Item Description launched from the ArcMap Table of Contents issue
2734
08-03-2010 02:15 PM
GregoryLehner
In ArcGIS Desktop 10, launching the Item Description for a layer by right-clicking on it from the ArcMap Table of Contents > Data > Item Description does not work.Note: Launching the Item Description from the Catalog Window or ArcCatalog does work.
Use the following workaround to solve this issue:
  1. Shut down ArcMap and ArcCatalog.
  2. Download the following ZIP file: Data Source Item Description window.zip
  3. Extract the .reg file located in the ZIP file to your hard drive or desktop
  4. Double-click the Data Source Item Description window.reg file. This adds a registry setting that enables the functionality.
  5. Open ArcMap.
The Item Description launched from the ArcMap Table of Contents > Data > Item Description will now work.
Sorry for any inconvenience this may have caused. Please leave any comments in the comment section below this blog post. NOTE: You must be logged in to your Esri Global Account to leave comments.
- Jeff M., Desktop Development Lead - User Advocacy Group, Esri Support Services
2 Comments
About the Author
Originally from Wisconsin, Greg is an avid fan of GIS (and a county collector)! He helps support ArcGIS Pro by developing next-generation map authoring capabilities and writing/editing web help resources.
