Geodatabase Questions
191
22.7M
2K
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Under Consideration | In the geodatabase schema report, can a new column be added to list any additional objects (tables, feature classes) ... by JarekDomanski Emerging Contributor 1 2 | 1 | 2 | |
Under Consideration | Just read this article on Field Descriptions in ArcGIS Online. I think that's a wonderful idea! I went to look up i... by Sarah_of_Lubbock Occasional Contributor 51 18 | 51 | 18 | |
Under Consideration | Currently a sync service (used to generate a replica) only allows a single layer per feature class. So you cannot ha... by JoeHershman ![]() 22 5 | 22 | 5 | |
Under Consideration | I'd like to be able to represent the equivilant of a self-join as a relationship class, but since the source and targ... by AJR Frequent Contributor 16 8 | 16 | 8 | |
Under Consideration | In previous versions ESRI supported Visio or Rational Rose as a CASE tool for Geodatabase modeling. These CASE tools ... by PeterFitts ![]() 31 15 | 31 | 15 | |
Under Consideration | After creating a feature class, it would be convenient to go back after data input, and make changes to the field ord... by NewingtonConnecticut Occasional Contributor 3464 209 | 3464 | 209 |
Idea Submission Guidelines
User | Count |
7 | |
2 | |
2 | |
1 | |
1 |
