Typically, the bulk of the time is spent at 4.1. This is where the server is working on the response.
This Community Article will explorer areas that can impact this portion of the response time.
Simply put: the faster the performance, the lower the response time.
It depends.
The criteria or requirement for classifying an item as having fast (or slow) performance can vary greatly by organization, the published services and expected operations users will be calling.
It is not uncommon to have different response time goals for ArcGIS Server functions or user application workflows (several requests grouped together to represent one operation).
Any number of seconds is fine for a requirement but keep in mind, it may take more hardware as well as more extensive tuning and strategies (this Article) to achieve aggressive goals.
Response time is the key metric for determining if performance is meeting or staying within or under a target requirement.
Common strategies for measuring are:
How response times are captured through single user interaction is a fun topic of discussion.
The easiest approach to capture response times of REST requests from a web application is with the browser's "developer tools" functionality. All major browsers offer some view of the requests, responses and times being sent and received. This duration can give an idea of how fast a request or operation (potentially multiple requests) performed. Decisions can then be made if this is acceptable or needs to be improved.While ArcGIS Pro also communicates with ArcGIS Enterprise via REST, it does not have a built-in equivalent of the developer tools. For capturing responses times, you'll need a separate HTTP debugger. There are many available, a popular choice is Fiddler.
With Fiddler installed to the same machine as ArcGIS Pro, it can be configured to intercept the traffic. Request parameters, response content and times can be similarly captured and examined.
Absolutely not. GIS Administrators can always analyze, tune and apply best practices to the system even if no official performance requirements are in place.
However, it is highly recommended to understand what performance your system is initially delivering (e.g., these are typically referred to as baseline response time numbers) before adjustments are made. This way you can determine if the applied changes are having a positive effect.
One of the most frequent areas that ArcGIS administrators encounter performance challenges with is setting the appropriate number of instances for dedicated services. But first, let's review the different types. There are 3 service types, each with their own strengths.
As a GIS Administrator it is important to be able to identify the instance type for a service.
This can be easily viewed within ArcGIS Server Manager, under Manage Services:ArcGISServer_Manager_Dedicated_Instances1.png
Choosing a dedicated service type is ideal when achieving the most performance and scalability control is desired. With this type, the administrator can:
Dedicated services are ideal for heavily requested services or services where performance is paramount.
Hosted services do not utilization ArcSOC instances and auto-scale as needed. However, the ArcGIS capabilities available to it (Hosted) are limited as it is used primarily with feature queries.
Shared services are great for accessing items that are requested less frequently. They typically have more ArcGIS capabilities available to them but not all ArcGIS functionally is available (e.g., branch versioning). A shared instance pool is the default type when publishing a service with ArcGIS Pro.
Note: It is important to reiterate that if the selected service type is set to dedicated, the (minimum and maximum) number of instances should be evaluated to ensure they are optimal. The default when publishing in ArcGIS Pro is to only use a maximum of 2 (instances). This might be too low and inadeqaute for services where performance/scalability are important.
Optimizing the map is not a new strategy but a relatively easy one to follow for getting better performance from your deployment.
When the map is focused on its primary purpose and presentation, the system does not have to do unnecessary work. Remember, the web is a multiuser platform. Making the display of the dynamic data as streamlined as possible is key to good performance (and scalability). With potentially many requests occurring at the same time, the content being shared needs to be as efficient as possible.
A particular version of ArcGIS Enterprise (and its related solutions) can have a handful of patches after its initial base release. These patches can offer performance improvements as well as functionality and security fixes.
It is highly recommended to periodically check the Esri Patches and Updates site or run the "Check for ArcGIS Enterprise Updates" tool. Then, apply the updates at the appropriate time.
There are times when best practices and strategies for performance are applied but lower response times and higher scalability are still required. Perhaps the current hardware running ArcGIS Server is simply exhausted where the processing power or memory have become the bottleneck for improving the user experience.
For such situations, you need to consider expansion and/or upgrading the hardware.To improve performance with hardware, there is typically just one option:
The system's paging configuration can also impact scalability even when ample memory resources have been added to a system. Although this is operating system software setting and not hardware, it can play a crucial part in the running of many concurrent ArcSOC instances. Be sure to set this accordingly to handle a workload with many instances or instances with a large memory footprint.
There can be situations where performance is limited and appears to be CPU bound (e.g., a bottleneck due to limited processing power). Further inspection may reveal the "culprit" to be one or more slow queries which were suboptimal to begin with or an expensive operation called too frequently (through a periodic administrative tasks). In such a case, it may be more effective to address to the "bad" queries to improve performance and scalability.
Note: These expansion strategies are for overcoming general processing and memory limitations. But, disk and network (bandwidth, latency) resources can also be bottlenecks. For some environments, these can be more complicated to expand upon requiring additional steps to upgrade.
How much should you scale up...two servers, five servers? Without details on average response times and the anticipated number of users to support, it’s difficult to provide a concise answer.
However, a simplistic, general approach would be to just try doubling the current amount (memory and/or physical processing cores) and observing the impact.
For many cases, this probably works well up to 16 CPUs. At that point, adding another machine may be more advantageous.
"Quantifying ArcGIS" is a great strategy...a personal favorite. It defines what resources were being requested and how fast were the responses to fulfill these requests. It is important for obtaining an understanding of general system performance. If system resource utilization can also be captured, the analysis can be further elevated.
windows_resource_tool.pngThere are many utilities available for periodically examining your system. Some tools may read the access logs and primarily focus on the statistical request performance made by users. Others may poll Server's statistics page and capture the CPU utilization (of ArcGIS Server or the database) for that duration of time. Which approach is best? If observability is currently not taking place then most likely, any one of them. would be a good addition. They all help provide some type of insight to the performance and health of the deployment.
Once analysis has been conducted for a deployment, reports can be typically generated that highlight which map services might be of interest due to:
For an ArcGIS Site with many services, knowing which ones are statistically slow or are consuming the most resources help focus tuning efforts. With such reports, the GIS administrator has turned data into valuable information and are now better informed at making decisions for improving the user experience. That said, examining logs and statistics is just one (important) slice of the analysis pie.
Many tools for system observability and monitoring focus the analysis on requests and responses for services. This is a good approach and definitely assists administrators with quantifying ArcGIS, but it can have a limitation. The limitation can appear with an assumption that a slow map service can be "fixed" by simply adding processing cores. More cores might improve some aspects of the situation, but it is recommended that the service be examined (or even reexamined) in more depth before more resources are obtained.
This goes back to the "Focus the Map" section, for example:
Detailed query analysis can help show the occurrence of these behaviors that might get masked with general service reporting. However, while the break down of service request parameters and the underlying queries can improve the analysis it can add complexity to the reporting itself (e.g., more time to execute, more views of what to look at, the understanding of the views). Additionally, not all observability tools perform this type of inspection.
Some recent efforts that are gaining traction are attempting to tackle this issue. They are based on a bottom up approach of analysis where the starting point is on the underlying database queries themselves through mechanism known as "query datastore". Query datastore analysis is powerful and does not impact the database performance like a trace can but it does require some knowledge of the queries themselves and their purpose. Look to this type of analysis capability in the future to help get the most from your observability tools.
There is no single item to easily adjust for boosting performance and scalability of an ArcGIS Enterprise Site. However, this Article lists some common strategies that can be applied together for improving it. It is also important to understand these are items that should be periodically revisited and acted upon. User habits change over time as does the popularity of a web application or service. Resources that were assigned to a particular service can be reevaluated or reduced to make room for the next featured item in your Site.
ArcGIS performance analysis can be fun but it also a continuous effort for maintaining the best user experience.
Attribution
Resource: File:Grayson_running_the_4x100.jpg
Description: English:Grayson running the first leg of the 4x100 at the 2010 Tigered invite
Author: Graysonbay
Created: 02:02, 29 November 2010
License: This file is licensed under the Creative Commons Attribution 3.0 Unported license
Resource: File:Kurvimeter_1_fcm.jpg
Author: Frank C. Müller, Baden-Baden
License: This file is licensed under the Creative Commons Attribution-Share Alike 4.0 International license.
Resource: File:My_Opera_Server.jpg
Description: A server used for the My Home
Author: William Viker, [email protected] (c) 2006
License: The copyright holder of this file allows anyone to use it for any purpose, provided that the copyright holder is properly attributed. Redistribution, derivative work, commercial use, and all other use is permitted.
Resource: File:Samsung-1GB-DDR2-Laptop-RAM.jpg
Description: A 1 gigabyte stick of DDR2 667 MHz (PC2-5300) laptop RAM, made by Samsung and pulled from a 2007 MacBook laptop.
Author: Evan-Amos
Created: 1 August 2018
License: Public Domain
