ArcGIS Hub Blog
146
608K
76
Open | Setting content height levels in Hub for applications, surveys, or embedded content in a Page is limiting - often cut... by Teresa_Blader Occasional Contributor III 2 2 | 2 | 2 | |
Open | We would like the ability to configure the order of the file formats for download formats, both as a default for our ... by KatieMorgan New Contributor II 2 0 | 2 | 0 | |
Open | When a hosted feature layer is filtered by default, the record count on the Hub downloads page reflects the number of... by shannon-julius New Contributor II 0 0 | 0 | 0 | |
Open | When adding users to a supporting team in Hub Premium, you get a "Customize Notification" screen with only Nevermind ... by ChelseaRozek MVP Regular Contributor 0 0 | 0 | 0 | |
Open | A Gallery card in an ArcGIS Enterprise Site is a great way to display web maps available in ArcGIS Enterprise. Prior ... by dimesv New Contributor II 9 4 | 9 | 4 | |
Open | In many cases, people have asked for me to include pdf reports into the hub exerience. This is achievable but the us... by LiamHarrington-Missin Occasional Contributor II 5 6 | 5 | 6 | |
Open | When cloning a Hub site that includes many uploaded images, the process may time out and fail. Esri's recommended pra... by LaurenWinkler Occasional Contributor 0 0 | 0 | 0 | |
Open | We run a relatively stable/unchanging, but very well-used, Open Data site using ArcGIS Hub, and only recently noticed... by HilaryBrowning2 New Contributor II 22 8 | 22 | 8 | |
Open | I am using the gallery widget as a placeholder for site pages. I just need the department name to show up and wish I ... by Laura MVP Regular Contributor 1 0 | 1 | 0 | |
Open | On the Survey123 Card, it would be great if there was an option to load the theme added from the Survey123 Web App, v... by Teresa_Blader Occasional Contributor III 0 0 | 0 | 0 | |
Open | Add CSS to the "calcite-accordion-item" which will allow screen readers to recognize the header in the accordion. Add... by DarrenLloyd__DOIT New Contributor III 1 3 | 1 | 3 | |
Open | In the Upcoming Events card I suggest creating the option to choose date picker and list separately. Currently the op... by DarrenLloyd__DOIT New Contributor III 0 0 | 0 | 0 | |
Open | 1. There should be the opportunity to add some additional options (choice list) into the Follow button - for example ... by LiisiPark New Contributor III 0 0 | 0 | 0 | |
Open | Hub Team Folks,First: you provide a nice platform to share data with the public. I'm a big fan of your work and I fee... by MiltonSolano Occasional Contributor II 1 0 | 1 | 0 | |
Open | ArcGIS Hub does not allow you to create events for dates that have occurred in the past. Our use case wasn't for prom... by Jason_Ho New Contributor II 0 0 | 0 | 0 |
Idea Submission Guidelines
User | Count |
6 | |
2 | |
2 | |
2 | |
1 |
