Data Management Ideas
Other Boards in This Place
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Latest Activity (460 Idea Submissions)
Sort/Filter :
Closed
I often need to create Table Views of linear feature class (FC) attribute tables to either create secondary geometric...
DaveMcPherson
by DaveMcPherson Occasional Contributor
in Data Management Ideas Last Updated 11-25-2025
2 2
Closed
Many point and line features are actually depicting a feature with a defined width rather than describing the actual ...
EricNeal
by EricNeal Emerging Contributor
0 6
Open
What about Offering the possibility to enable/disable 3D or 2D geometry on a layer in ArcCatalog.When 3D is disable t...
DelaereMickael
by DelaereMickael Frequent Contributor
in Data Management Ideas Last Updated 05-19-2016
1 0
Closed
If you create features like circles, ellipses or polygons and lines including circular arcs an publish those in an Ar...
mariuskolleck
by mariuskolleck Occasional Contributor
in Data Management Ideas Last Updated 10-26-2022
6 1
6
Open
What about to support hstore and json data format?
LucaSimone
by LucaSimone Deactivated User
in Data Management Ideas Last Updated 08-09-2018
3 1
Open
I have a table that I want to make into a featureclass by adding a shape field and then populating the values.This is...
KimOllivier
by KimOllivier Honored Contributor
in Data Management Ideas Last Updated 03-30-2015
3 1
Closed
Perhaps there is already a solution to this though I was not able to find one.  If anyone knows, please feel free to ...
KariBuckvold
by KariBuckvold Frequent Contributor
in Data Management Ideas Last Updated 11-02-2022
8 3
8
Open
I would like to be able to store annotation features to be used at varied scales within the same annotation feature c...
KirstenLawrence
by KirstenLawrence Regular Contributor
in Data Management Ideas Last Updated 11-26-2012
6 0
6
Closed
There was a wonderful tool for ArcMap 9.3.1 (a script by a user) that would convert map annotation to geodatabase ann...
MargaretGooding
by MargaretGooding Deactivated User
in Data Management Ideas Last Updated 11-09-2022
10 1
10
Closed
1) add/ integrate wikimapia user generated layers as a base map. ideally as a live service [as in the layer keeps upd...
isaacmathew
by isaacmathew Deactivated User
5 1
Closed
1. I would like the ability to move multiple labels, but have each retain their anchor locations.  Currently, everyth...
JimThomas
by JimThomas Occasional Contributor
7 1
7
Open
Currently there is the ability to add a record to a feature class without the corresponding geometry.  This can cause...
JoshWhite
by JoshWhite Honored Contributor
in Data Management Ideas Last Updated 04-29-2015
7 3
7
Already Offered
I would like a tool  or set of tools which would allow one to add a new feature class to a geometric network without ...
GennadyMogilevich
by GennadyMogilevich Occasional Contributor
in Data Management Ideas Last Updated 09-21-2022
17 2
17
Closed
It is now impossible to edit a defined layer. The defined layer cannot be added to the create features template. The ...
TomZEHRER
by TomZEHRER Deactivated User
in Data Management Ideas Last Updated 04-04-2025
4 1
Already Offered
ESRI please add:'Create Shapefile' [Point,Line,Polygon] +set datum/projection'Create Geodatabase' [All known data typ...
JeromeParkin
by JeromeParkin Deactivated User
in Data Management Ideas Last Updated 09-15-2022
16 2
16
212 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
