If Only This Topo Map Was More Interesting
2176
11-04-2011 12:45 PM
Labels (2)
by Anonymous User
Not applicable
0 0 2,176
Topographic maps are some of the most common maps that are in publication. They come in many shapes and sizes, but how can you really spice one up? What can you do to make a regular topographic map (like the one below) more interesting?
One idea, make the map 3D and it’ll become … Ta Da! ... a topographic block diagram!
This topographic patch is a view based on three datasets (topographic raster, TIN, and multipatch) in ArcScene. The multipatch forms the bottom of the diagram and is based on the extruded result between the two TINS. The buffer polygon is used as the input feature class in the Extrude Between process. In practice, it’s good to have a 2D polygon that’s buffered just outside the edge of the elevation raster. Follow these steps to do the same to your own topographic map:
  1. Create a TIN from the DEM. (You can also create a Terrain at ArcGIS 10.)
  2. Use the Raster Domain tool to create a polygon of the elevation area.
  3. Use Feature Class to Feature Class tool (disable the z value in the Environment setting).
  4. Buffer the polygon to extend just outside the area (buffered 1 meter in the example).
  5. Add Field and specify the base elevation. (This depends on the data; I selected a value of 1,200 with a bottom elevation of 1,310 for the elevation raster.)
  6. Create a TIN from the new polygon and specify a hard line based on the new field.
  7. Use the Extrude Between tool to create the multipatch.
  8. Open ArcScene and add the multipatch and the raster that you’re looking to enhance.
  9. Right-click the raster in the Table of Contents. Select properties > Base Heights and select the TIN you used.
  10. Select the 3D Effects Toolbar, select the multipatch and then, set the priority of the multipatch to below the raster.
Now you will have a topographic block diagram. In the example, a topographic map was used, but the same workflow will work with a three-band raster. Keep in mind that with ArcScene, larger rasters and larger multipatches can cause issues with the display because ArcScene uses a lot of memory. Remember to check out the Optimizing ArcScene tips found on the ArcGIS Resource Center.Jeff S. - Geodata Raster Support Analyst
