Data Management Ideas
Other Boards in This Place
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Latest Activity (445 Idea Submissions)
Sort/Filter :
Already Offered
Being able to retain foreign key values in any extract of data that the user wants to create that match the source pr...
RichardFairhurst
by RichardFairhurst MVP Alum MVP Alum
in Data Management Ideas Last Updated 02-22-2025
0 7
Already Offered
If I understand correctly, only the latest version of the ST_GEOMETRY .dll is available in My Esri downloads.For exam...
Bud
by Bud Esteemed Contributor
in Data Management Ideas Last Updated 05-25-2023
1 15
Already Offered
Rework the "Batch Project" geoprocessing tool to enable the reprojection from different input reference systems, like...
ClaireCG
by ClaireCG Emerging Contributor
in Data Management Ideas Last Updated 03-06-2023
0 4
Already Offered
Please certify Oracle 19.4 an up for geodatabase use with ArcGIS Desktop 10.7.1.SLES 15 support only Oracle 19.4 and ...
TomGO
by TomGO Emerging Contributor
2 11
Already Offered
Currently replicas can only be synced by the user the created the replica or a portal admin.  It is a common offline ...
JoeHershman
by JoeHershman MVP Alum MVP Alum
in Data Management Ideas Last Updated 10-05-2022
12 10
12
10
Already Offered
In enterprise and file geodatabases, the Shape.STArea() and Shape.STLength() fields are automatically calculated afte...
MarkWarren1
by MarkWarren1 Emerging Contributor
in Data Management Ideas Last Updated 09-20-2022
8 5
8
Already Offered
It is frustrating when one wants to create symbols with the colors from polylines to polygons you have to create the ...
RobertBorchert
by RobertBorchert Honored Contributor
in Data Management Ideas Last Updated 10-18-2022
3 2
Already Offered
If I had numbers 1-10 in an attribute table and sorted by this field the number 10 would be placed between 1 and 2. L...
ChrisRichardson
by ChrisRichardson Deactivated User
in Data Management Ideas Last Updated 09-14-2022
11 1
11
Already Offered
Much like the attribute table-> options-> show field aliases toggle, it would be helpful to be able to switch between...
TylerBurg
by TylerBurg Deactivated User
in Data Management Ideas Last Updated 09-09-2022
10 3
10
Already Offered
Prior to 10x users could facilitate the selection of only topology nodes by using the 'N' key. This made it easier to...
TiffanyPuett1
by TiffanyPuett1 Deactivated User
in Data Management Ideas Last Updated 01-31-2025
8 3
8
Already Offered
You cannot remove default values from fields using a toolbox but can certainly assign them with "Assign Default to Fi...
RonnieRichards
by RonnieRichards Frequent Contributor
in Data Management Ideas Last Updated 10-19-2022
10 3
10
Already Offered
We recently moved to a versioned database and enabled archiving at the same time so we can manage changes that may ne...
RobertPfingsten
by RobertPfingsten Deactivated User
in Data Management Ideas Last Updated 09-15-2022
11 2
11
Already Offered
Currently it seems that once can use "cut & paste" to quickly move gemoetry from one shapefile / feature class to ano...
SeanGambrel
by SeanGambrel Deactivated User
6 6
6
6
Already Offered
Change the new ArcGIS 10.1 Create Database User geoprocessing tool so that it does not grant create data privileges i...
NathanHeick2
by NathanHeick2 Deactivated User
16 1
16
Already Offered
The file geodatabase API/SDK should support any coordinate system ArcGIS itself understands and can use.After days of...
mattwilkie
by mattwilkie Deactivated User
in Data Management Ideas Last Updated 12-12-2022
36 5
36
188 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
