A lot of users often have questions concerning their system configuration for the version of software being used in conjunction with our products. Questions get more specific to involve installing patches, service packs, etc., within an environment and, in relation to ArcSDE Enterprise geodatabases, questions also involve RDBMS patches. Let’s outline some of the key points made in our Supported Environment Policy document that should help you answer these questions when considering patching a test or production database that houses ArcSDE Enterprise geodatabases.
Support Environment Policy
http://resources.arcgis.com/content/supported-environment-policy
Meet or exceed the minimum requirements:
Check out the ‘limitations’ section of the system requirements page:
Check that the 3rd-party vendor supports the environment:
Test, test, test!
Since Esri cannot test and certify every possible configuration, it is always recommended to thoroughly test any upgrade or change to your production environment on a test server first. This helps to ensure your organization’s workflows prior to implementing such a change.
Geodatabase and ArcSDE System Requirements – Version 10.0
http://resources.arcgis.com/content/geodatabases/10.0/geodatabase-and-arcsde-system-requirements
ArcGIS Server 9.3/9.3.1 System Requirements - see Supported Relational Database Management Systems (ArcSDE) section
http://wikis.esri.com/wiki/display/ag93bsr/ArcGIS+Server
