Utility Network SDK Trace Conditional Expressions
Sorry for the detailed question, but I'm kind of pulling my hair out over this one. I'm trying to perform a subnetwork trace that stops at: * All Open Devices * All Fuses * Single phase reclosers, and * Single phase sectionalizers My code is below — including the resulting SQL. It produces an SQL query that seems correct,…
Getting a downstream trace to continue past Pressure Reducing Valves (Pressure tier)
I'm stuck on a tracing scenario and haven't found an answer yet. I've asked several people who work with the Utility Network, and nobody has been able to solve it. Setup * Several of our wells discharge directly into a pressure zone. Because of that, they're set up as subnetwork controllers on the Pressure tier. *…
Trace JSON output missing connectivity through node-node associations
I am attempting to write a Python script that walks upstream of a sewer subnetwork controller and writes metadata to features as it goes. My simple n-ary tree traversal works as I want and expect. However, when I get to a location where a manhole channel and pipe connection are in a node-node association, the data to make…
Normally open bus tie breaker not acting as a barrier during Update Subnetwork (ERROR 001890)
In substations where two transformers feed separate bus sections joined by a normally open (N.O.) bus tie breaker, Update Subnetwork fails with ERROR 001890. The error names the transformer subnetworks on both sides of the bus tie. The bus tie breaker has Operating Status = Open. The disconnect switches on either side of…
Custom Network Diagram Templates for Utility Network Foundations
Network Diagrams is a core component of the Utility Network that generates schematic representations of utility networks. By simplifying network complexity and highlighting key operational relationships, it enables organizations to better analyze, troubleshoot, plan, and manage their networks. These diagrams typically…
StandAlone Table Relationship Class to Feature Class in Utility Network
I am working with the latest Electric Utility Network from ArcSolutions and want to add a series of stand-alone File GDB Tables with relationship classes. Example: Electric Device - MV Transformer relationship to GISeXFMR. When I run the Create Relationship Class tool, it runs fine but when I select a feature and open the…
Subnetwork Trace includes barrier features when trace is configured to exclude
ExcludeBarrierFeatures.png As shown in the attached, I perform a subnetwork trace with the option to include barrier features un-checked, but they are included in trace results anyway. This is ArcGIS Pro 3.5.6. Any suggestions would be much appreciated. Thx
Attribute withOUT domain not copying when line split
I am doing my work in ArcGIS Pro 3.7.x. I created an AssetTag field with long integer as the type. There is no domain assigned to this field. It does have a calculation attribute rule assigned but is currently disabled for testing. When I split the line the attribute is Null in the new segment instead of a copy of the…
Is a SourceDefinitionQuery in the Data Reference workbook required?
Using Pro 3.7.1 with Load Data Using Workspace, the tool will fail if there is not a Source Definition Query. If I add a valid Def Query, such as 1=1 or similarly ObjectID > 0, the tool will continue. The doc indicates only use a Def Query if a subset is needed. Data Ref Doc Tool Doc Error Message: Load Data Using…
Set Network Category - Anomalous behavior with the Subnetwork Tap category
Hi everyone, Set Network Category 1.png Set Network Category 2.png I’ve noticed some anomalous behavior with the Set Network Category geoprocessing tool in ArcGIS Pro 3.7, regarding the Subnetwork Tap system category. In the tool’s Categories dropdown, Subnetwork Tap appears only for asset types that have a terminal…
Association Issue in Esri UN
I have imported the associations and validated the topology , The rules exist it did not create any dirty area though . But When I check in the association pane it showing the error the item that participates in containment association is invalid @RobertKrisher
AssignTerminalConnections on an already-released Utility Network (branch versioned)
Hi everyone, I need to assign terminal connections using the AssignTerminalConnections tool. The issue is that the Utility Network is already deployed in an enterprise environment, so branch versioning is enabled, and the tool fails with: TypeError: cannot update branch versioned table. The workflow I had in mind is: *…
Owned By Data not Migrating Correctly
We are currently migrating a data from GTECH to Esri UN using an Electric AP . In the Asset package the features have null in ownedby attributes . When We apply the AP to Enterprise the NULL values are coming as with Default value which we dont want to happen . How to fix this ? @RobertKrisher @MikeMillerGIS
Modeling hot standby circuit breakers
What is the best way to represent an open hot standby circuit breaker in an electric utility network that needs to be geometrically connected to two separate subnetwork names? If this were any other device, this circuit breaker would have SUBNAME1::SUBNAME2, but this is not possible because the CB is the subnetwork…
Difference between UN Package Tools and UN Tools
This discussion was created from comments split from: Difference between Utility Network and UPDM.
ESRI Recommendation for Incremental Loading of ~8 Billion Records into an Existing Utility Network
We need to migrate approximately 8 billion records into a PostgreSQL Enterprise Geodatabase containing an ArcGIS Utility Network. Due to data volume limitations, the data will be loaded incrementally in multiple batches into the same Utility Network. What is the ESRI-recommended approach for: * Incremental batch loading *…
Pole-Conduit Connectivity
We are migrating data from GTech to Esri UN , In GTECH the Conduits are owned by Poles . How to replicate this in Esri . Is only the Junction -Edge connectivity is enough here , Or Do I need to create any structure attachment to the Pole . But we can't create a structure attachment from pole to Conduit as per feature…
Reconcile error
I recently published a Gas UN data and an LRS data as a service. The aim is that users are able to create their versions based on the published data set. Users are able to create versions successfully, but whenever we try to reconcile Users branched version edits, we hit a snag. Error message code - 500 is what we get…
Export Subnetwork Question
Hi - A few years ago our company started providing proposed equipment from GIS to our outage system (Oracle NMS). We applied a few conventions to data in our ArcFM Feeder Manager managed distribution system and it, by and large, works OK. Energization is now performed in NMS by the system operator — who is in direct…
Identifying orphaned features in Utility Network
As far as my understanding of the Utility Network goes, the topology rules dictate the legal combinations of devices and lines, e.g. being silly that a manhole can join to a sewer but not a watermain, which at validation time makes alot of sense. However there doesn't seem to be anything stopping an editor adding an…
Utility network vocabulary specifically for water and wastewater (sewer) utility assets
Hi, Does anyone know of a similar vocabulary/terminology document similar to this (Utility network vocabulary | ArcGIS Pro documentation) but with specific references to/examples of water and wastewater (sewer) utility assets. This would be very helpful for water and wastewater utilities to understand how our current data…
The 2026 subnetwork performance improvements and Utility Network Version 8
Hi, I have been reading the following article about the 2026 Network Management Release What's new for ArcGIS Utility Network with the 2026 Network Management Release One part is especially interesting for us: “performance has been improved for subnetworks that use propagation and when updating a subnetwork for the first…
Question on asset package and utility network in enterprise geodatabse
Hello Everyone, I have been reviewing various resources regarding ArcGIS Utility Network deployment, which highlight that an Asset Package contains the schema, rules, and properties inherited by the Utility Network and must reside in a File Geodatabase. I would like to know if it is technically possible or supported to…
How to integrate between Utility Network data and DIgSILENT?
Hello, What method can be used to integrate data from Utility Network with DIgSILENT? Taking into account the need for connectivity nodes and other factors.
Add Selected to Relationship - should it warn/error?
I have an ArcGIS Relationship Class between ServiceLocation (a Feature Class) and Premise (an Object Class), with cardinality 1:M. In Pro, I select a Premise that is not (yet) related to any Service Location. In the map I select two Service Locations, with OIDs 114352 and 114359, respectively. (The actual values don't…
