Attribute withOUT domain not copying when line split
I am doing my work in ArcGIS Pro 3.7.x. I created an AssetTag field with long integer as the type. There is no domain assigned to this field. It does have a calculation attribute rule assigned but is currently disabled for testing. When I split the line the attribute is Null in the new segment instead of a copy of the…
Is a SourceDefinitionQuery in the Data Reference workbook required?
Using Pro 3.7.1 with Load Data Using Workspace, the tool will fail if there is not a Source Definition Query. If I add a valid Def Query, such as 1=1 or similarly ObjectID > 0, the tool will continue. The doc indicates only use a Def Query if a subset is needed. Data Ref Doc Tool Doc Error Message: Load Data Using…
Set Network Category - Anomalous behavior with the Subnetwork Tap category
Hi everyone, Set Network Category 1.png Set Network Category 2.png I’ve noticed some anomalous behavior with the Set Network Category geoprocessing tool in ArcGIS Pro 3.7, regarding the Subnetwork Tap system category. In the tool’s Categories dropdown, Subnetwork Tap appears only for asset types that have a terminal…
Association Issue in Esri UN
I have imported the associations and validated the topology , The rules exist it did not create any dirty area though . But When I check in the association pane it showing the error the item that participates in containment association is invalid @RobertKrisher
AssignTerminalConnections on an already-released Utility Network (branch versioned)
Hi everyone, I need to assign terminal connections using the AssignTerminalConnections tool. The issue is that the Utility Network is already deployed in an enterprise environment, so branch versioning is enabled, and the tool fails with: TypeError: cannot update branch versioned table. The workflow I had in mind is: *…
Owned By Data not Migrating Correctly
We are currently migrating a data from GTECH to Esri UN using an Electric AP . In the Asset package the features have null in ownedby attributes . When We apply the AP to Enterprise the NULL values are coming as with Default value which we dont want to happen . How to fix this ? @RobertKrisher @MikeMillerGIS
Modeling hot standby circuit breakers
What is the best way to represent an open hot standby circuit breaker in an electric utility network that needs to be geometrically connected to two separate subnetwork names? If this were any other device, this circuit breaker would have SUBNAME1::SUBNAME2, but this is not possible because the CB is the subnetwork…
Difference between UN Package Tools and UN Tools
This discussion was created from comments split from: Difference between Utility Network and UPDM.
ESRI Recommendation for Incremental Loading of ~8 Billion Records into an Existing Utility Network
We need to migrate approximately 8 billion records into a PostgreSQL Enterprise Geodatabase containing an ArcGIS Utility Network. Due to data volume limitations, the data will be loaded incrementally in multiple batches into the same Utility Network. What is the ESRI-recommended approach for: * Incremental batch loading *…
Pole-Conduit Connectivity
We are migrating data from GTech to Esri UN , In GTECH the Conduits are owned by Poles . How to replicate this in Esri . Is only the Junction -Edge connectivity is enough here , Or Do I need to create any structure attachment to the Pole . But we can't create a structure attachment from pole to Conduit as per feature…
Reconcile error
I recently published a Gas UN data and an LRS data as a service. The aim is that users are able to create their versions based on the published data set. Users are able to create versions successfully, but whenever we try to reconcile Users branched version edits, we hit a snag. Error message code - 500 is what we get…
Export Subnetwork Question
Hi - A few years ago our company started providing proposed equipment from GIS to our outage system (Oracle NMS). We applied a few conventions to data in our ArcFM Feeder Manager managed distribution system and it, by and large, works OK. Energization is now performed in NMS by the system operator — who is in direct…
Identifying orphaned features in Utility Network
As far as my understanding of the Utility Network goes, the topology rules dictate the legal combinations of devices and lines, e.g. being silly that a manhole can join to a sewer but not a watermain, which at validation time makes alot of sense. However there doesn't seem to be anything stopping an editor adding an…
Utility network vocabulary specifically for water and wastewater (sewer) utility assets
Hi, Does anyone know of a similar vocabulary/terminology document similar to this (Utility network vocabulary | ArcGIS Pro documentation) but with specific references to/examples of water and wastewater (sewer) utility assets. This would be very helpful for water and wastewater utilities to understand how our current data…
The 2026 subnetwork performance improvements and Utility Network Version 8
Hi, I have been reading the following article about the 2026 Network Management Release What's new for ArcGIS Utility Network with the 2026 Network Management Release One part is especially interesting for us: “performance has been improved for subnetworks that use propagation and when updating a subnetwork for the first…
Question on asset package and utility network in enterprise geodatabse
Hello Everyone, I have been reviewing various resources regarding ArcGIS Utility Network deployment, which highlight that an Asset Package contains the schema, rules, and properties inherited by the Utility Network and must reside in a File Geodatabase. I would like to know if it is technically possible or supported to…
How to integrate between Utility Network data and DIgSILENT?
Hello, What method can be used to integrate data from Utility Network with DIgSILENT? Taking into account the need for connectivity nodes and other factors.
Add Selected to Relationship - should it warn/error?
I have an ArcGIS Relationship Class between ServiceLocation (a Feature Class) and Premise (an Object Class), with cardinality 1:M. In Pro, I select a Premise that is not (yet) related to any Service Location. In the map I select two Service Locations, with OIDs 114352 and 114359, respectively. (The actual values don't…
New ArcGIS Utility Network Associates Exam
A newer version of the ArcGIS Utility Network Associates exam is scheduled to be release Q4 2026, replacing the version developed in 2024. You can also find a link of resources to help you prepare for the exam by reading the Esri Utility Network Associates - Exam Information Guide article. You can learn more about the…
Editing the Utility Network system of record using ArcGIS Pro
Hi, I would like to connect with any water and/or wastewater utility organisations that have moved from data management editing in ArcMap ArcGIS for Water Utilities to ArcGIS Pro with the new Utility Network data model. Obviously there is a vast amount of correspondence, resources etc. regarding the UN generally but so far…
Update subnetwork GP tool reports not dirty, but data shows it *is* dirty
Step 1. Attempt to update subnetwork "0041012022". Result: Network is not dirty. Step 2: Examine Subnetwork table: Subnetwork 0041012022 status is "Dirty" Any ideas or suggestions for what is going on would be appreciated. Thx, Ed
Trying to correct what is apparently a corrupt geometry I get the error: Underlying DBMS Error [Success]
Step 1: Select "Rebuild current extent" Step 2: Operation failed.
Best approach for migrating branch-versioned Utility Network data from UN v5 to UN v7 with schema changes?
Hi All, I am looking for advice on the best approach and recommended tooling to migrate data between two separate Enterprise Geodatabases (EGDBs) running different versions of the ArcGIS Utility Network. Our Current Setup & Goal: * Source: Utility Network Version 5 (running on branch versioned data, published as a Feature…
Export Subnetwork REST - Fails Intermittently with the error "message": "Dirty subnetwork cannot be exported."
Hi Team, I am trying to programmatically export all subnetworks. This used to work before but now it seems to be failing and I cannot quite put my finger on the problem. I have tried using FME. But the issue seems to be on the server side, to test this I am using the browser. It works, works, fails, then works again. GIF…
