ArcGIS Survey123 Blog
561
151.2M
316
| Under Consideration | Idea: Add Location Profiles as a configuration parameter in Survey123The Problem: You need to apply a datum transform... by ElizabethGreaves Emerging Contributor 8 3 | 8 | 3 | |
| Under Consideration | I feel the addition of a default "Yes/No" question would be quite useful and time saving within the Survey123 web app... by NicolasCelano Emerging Contributor 8 3 | 8 | 3 | |
| Under Consideration | The jr:choice-name function currently returns an error if used in the instance_name field. The instance_name returns ... by Tim-Woodfield Regular Contributor 7 1 | 7 | 1 | |
| Under Consideration | I would like to see the ability to use calculations (specifically sum) on geometry questions in the web interface. I ... by BrandonA_CDPH Frequent Contributor 2 2 | 2 | 2 | |
| Under Consideration | On a custom “thank you screen” defined in Survey123 Connect, it would be very helpful to have the ability to run Java... by kim77 Occasional Contributor 2 1 | 2 | 1 | |
| Under Consideration | I love the new address type question, so much easier to use than a map question when you want to collect the point lo... by JohnNergeBrooklynPark Frequent Contributor 8 5 | 8 | 5 | |
| Under Consideration | Survey123 Connect | Esri can you add the option to auto-magically create a Hosted, View when publishingI usually need... by MichelleWilliamsERM Frequent Contributor 9 2 | 9 | 2 | |
| Under Consideration | It would be helpful to include information in a webhooks payload that is not part of the feature layer data. For ins... by Andrew-Bowne Frequent Contributor 7 2 | 7 | 2 | |
| Under Consideration | Users can abandon a survey and discard the data collected. However, when data is primarily collected through repeats... by PhilHickey_ntg Occasional Contributor 2 5 | 2 | 5 | |
| Under Consideration | I would like to see a more visible choice for languages on the Survey123 form. Right now it's really obscure and tiny... by Jen_Zumbado-Hannibal Frequent Contributor 2 9 | 2 | 9 | |
| Under Consideration | Currently the deprecation item flag is mostly useless. It can be a deterrent from new users picking a service but the... by stevegourley Frequent Contributor 11 2 | 11 | 2 | |
| Under Consideration | I think a "Dark Theme" button...especially for all apps to the field workers would be optimal in a sunny day. by Anonymous User Not applicable 21 1 | 21 | 1 |
Idea Submission Guidelines
| User | Count |
| 8 | |
| 5 | |
| 5 | |
| 4 | |
| 4 |
