Geodatabase Questions
191
22.7M
2K
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Closed | The Attribute Transfer Tool Field Mapping can be set up to transfer the Source Shape field over to the Target Shape f... by RichardFairhurst ![]() 3 4 | 3 | 4 | |
Open | For many Polyline feature class data models a pair of fields or a set of four fields hold values that are dependent o... by RichardFairhurst ![]() 0 0 | 0 | 0 | |
Already Offered | Being able to retain foreign key values in any extract of data that the user wants to create that match the source pr... by RichardFairhurst ![]() 0 7 | 0 | 7 | |
Open | When migrating data from a source feature class to a destination feature class (new or existing), I found an issue if... by GKing Emerging Contributor 1 2 | 1 | 2 | |
Closed | I am in a situation to migrate huge database that contain more than 6 million records with tens of feature datasets ... by MarGIS Regular Contributor 0 6 | 0 | 6 | |
Open | One behavior of Table To Table—Conversion toolbox | ArcGIS Desktop, Copy Rows—Data Management toolbox | ArcGIS Deskto... by JoshuaBixby ![]() 0 3 | 0 | 3 | |
Closed | In ArcMap there is the Load Objects Command, it's found under customize mode. See link on how to add it in ArcMap. I ... by RichardLittlefield Frequent Contributor 20 15 | 20 | 15 | |
Open | I recently ran into the following problem:Problem: Data type in a feature class converts to double when exported from... by ColleenFarrell Occasional Contributor 0 0 | 0 | 0 | |
Open | When using the data loader in ArcCatalog. You spend the time to map out the fields to load into which field. Then af... by RobertBorchert Honored Contributor 10 2 | 10 | 2 | |
Open | When copying a layer in arcatalog, an option could purpose to keep or reinit the objectid field of the copying featur... by DelaereMickael Frequent Contributor 7 2 | 7 | 2 | |
Closed | Can we please have the ability to export symbology with a feature class / Layer when exporting it to a geodatabase. T... by JasonKennedy Occasional Contributor 7 3 | 7 | 3 | |
Open | sdeexport/sdeimport command is very fast and stable.ArcSDE command will be retired and ArcGIS can't handle the format... by SatoruGunji1 Deactivated User 6 0 | 6 | 0 | |
Already Offered | Currently it seems that once can use "cut & paste" to quickly move gemoetry from one shapefile / feature class to ano... by SeanGambrel Deactivated User 6 6 | 6 | 6 | |
Open | We have data that gets extracted from other sources and a filegeodatabase is created nightly. We need to load this da... by DorothyMortenson Deactivated User 25 1 | 25 | 1 | |
Open | There is a 'silent' datum transformation that may (or may not) take place when data is imported (Feature Class to Fea... by TylerGrosshuesch Occasional Contributor 4 0 | 4 | 0 |
Idea Submission Guidelines
User | Count |
7 | |
2 | |
2 | |
1 | |
1 |
