ArcGIS Hub Blog
195
1.1M
97
Open | Allow users to adjust column width in table view. It is impossible for a user to view the data when they cannot incre... by PeterSpurgeon1 Emerging Contributor 0 0 | 0 | 0 | |
Open | Add a built-in header style to support dropdown capable menu links. by EfeU Occasional Contributor 1 0 | 1 | 0 | |
Open | In ArcGIS Hub, when setting custom Terms of Use for an item, the system currently auto-detects certain license titles... by MatthewRyanGA Emerging Contributor 4 0 | 4 | 0 | |
Open | Would be great if the Image widget had more configuration options for placement, size, carousel etc. the current widg... by JonathanMcD Frequent Contributor 3 0 | 3 | 0 | |
Open | Add a built-in option to filter content by owner in the ArcGIS Hub when managing content for a hub site. In the Hub ... by JacquieHrncir Emerging Contributor 5 0 | 5 | 0 | |
Open | I would like to have the ability to choose fields which fields can be used for filtering in a layer shared in the ope... by JenniferBorlick Frequent Contributor 2 1 | 2 | 1 | |
Open | Currently to download a subset of data based on location, the user needs to turn on the "filter as map moves" in the ... by JenniferBorlick Frequent Contributor 0 0 | 0 | 0 | |
Open | Way back in the day when hub first was a thing, I think I remember that when you hit "Publish" It would publish all o... by JenniferBorlick Frequent Contributor 2 0 | 2 | 0 | |
Open | Notify hub organisation administrators when hub is down. This comes after an interruption to the service yesterday (h... by DataOfficer Frequent Contributor 2 3 | 2 | 3 | |
Open | We’d like to see one of the following functionalities implemented in ArcGIS Hub:The ability to interact with and zoom... by hexagonenergy27 Emerging Contributor 1 0 | 1 | 0 | |
Open | Hello, I just read about the release of the 'Check Items' tool in StoryMaps and was curious if there are plans to rel... by Veronicampbell Frequent Contributor 1 0 | 1 | 0 | |
Open | We used to be able to get to the other pages in our site fairly easily. Now the only way to get there is to go to the... by JenniferBorlick Frequent Contributor 4 1 | 4 | 1 | |
Open | Show some sort of deprecation marker on the content in the content library. Right now it doesn't indicate an item is ... by SupriyaK Regular Contributor 4 0 | 4 | 0 | |
Open | When adding an existing page to a hub site, there is no filtering available to see content you own or content your or... by CaitlinParker2 Occasional Contributor 2 1 | 2 | 1 | |
Open | In hub workspaces, the "Type" category on the content area of your default workspace sorts by item count. It would id... by CaitlinParker2 Occasional Contributor 0 0 | 0 | 0 |
Idea Submission Guidelines
User | Count |
5 | |
3 | |
2 | |
2 | |
2 |
