System Log Parser - Statistics and Service Optimization
18286
13
04-23-2019 10:38 AM
JacobBoyle412
15 13 18.3K
What is System Log Parser?
System Log Parser is an ArcGIS for Server (10.1+) log query and analyzer tool to help you quickly quantify the "GIS" in your deployment. When run, it connects to an ArcGIS for Server instance on port 6080/6443/443 as a publisher (or an administrator), retrieves the logs from a time duration (specified as an input), analyzes the information then produces a spreadsheet version of the data that summarizes the service statistics. The command-line version of System Log Parser (slp.exe) is used by ArcGIS Monitor for data capture.
Note:   This post is a second in a series on System Log Parser, please see ArcGIS Server Tuning and Optimization with System Log Parser to learn how to setup your server for System Log Parser and an overview of the report.
Introduction to Statistics Used In System Log Parser
There are several statistical categories you should be familiar with when using System Log Parser. (definitions from Wikipedia)
Percentile (P) - a measure used in statistics indicating the value below which a given percentage of observations in a group of observations falls. For example, the 20th percentile is the value (or score) below which 20% of the observations may be found.
Average (avg) -   is a single number taken as representative of a list of numbers. Different concepts of average are used in different contexts. Often "average" refers to the arithmetic mean, the sum of the numbers divided by how many numbers are being averaged. In statistics, mean, median, and mode are all known as measures of central tendency, and in colloquial usage, any of these might be called an average value.
Maximum (Max) - the largest value of the function within a given range.
Minimum (Min) - the smallest value of the function within a given range.
Standard Deviation (Stdev) -    measure that is used to quantify the amount of variation or dispersion of a set of data values. A l...
Fields of the Statistics Collected
Field
Definition
Resource Requested resource or service (Service REST endpoint)
Capability The ArcGIS capability of the resource
Method The function performed by the resource (What was accessed)
CountThe number of requests for this resource
Count Pct Count percentage based on total service requests
Avg The average time (in seconds) spent processing request
MinThe time (in seconds) of the shortest request
P5, P25, P50, P75The percentile grouping of the time (in seconds)
P9595% of all responses occur between 0 seconds and the value displayed in this column per service
P9999% of all responses occur between 0 seconds and the value displayed in this column per service
MaxThe time (in seconds) of the longest request
StdevThe standard deviation of time (in seconds)
SumThe total time (in seconds) spent processing requests per resource
Sum PctThe total time (in seconds) spent processing requests
We're going to focus on 2 key statistics, P95 and Max.  As we learned above, P95 signifies the response time for the fastest 95% of all requests and Max signifies the maximum draw time per request per service and method.
Identifying Opportunities to Tune Service Performance
In the example below, I've sorted P95 and Max values over 1/2 second.  User experience drops the longer your draw-time takes.
I've highlighted any Max draw time over 1/2 second in red and any P95 draw time over 1/2 second in yellow.  These are the services and layers I'd focus on cleaning up, focusing first on getting the P95 value below 1/2 second first.
In the next section you'll find starting points to tune and optimize your services.
Another column worth reviewing is the Sum Pct.  this column factors in the number of requests for each service and the respective average time, then weights that in against all the other services.
Sum Pct
For example:
  1. One service may have thousands of more requests than all others but it has fast times (Sum Pct should be low)
  2. Another service may have just a small handful of requests but very slow times (Sum Pct should be high). In this case, this service would be a good candidate to for tuning.
Best Practices for Services
Below are some links to get you started on service tuning and SOC management.
In addition to the above, data source performance should be looked at if adjustments to the service do not help enough. You can look at:
I hope you find this helpful, do not hesitate to post your questions here: https://community.esri.com/thread/231451-arcgis-architecture-series-tools-of-an-architect
Note: The contents presented above are recommendations that will typically improve performance for many scenarios. However, in some cases, these recommendations may not produce better performance results, in which case, additional performance testing and system configuration modifications may be needed.
13 Comments
MehdiPira1
Very useful! Thanks @JacobBoyle412
by Anonymous User
Not applicable
Exactly what we needed!!! Thank you @JacobBoyle412 !
NickMiller2
Does anyone have a sample bat file that schedules the running of System Log Parser that they can share?
ZachBodenner
MVP Regular Contributor
What does it mean when a Username in a system log parser output is given as "Anonymous User?" At first I though it was just an indicator that a publicly available service was accessed by...a member of the public. But in the report I ran recently I have Anonymous User listed as an accessor for internal services.
AaronLopez
Hello @NickMiller2
What is the log source you are wanting to parse with SLP? ...I'll list examples for using several of the common ones. Select one of the slp.exe commands below and arguments and put them into a bat file.
ArcGIS Server Log Query (File System)
slp.exe -f AGSFS -i \\myserver.domain.com\c$\arcgis\arcgisserver\logs\MYSERVER.DOMAIN.COM -eh now -sh 30day -a optimized -validate true
ArcGIS Server Log Query (Web)
slp.exe -f AGS -s https://myserver.domain.com/server -u gisadmin -p Myp@ssword -eh now -sh 7day -a optimized -validate true
Internet Information Services Log Query
slp.exe -f IIS -i \\myserver.domain.com\c$\inetpub\logs\LogFiles\W3SVC1 -eh now -sh 30day -a optimized -validate true
All of the examples commands above use the Optimized report which is the recommended Analysis Type. The Optimized report has tremendous memory savings over the other analysis types, especially if you are reading 30days worth of logs. If you are wanting to query ArcGIS Server logs but can only use the web, reading 30day might be difficult (due to the nature of the REST Admin API that is used behind-the-scenes).
To assist in troubleshooting, the "-validate true" is passed into the slp.exe command in print any potential errors to the console that might be encountered. Otherwise, slp.exe runs "silently".
For in-depth troubleshooting, you can optionally pass in "-apploglevel DEBUG". This will create a unique run log of the slp.exe execution...with alot of detail. The log file is typically found in:
C:\Users\gisadmin\Documents\System Log Parser\Logs\Application_agsfsx2_20220702T220628_k6a7xrhk.log
Hope this helps.
AaronLopez
> internal services.
Hi
 ZachBodenner,
If an ArcGIS Enterprise internal service is shared to Everyone (public) and is accessed without the member actually logging in, the user entry in the log is typically just anonymous. Other log entries (which SLP might use based on the analysis being performed, like wait time, instance creation time, arrival time, etc...) may alternatively list, Anonymous user. But for case of the "Statistics By User" worksheet, I usually just see anonymous listed for non-authenticated entries.
There also some one-off user entries that I cannot directly explain...other than SLP is just reporting on what is in the logs. For example, some user entries are listed as: 0123456789abcdef::[username] or null. The alpha-numeric listing in front of the user account is not seen often and I believe is just observed with a few services. The 'null' entry is another version of anonymous...but isolated to just one or two particular services.
Hope that helps.
AaronLopez
The following is an additional resource which may help provide information on the "anonymous" entries observed in the ArcGIS Enterprise (e.g., ArcGIS Server) logs:
ArcGIS Enterprise Analysis with System Log Parser: Understanding Anonymous Entries for the User Name...
Br1an_Peters
For the .bat file how can we change the save report location? Any reason this isnt part of the ArcGIS Monitor (we have 2023 version)
AaronLopez
Hi @Br1an_Peters,
To specify a custom output location use the -d option with a path.
For example:
slp.exe -d "C:\Folder1\MyReports" -s https://myserver.domain.com/server -eh now -sh 2hr -a Optimized -u siteadmin -p sit3adm1nPW
Br1an_Peters
@AaronLopez  Have you seen or know of a way to create a dashboard for this data? I really wanted this in ArcGIS Monitor, but I do not see how to get all this data. Power BI template?
AaronLopez
Hi @Br1an_Peters,
Not sure on creating a dashboard.
However, you can tell System Log Parser to write out the statistical analysis of a Simple report as JSON (instead of an xlsx file). This could be used as input to a dashboard or observability tool.
slp.exe -d "C:\Folder1\MyReports" -s https://myserver.domain.com/server -eh now -sh 2hr -a simple -u siteadmin -p sit3adm1nPW -r json
AndreaB_
Hi @AaronLopez or others,
I have fairly high elapsed times for Max and P95 columns on the Statistics by Resource tab for a few lines where the resource method is "/export" and "layers/x/query" for MapServer. The "query" I can guess means someone clicking on the map service and getting the response back. Correct me if I'm wrong.
But I'm wondering about the "/export" method? We don't have users exporting our data from our map services - to my knowledge. Is that what that means?
Thank you!
A
AaronLopez
Hi @AndreaB_,
I think that is a good guess on the query calls. Such log entries could be from users or from dashboards.
These map layer query requests return data in the form of json, pbf or kml.
For MapServer services, this textual info is pulled from each layer separately which can then be rendered in a client (e.g., a JavaScript app).
Export on the other hand, is a request to generate an image of this same data from one or more layers at once. While the function is called export, "export map" only returns a rendered image...not the actual data.
Hope that helps
Aaron
About the Author
Mr. Boyle is an expert in GIS technology, system planning, design, development and administration with a focus on public sector and E&P in the oil and gas industry. He has 15 years experience as a government, non-profit and E&P employee for organizations in North America. Through his work as a GIS Database Administrator, he has gained in-depth organizational and technical experience for system development, deployment, and management. He has strong technical skills in GIS and IT application design and development, database design, systems architecture, and integration and holds several technical certifications. His technical skills are complemented by his experience in project management and organizational development. He has a Bachelors in Environmental Studies – Geography, Mr. Boyle has received extensive post graduate training and education in information technology, GIS, and Geographix. He holds a GISP Certificate.
