ArcGIS Survey123 Blog
Other Boards in This Place
Latest Activity
(277 Posts)
ChrisLeSueur
A new update to ArcGIS Survey123 is now available. This update includes important fixes to the Survey123 website and web app.
Read more...
more
6 8 865
BrettStokes
Bug fix and JS API update
Read more...
more
3 1 339
CoryMarietta
Make sure to stop by the Survey123 kiosk and tech sessions at the Esri Partner Conference and DevSummit!
Read more...
more
6 3 576
IsmaelChivite
Esri Notable Contributor
A new update to ArcGIS Survey123 is now available! Learn in 3 one-minute videos what is new!
Read more...
more
10 3 1,934
HenryLindemann
How to deploy Survey123 Web + Survey123 Connect in a disconnected/offline environment using the Survey123 web Api
Read more...
more
3 0 845
BrettStokes
The latest (3.19) version of the Survey123 website installer has just been made available for download via the My Esri site.
The 3.19 version includes all of the fixes and improvements from the November 14, 2023 update of the Survey123 web app and website, along with the following improvements to the installed website itself:
  • BUG-000155630 [DE-000006740, DE-000006948] - Map doesn't load when accessing via reverse proxy and the website is installed on the same machine as the ArcGIS Enterprise it is configured with.
  • BUG-000159328 - Address questions don't provide suggestions when configured with JSAPI <4.21.
  • BUG-000147221 - Map and Address questions not working when configured with JSAPI <4.18.
  • BUG-000150542 - Update JRE to v17.0.7
  • BUG-000155551 - The website does not honor the specified PEM certificate within the config.json file
  • BUG-000139658 - The website configured with a reverse proxy returns an error 404 not found error after clicking Save As.
  • A bug was fixed in which upgrading a Linux installation didn't maintain the Portal configuration.
  • A bug was fixed in which the post installation text alignment was incorrect for RTL locales.
  • Update Node.js to v18.18 to avoid security vulnerabilities.
  • Update Python to v3.11.6.
  • Other bug fixes and enhancements.
If you’re not familiar with the Survey123 website installer or why some organizations need it, please refer to this previous blog post: Understanding the Survey123 website installer. It provides details on what it is, what you get, how it works and some other things to consider before setting it up in your local environment.
More information can also be found in the Documentation and the following Knowledge Base articles:
more
3 1 449
IsmaelChivite
This article describes how you can use Microsoft Power Automate to work with Survey123 attachments. Specifically, it provides step by step instructions to:
  • Include one or more Survey123 attachments in an email
  • Upload Survey123 attachments into Microsoft OneDrive and Sharepoint
Read more...
more
10 12 5,600
IsmaelChivite
The Survey123 module in the ArcGIS Python API will get a big boost in 2024. Join this session to learn what's coming and provide feedback!
Read more...
more
8 0 1,318
IsmaelChivite
This article describes how the Survey123 mobile app works together with TruPulse® laser rangefinders from Esri Silver Partner Laser Tech.
Read more...
more
4 1 2,111
IsmaelChivite
This release strengthens multi-lingual survey support and brings a good number of fixes to the Survey123 website, web and mobile apps. Read on to learn more...
Read more...
more
2 16 2,830
452 Subscribers
