Geodatabase Questions
220
37.6M
2.1K
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
| Open | Add a line to the SQL Expression docs that clearly states:Correlated subqueries are not supported in file geodatabase... by Bud Legendary Contributor 0 1 | 0 | 1 | |
| Open | Edited as suggested by @JohannesLindner Regarding database views in geodatabases:It would be helpful if we could edit... by Bud Legendary Contributor 17 9 | 17 | 9 | |
| Open | Allow the Destination table in a relationship class to be a registered database view. The relationship wouldn't suppo... by DavidSolari 13 3 | 13 | 3 | |
| Open | Problem: Datasets have different domains that mean the same thing Example: Street Suffix' can be provided in differ... by JulieCulligan Occasional Contributor 1 1 | 1 | 1 | |
| Open | This is somehow related to: Web Map: time slider support for m-1 tabular data related to feature layer It happens t... by WernerStangl Emerging Contributor 0 2 | 0 | 2 | |
| Open | We maintain many of our base layers as spatial views registered with our Enterprise GeoDatabase. Unfortunately, we c... by MichelleMestrovich1 Regular Contributor 1 0 | 1 | 0 | |
| Open | I have 60 Relationships classes in my DB from a bunch of tables all connected to one master Feature class. (I also h... by DougBrowning 2 1 | 2 | 1 | |
| Open | I recently discovered that you cannot use standard aggregate or grouping SQL keywords (i.e. COUNT, GROUP BY, SUM) in ... by AndrewStickney1 Occasional Contributor 4 13 | 4 | 13 | |
| Open | If I want to run a SQL query to create a view from another database on another server I create a linked server. I th... by JeffTimm Frequent Contributor 9 1 | 9 | 1 | |
| Open | It would be really helpful if the CreateDatabaseView_management tool was enhanced with the option to create MATERIALI... by MarcoBoeringa 4 0 | 4 | 0 | |
| Open | Char_Field like '[A-Z]%' Char_Field like '%[1-9]%' etc. You've never been able to do this in a File Geodatabase, bu... by JoeBorgione 3 3 | 3 | 3 | |
| Open | I recently ran into an issue that caused me to review the SQL reference for query expressions used in ArcGIS—Help | A... by JoshuaBixby 9 27 | 9 | 27 | |
| Open | I often have to put data into a particular Data Model for our clients and then get an error that the string is too lo... by AlecBost Occasional Contributor 0 0 | 0 | 0 | |
| Open | Short Version: Join a non-spatial table to a feature class, and the records are mapped by the feature-classes geometr... by GreggRoemhildt1 Deactivated User 1 0 | 1 | 0 | |
| Open | My post is related to https://c.na9.visual.force.com/apex/ideaView?id=087E0000000CzjRIAS. It is a little different, ... by TroyBum72 Frequent Contributor 4 1 | 4 | 1 |
Idea Submission Guidelines
| User | Count |
| 2 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
