Helpful Utility Network Links
37931
16
07-05-2022 08:50 AM
This article contains a list of content that will be useful in your journey with the ArcGIS Utility Network. It includes links to learning content, blogs, and other informative content to help you along the way. You can also find several "cheat sheets" you can print out and reference for identifying and resolving your topology and subnetwork errors.
I recommend most users start with the Getting Started with the ArcGIS Utility Network learning series (or one of the industry-specific playlists below) and the Learning about the ArcGIS Utility Network article. These two resources contain links to dozens of articles, blogs, videos, and other content to help get you up to speed on the ArcGIS Utility Network.
Learning Series
Webinars and Videos
Esri Video - ArcGIS Utility Network Channel
General Information
Introduction
Releases, Versions, and What's New
Migration Toolset
Utility network administration
Utility Network Journey
Creating Business Value
Asset Packages
Apps, Maps, and Services
Configuration
Utility Network Development
Solutions, Tools, and Add-Ins
Data models and deployment
Misc Tools
Branch Versioning
Videos
Articles
Network Diagrams
Learning
Videos
Articles
Can you think of any content I missed? Have any feedback on additional content you'd like to see? Comment down below!
Comments
Pat_Hohl
This is a gold mine! Thanks, Robert.
bmberede
Thank you for this. bookmarked!
MuhammadQasim
I am about to appear for the Esri Certification exam (ArcGIS Utility Network 20-001). Found this documentation very helpful and at the right time. Thank you, Robert.
RobertKrisher
@MuhammadQasim Good luck!
MatheusSparapani
Thank you for this @RobertKrisher!
HemendranathMoravapalle
New Explorer
Hi everyone - i'm looking for Telecom related  UN article.
appreciate if anyone can suggest few that are available in ESRI site.
many thanks in advance.
RViswanadha
📢 Thank you @RobertKrisher
robertopepato_bizpoke
Thank you for sharing this @RobertKrisher . This is very helpful in providing guidance and a path for the community to learn about every important aspect of UN.
I think there is a minor issue with the link to the webinar "Migrating and Implementation of the ArcGIS Utility Network". It links to https://www.youtube.com/watch?v=6J66bYFAVck (which is the same link as the "The Business Values of the ArcGIS Utility Network" webinar). I believe that the correct target for "Migrating and Implementation of the ArcGIS Utility Network" link should be https://www.youtube.com/watch?v=cudpvQGiOnM
RobertKrisher
@robertopepato_bizpoke Good catch! I've updated the link in the article.
AbigailCharbonneau
Hello,
Very helpful list of articles, so thanks for posting! I recently upgraded from UN 3 to UN 5 and am running into Warning 24099: The web layer being published cannot be consumed by ArcGIS Pro without all the <value> layers being present, when trying to share it. I cannot figure out how to resolve this and to my knowledge have all the UN layers/related tables in the map when publishing. Any recommendations or known problems with this when upgrading to UN 5?
Thanks in advance.
Abby
RobertKrisher
@AbigailCharbonneau check out the utility network upgrade history link on this page. We introduced several new layers and table to the utility network with the v4 utility network. That page will walk you through all the steps you need to take for each release, so you will need to do everything called out in the v4 changes and v5 changes.
We also introduced many new capabilities and features, so I would recommend you also check out the links for the "What's New in the ArcGIS Utility Network".
Omar_A
by Esri Contributor
This is a treasure of information! Definitely will be a resource for my learning and development path. Thanks, @RobertKrisher
Best,
Omar
JoseVR
New Explorer
Oh my... this is awesome. There is a lot of content, I hope've enough time to read it all.
Thank you.
JayHodny
Robert,
Thank you for this resource!  Aside from the 'where to start' suggestions in the opening paragraphs, is there an order to which one should follow in reviewing this content?  We are in the early stages of migrating to the utility network.  Any directional advice would be most appreciated.  Regards, Jay
Aaron_Sapsford
@RobertKircher  - I recently saw this in the Developer release notes for UNv7 support in the Maps SDK
Release notes for 200.5 | ArcGIS Maps SDK for .NET | Esri Developer
Question regarding those sites that are part way through implementations on 11.3 using a v6 UN because of the previous advice not to go to v7 until BIGINT ObjectID's are supported in the Maps SDK. At which point in the Network Release cycle of Enterprise should we start thinking about moving off of version 6? This will have a bearing on future upgrades etc.
Version history
Last update:
2 weeks ago
Updated by:
Contributors
