ArcGIS Survey123 website installer: What's new (January 2024)
1149
01-23-2024 06:52 PM
BrettStokes
The latest (3.19) version of the Survey123 website installer has just been made available for download via the My Esri site.
The 3.19 version includes all of the fixes and improvements from the November 14, 2023 update of the Survey123 web app and website, along with the following improvements to the installed website itself:
  • BUG-000155630 [DE-000006740, DE-000006948] - Map doesn't load when accessing via reverse proxy and the website is installed on the same machine as the ArcGIS Enterprise it is configured with.
  • BUG-000159328 - Address questions don't provide suggestions when configured with JSAPI <4.21.
  • BUG-000147221 - Map and Address questions not working when configured with JSAPI <4.18.
  • BUG-000150542 - Update JRE to v17.0.7
  • BUG-000155551 - The website does not honor the specified PEM certificate within the config.json file
  • BUG-000139658 - The website configured with a reverse proxy returns an error 404 not found error after clicking Save As.
  • A bug was fixed in which upgrading a Linux installation didn't maintain the Portal configuration.
  • A bug was fixed in which the post installation text alignment was incorrect for RTL locales.
  • Update Node.js to v18.18 to avoid security vulnerabilities.
  • Update Python to v3.11.6.
  • Other bug fixes and enhancements.
If you’re not familiar with the Survey123 website installer or why some organizations need it, please refer to this previous blog post: Understanding the Survey123 website installer. It provides details on what it is, what you get, how it works and some other things to consider before setting it up in your local environment.
More information can also be found in the Documentation and the following Knowledge Base articles:
1 Comment
