more...
more
0 2 7,181
AaronLopez
The System Log Parser (SLP) utility is great for being able to analyze many different "ArcGIS Enterprise" log sources to help quantify the usage of your Site. It is free and includes an easy-to-use graphical user interface (GUI) called SystemLogsGUI.exe. But, did you know it can also be run from the command line via the slp.exe that is included with the download?
Command line capable execution makes a good fit for automation through PowerShell or good old fashioned bat scripts.
The slp.exe executable includes all of the same capabilities. However, you can override many of the limits imposed by the GUI such as: the end time and start time. You can even access features that are not available from the GUI like: searching with specific UTC dates, customizing the name of the report, and enabling the application debug log (for troubleshooting).
Read more...
more
7 3 7,619
DannyKrouk
The GIS Enterprise Reporter provides a wide variety of information about the services in ArcGIS Enterprise.  This article describes the information gathered by GIS Enterprise Reporter and how to understand it.
Read more...
more
10 0 5,433
133 Subscribers
