Geodatabase Questions
125
7.4M
1.8K
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Open | Just read this article on Field Descriptions in ArcGIS Online. I think that's a wonderful idea! I went to look up i... by Sarah_of_Lubbock New Contributor II 1 0 | 1 | 0 | |
Open | Make it possible to store NaN values for Z values. This is possible for M values.If this is possible for Z values, th... by Nico_Burgerhart_Sweco New Contributor II 1 5 | 1 | 5 | |
Open | Could Esri provide recommendations in the documentation regarding GDB object naming conventions?Examples:Prefix so th... by Bud Regular Contributor III 2 1 | 2 | 1 | |
Open | There are different ways to store your metadata in ArcGIS Products: Feature Classes can have metadata which you can a... by Till_Strauss New Contributor II 0 2 | 0 | 2 | |
Open | There needs to be a way to block access of data when a map is publicly shared (everyone). Currently, there is no way ... by bjamaspi New Contributor 0 0 | 0 | 0 | |
Open | When creating a field, you're limited to specifying a static value as the default value. You can use Attribute Rules... by JoshSaad New Contributor III 1 2 | 1 | 2 | |
Open | Currently ArcGIS Pro allows us to view which domains are being used in a Geodatabase (which is great). It would be f... by MarkVolz Regular Contributor 1 0 | 1 | 0 | |
Open | Domains have the fields 'Code' and 'Description'.We experience that different users have different perceptions of the... by JohnZachariassen New Contributor II 5 0 | 5 | 0 | |
Needs Clarification | There are two geoprocessing tools in the Geodatabase Admin tool box: Create and Delete Database Sequence. You can ge... by JoeBorgione ![]() 9 6 | 9 | 6 | |
Open | Attribute Rules (AR) is the widely promoted replacement for the Attribute Assistant (AA) tool used in ArcMap. Attribu... by AlexSainz New Contributor III 11 5 | 11 | 5 |
Idea Submission Guidelines
User | Count |
5 | |
3 | |
2 | |
1 | |
1 |
