Esri Training Blog
Other Boards in This Place
Latest Activity
(172 Posts)
Zachary-Ordo
The 260-character Windows file path limit can cause issues when working with Sentinel SAFE products, such as Sentinel-1 (SAR) imagery, in ArcGIS Pro. This post shares practical tips for avoiding common path-length and data access problems.
Read more...
more
5 0 676
larogers
Customization of the ArcGIS Pro user interface and default settings is a great way to make ArcGIS Pro work for you and your specific workflows.
This article will start by setting up some default settings to get projects running quickly and smoothly, then dive into visualization and display customizations, and finish with a few options to improve efficiency with user interface customizations.
Read more...
more
2 0 981
MaryBWilson
Esri Alum
Attend the 2025 Esri Federal GIS Conference to explore how ArcGIS empowers government leaders as an essential decision-making platform, using a geographic approach to streamline operations and benefit society.
Read more...
more
3 0 1,943
TimothyHales
Esri Notable Contributor
Calculating the slope of a line across a surface is simple using the Add Surface Information tool in ArcGIS Pro. This tool overlaps the line feature with a surface, such as a LAS or raster dataset, to extract the elevation values and calculate the slope value.
But what do you do when you don't have a surface layer for the calculation?
When a surface layer is unavailable to calculate elevation values, you must use either attribute values or Z-values from the line feature. An ArcGIS Arcade expression can be used calculate the slope in an attribute rule and field calculation using these values.
Read more...
more
4 0 6,831
StephanieOliver
KevinPriestley
In the classes I teach, learners often ask a variation on this question: “The data I work with in my job is not as good as what we work with in class. Where do I go to find good data?”
Read more...
more
3 0 1,845
KevinPriestley
ArcGIS Pro can help us understand the world and make decisions.  With so much power just a few clicks away, new and longtime users of the software may struggle getting their projects off the ground.  This blog focuses on principles to help complete projects successfully.
Read more...
more
2 0 2,617
Robert_LeClair
Esri Esteemed Contributor
Interested in what data formats are supported in ArcGIS Pro?  One word answer...considerable!
Read more...
more
2 0 1,271
KatieSmith
Esri Alum
The kickoff to Esri User Conference is quickly approaching—July 10 will be here before we know it. Whether you’re packing your bags to join us in San Diego or attending virtually, Esri Training has several ways to connect. Read this blog to discover sessions to add to your schedule.
Read more...
more
1 0 4,398
StephanieOliver
8 2 31.3K
138 Subscribers
