Implementing ArcGIS Blog - Page 4
Latest Activity
(186 Posts)
JeffDeWeese
GIS has evolved at a rapid pace ever since computers took up to the challenge of providing spatial capabilities. The evolution of GIS from a Map creation platform to a Location Intelligence platform necessitates the need to build systems that are robust, reliable, and elastic as they are utilized to host solutions that your business relies on to be successful. GIS is everywhere running from servers running within traditional data centers, the Cloud, and from mobile and IoT devices. Supporting such a diverse landscape creates unique architectural challenges that require a systematic approach to designing your GIS.
Esri system architecture design is based upon traditional architecture patterns centered around multiple tiers, namely a Client/Application, Presentation, Services, Support, and Data tier. Each tier aligns with Esri products and solution components as depicted by the example logical architecture below. Following a systematic approach, this blog series will explore the various architectural tiers and their related solution components in support of building modern GIS platforms to meet today's business and Location Intelligence needs.
more
11 0 5,991
MichaelHatcher
What is Infrastructure as Code?
Taken directly from Microsoft,
"Infrastructure as Code (IaC) is the management of infrastructure (networks, virtual machines, load balancers, and connection topology) in a descriptive model".
In the simplest terms, Infrastructure as Code (IaC) is a methodology to begin treating cloud infrastructure the same as application source code. No longer are changes made directly to the infrastructure, but to the source code for a given environment or deployment. This change in behavior will lead to environments that are easily reproducible, quickly deployable and accurate.
Note:   This post is one (1) in a series on engineering with ArcGIS.
What is Terraform?
Terraform is a tool for building, changing, and versioning infrastructure safely and efficiently. Terraform can manage components such as virtual machines, networking, storage, firewall rules and many others. To define what needs to be deployed or changed, terraform uses what is called a terraform configuration which can be made up of one or more individual files within the same folder. Terraform files utilize the file extension
.tf
as well as HCL (HashiCorp Configuration Language) as the configuration language. HCL is a structured configuration language that is both human and machine friendly for use with command-line tools, but specifically targeted towards devops tools, servers, etc.
In complex deployments, administrators may find they can utilize a different configuration file for each aspect of their environment as such,
/environment_a
   /production
      network.tf
      machines.tf
      storage.tf
      security.tf
   /staging
      network.tf
      machines.tf
      storage.tf
      security.tf
whereas with simple deployments, a single file may be sufficient, such as
/environment_a
   main.tf
To actually create and manage infrastructure, terraform has a number of constructs to allow users to define Infrastructure as Code but the most important two are Providers and Resources.
Resources
Resources are the mechanism that tell terraform how the infrastructure should be deployed and configured. Each cloud provider will have its own list of Resources that users will have access to. An example would look something like this which creates an azure resource group and a virtual network within.
resource "azurerm_resource_group" "rg" {
   name = "prd"
   location = "westus2"
resource "azurerm_virtual_network" "vnet" {
   name = "prd-vnet"
   address_space = ["10.0.0.0/16"]
   resource_group_name = "prd"
Providers
Providers are the mechanism for defining what cloud provider or on-premise Resources are available for use. Each provider offers a set resources, and defines for each resource which arguments it accepts, which attributes it exports, and how changes to resources of that type are actually applied to remote APIs. Most of the available providers correspond to one cloud or on-premises infrastructure platform, and offer resource types that correspond to each of the features of that platform. In simpler terms, if the goal is to define infrastructure on Azure, an Azure based provider must be used before Resources can be defined.
A provider example for Azure would look something like this,
provider "azurerm" {
   subscription_id = "this-is-not-a-real-subscription-id"
   client_id = "this-is-not-a-real-client-id"
   client_secret = "this-is-not-a-real-client-secret"
   tenant_id = "this-is-not-a-real-tenant-id"
Terraform has multiple methods for authenticating to a given cloud provider and in this example, a Service Principal is being utilized.
State
Lastly, terraform makes use of a State File that keeps track of the infrastructure that has been deployed and configured. This state file is what allows terraform to run checks against the last recorded state of an environment compared to the current run and provide users the delta so validation can be done before making changes. This aspect is very important in that it allows terraform to be idempotent, which is a key aspect of IaC.
Infrastructure Life-cycle
For the purposes of this introduction, we will be using the attached terraform template as the basis for the following examples. This template will be posted to GitHub in the near future for future articles to utilize and build off. It is designed to deploy the following within an Azure subscription.
Before it can be deployed, the deployInfo variable group (Map) will need to be populated. When creating the Service Principal, the following documentation (Service Principal creation) can be reference for assistance. Terraform will also need to be available locally. The steps to ensure it is can be found here.
  • Resource Group
  • Virtual Network
  • Subnet
  • Network Security Group
    • Rule to allow 80 and 443 traffic from the internet into the virtual network
    • Rule to allow RDP access (3389) into the virtual network from the public IP of the person who deploys the template. This is accomplished by querying the web during deployment and retrieving your public IP. This workflow is not recommended in production environments and is only being used for example purposes.
    • Rule to block all other internet traffic into the virtual network.
  • Storage account
  • Availability Set
  • Public IP
  • Network Interface
  • Virtual Machine
    • Windows Defender Extension
    • Recovery Services Vault Extension
  • Key Vault
    • Backup Policy
Creation
Once terraform is available locally and the deployInfo variable map has been completed, the first step in deploying infrastructure is to initialize terraform. This can be accomplished by navigating to the directory in which you have saved the above template with the .tf file extension and running the following command, which will prepare various local settings and data that will be used by subsequent commands.
terraform init
The output from initializing terraform will resemble the following.
With terraform successfully initialized, the next step in the process is to have terraform review the template and determine what changes need to take place. This step will have terraform compare the template with the current state file and produce an output showing the deltas as follows. To do so, use the following command.
terraform plan
Output has been truncated.
As this is the first run of terraform, terraform is only able to see resources it needs to add (create). Later in this post, we will walk through updating existing resources.
With terraform successfully prepared to deploy our infrastructure, we can being the deployment by using the following command which will start the process of creating the resources within Azure and provide the following output when complete.
terraform apply
Updates
As the deployment is utilized, it may be determined that the current infrastructure is not adequately sized and resources need to be increased. As our resources are defined as code, so is the virtual machine sizing. Within the "arcgisEnterpriseSpecs" variable map, a variable is defined with the name "size" which is the Azure machine sizing that is used by terraform when deploying resources.
If this variable is changed to "Standard_D8s_v3" and terraform plan is ran again, it will detect a delta between what is defined in code and what is actually deployed within Azure and present this in the output as such.
Once this delta is planned and the changes are ready to be pushed to the actual infrastructure within Azure, simply running terraform apply again will begin the process.
Decommission
The last phase of a given deployments life-cycle is decommissioning. Once infrastructure has reached the end of it life, it must be terminated and removed and thankfully, terraform provides an easy method to do so with the following command.
terraform destroy
The output of destroying the infrastructure will resemble the following.
In conclusion, as teams aim to become more agile and move at a much faster pace, moving to modern methodologies such as infrastructure as code (IaC) is a great first step and should not be viewed as unnecessary but a crucial step in the right direction.
I hope you find this helpful, do not hesitate to post your questions here: https://community.esri.com/community/implementing-arcgis/blog/2019/07/03/engineering-arcgis-series-t...
Note: The contents presented above are examples and should be reviewed and modified as needed for each specific environment.
more
7 1 7,632
SridharKarra
The Managed Cloud Services team in Professional Services is pleased to announce a new series that will be highlighting various tools and best practices for implementing ArcGIS Enterprise using modern methodologies.
System implementation, configuration and management of the deployment is a fun challenge, similar to Tetris. As an ArcGIS Enterprise or ArcGIS Server administrator, you are likely tasked with standing up new systems, ensuring they are configured correctly and maintaining them over time. Traditionally, these tasks were done manually where an administrator would work through procuring a new virtual machine, install the required software, work through the configuration steps needed and then ensure users were able to access it. Over time, the needs of the users may change and as such, the administrator would need to further modify the system and its software to meet those needs.
Here at Managed Services, we are faced with managing 100's of customer implementation. This series will cover best practices we developed overtime. Each entry will cover a specific aspect of automating the deployment, configuration & life-cycle management (updates, monitoring, scaling, etc) of both infrastructure and the ArcGIS suite.
automation, devops, implementation , engineering‌, cloud‌
more
12 4 5,982
JeffDeWeese
As cloud adoption evolves from Web GIS to full GIS deployments, questions continue to be raised such as, “What about the desktops?”. That is, when moving desktops to the cloud, what technologies should be used to support Esri desktop GIS? The cloud offers multiple desktop options and the following will provide some high-level guidance as to how and when these technologies should be used. It is important to realize that each deployment is unique and deciding on which of these technologies to deploy involves multiple factors. The purpose of providing this information is primarily to share information regarding all of the potential solutions and high-lighting some of their key characteristics. However, they will not be ranked in any way as deciding on one approach over the other requires more detailed analysis and discussion based on specified requirements, costs, and constraints. Further, this list can likely be expanded but the solutions below represent the most common options that Esri has encountered.
Note: Assuming ArcGIS Pro will be used for rendering, ArcGIS Pro requires a GPU-enabled machine type for the underlying host VM. Examples include the NVv4 for Azure and a Graphics Bundle for AWS WorkSpaces.
Virtual Machines - Azure and AWS
  • Use Case: Typically used to support administrative functions or small number of desktop users
  • Client Connectivity: Utilizes the Remote Desktop Connection client and the RDP protocol
  • User Experience: Published desktop with growing visual latency as geographic distance increases
  • Scalability: Limited due to no more than two concurrent users per VM
  • Management: Typically deployed without a base image
  • User Profiles: Locally stored per VM
Remote Desktop Services  - Azure and AWS
  • Use Case: Supporting users at scale where the users are not globally distributed
  • Connectivity: Utilizes the Remote Desktop Connection client and the RDP protocol
  • User Experience: Published desktop or apps with growing visual latency as geographic distance increases
  • Scalability: Limited for ArcGIS Pro based on the number of concurrent sessions that can share resources (e.g., GPU)
  • Management: Can be used with snapshot technology to create a base image
  • User Profiles: Roaming profile or equivalent, assuming at least two servers deployed
Citrix Virtual Apps and Desktops (XenApp) - Azure and AWS
  • Use Case: Supporting users at scale where the users could be globally distributed
  • Connectivity: Utilizes the Citrix Workspace app and the HDX protocol
  • User Experience: Supports both published desktops and apps and performs well with high-latency
  • Scalability: Limited for ArcGIS Pro based on the number of concurrent sessions that can share a GPU
  • Other: Can utilize Citrix Cloud to manage the "back-end" (e.g., Controllers/Licensing)
Amazon WorkSpaces - AWS
  • Connectivity: Utilizes either a desktop or web client with either the PCoIP or WSP protocol
  • User Experience: Supports a published desktop to an assigned WorkSpace instance
  • Scalability: Can scale as needed as users increase but is 1:1 user to VM assignment
  • Management: Cannot be used with snapshot technology so each WorkSpace is an independent deployment
  • User Profiles: Locally stored on each WorkSpace
Amazon AppStream 2.0 - AWS
  • Use Case: Supporting user applications at scale
  • Connectivity: Utilizes either a desktop or web client with the NICE DCV protocol
  • User Experience: Supports published desktop applications
  • Scalability: Can scale as needed as back-end infrastructure capacity is managed by AWS
  • Management: Based on creating base images for different application configurations as needed
  • User Profiles: Saved to a Virtual Hard Disk (VHD) and synchronized to Amazon S3
  • Other: Esri / AWS AppStream 2.0 Deployment Guide
Azure Virtual Desktop - Azure
  • User Experience: Supports a published virtual desktop
  • Scalability: Can scale as needed assigning users to virtual desktops
  • User Profiles: Roaming profile or equivalent, assuming at least two servers deployed (e.g., vie FSLogix)
  • Other: The only solution supporting multi-session Windows 10/11
more
8 4 7,688
JeffDeWeese
As the Esri platform continues to evolve, it is critical that organizations maintain a capable GIS system architecture that will support new GIS/IT capabilities and scale to support growing user demand. There are further key considerations that we have seen most recently such as moving to the cloud, migrating to ArcGIS Pro, and expanding the adoption of GIS capabilities within the organization. Esri Architects can work with you to understand your organization’s needs and provide guidance. We will be available at UC2019 at the Guiding Your Geospatial Journey area of the Esri Showcase and participating in several sessions throughout the conference. Meanwhile, have a look at the Architecture and Security section of GeoNet where you will discover valuable information related to GIS system architecture!
Technical Workshops
Tuesday, July 9        Location: SDCC - Rooms
8:30 am
Esri Best Practices: Architecting Your ArcGIS Implementation
SDCC, Room 33 C
8:30 am
Moving to a Managed Cloud Services Environment
SDCC, Room 30 A
Wednesday, July 10        Location: SDCC - Rooms
8:00 AM
Designing an Enterprise GIS Security Strategy
SDCC, Room 30 A
1:00 pm
SDCC, Room 31 A
4:00 pm
SDCC, Room 31 A
Thursday, July 11        Location: SDCC - Rooms
10:00 am
How to be Successful with Esri Managed Cloud Services
SDCC, Room 16 A
Spotlight Talks
Tuesday, July 9                             Location: SDCC – Expo: Guiding Your Geospatial Journey Spotlight Theater
11:15 am
ArcGIS Enterprise: Architecture Best Practices
1:00 pm
ArcGIS in the Cloud
1:30 pm
Build Security into Your System
Wednesday, July 10                          Location: SDCC – Expo: Guiding Your Geospatial Journey Spotlight Theater
10:00 am
Are You Cloud Ready?
11:15 am
Designing a Robust Environment - Workload Separation
1:30 pm
Considerations for a Highly Available Enterprise
4:30 pm
Designing a Robust Environment - Environment Isolation
5:45 pm
Distributed Web GIS - A Modern Approach to Sharing
Appointments
Tuesday, July 9 – Thursday, July 11  Location: SDCC – Expo: Guiding Your Geospatial Journey Spotlight Theater
Architecture Maturity Review
Get expert advice and feedback on your enterprise implementation, including best practices. Leave with recommendations for meeting security and architecture needs.
Schedule an appointment
Stop by to connect 1-on-1 with Esri Staff that can talk more about your system architecture plans in our Guiding Your Geospatial Journey area.
Tuesday, July 9               9:00 AM–6:00 PM
Wednesday, July 10        9:00 AM–6:00 PM
Thursday, July 11            9:00 AM–4:00 PM
more
3 0 747
AdamCarnow
If you're headed to the 2019 Esri International User Conference and are interested in sessions for GIS Managers, here is a link to the GIS Manager Track:
https://userconference2019.schedule.esri.com/schedule?filters=1964269831
more
0 0 703
AdamCarnow
Are you a GIS manager, leader or other executive headed to the 2019 Esri International User Conference (UC)?  I know it can be a challenge creating your personal agenda for the world's largest GIS conference, so I created this flier to assist.  It covers suggested events and activities you should consider when deciding how to spend your valuable time at UC.  I hope you have a productive UC experience, and I hope to see you there!
UPDATED 6/24/2019 - Added GIS Manager Track and Get Advice from Esri Services section.
UPDATED 6/13/2019 - Corrected the name of the Implementing ArcGIS area in the Expo to “Guiding your Geospatial Journey”
FYI there are other Esri UC fliers here: https://community.esri.com/community/events/user-conference/content?filterID=contentstatus%5Bpublish...
more
3 0 2,680
AhmadAbdallah
Introduction
To cloud or not to cloud is the question that many organizations are currently facing. While on-premise data center technology is not necessarily on the verge of extinction, cloud computing is an option with many benefits including scalability, agility and cost efficiency.
The ArcGIS platform is supported on both on-premises or in a cloud environment like Microsoft Azure or Amazon Web Services (AWS). By leveraging these components, you can expose GIS content and capabilities as web services and consume those services in your apps. This enables users to access and apply useful GIS resources in their work.
Moving to the cloud is more than just upgrading your servers and software. It represents a radical change in the way that you manage technology. This shift gives you a unique opportunity to align technology with your overall business vision, which in turn can help you grow your business, improve productivity, and reduce costs.
Before starting, it is a must to document your current infrastructure, this includes compiling a list of your servers, storage systems, network components, off the shelf software, bespoke software, and subscriptions to gain a full picture of your current technology. This information is critical for helping you determine the best path forward.
Analyzing your current infrastructure against your user workflows is the next step.  From assessing your desktop workflows to assessing your integrations, your security policies, SLAs, data storage requirements, authorization, and authentication providers all these points will play a huge factor in designing your cloud infrastructure. We will discuss these topics briefly in this article and will go into the specifics of each separately in future blogs posts.
General Database Considerations
Moving your Geodatabase to the cloud is a big step, you need to consider where your clients accessing the data exist, are they running from the cloud or on-premise, and what is the type of work is being performed (read-only, frequent edits, etc.).
General Network Bandwidth and Speed
Moving all the infrastructure to the cloud will need a resilient and reliable Internet connection, most importantly with low latency. Low bandwidth can be a serious problem when you factor in a large number of employees sharing the same network. Sometimes cloud solutions don’t offer enough bandwidth, especially when it comes to uploading larger files such as raw satellite imagery. However, latency is the primary concern as network latency is the key factor in determining cloud architecture decisions, for example, because of the latency it is likely not practical to keep desktops on premise and move the database into the cloud.
Assessing ArcGIS Desktop Workflows
First and Foremost, do you need to provide this functionality through ArcGIS Pro or ArcGIS Desktop, or can we have it replaced via a web-based app? That would save us setting up a dedicated machine or application instance on the cloud.
Is the data you are processing 2D or 3D? ArcGIS Pro required a GPU and the resourcces are even more demanding if processing 3D data. GPU enabled machines on the cloud cost considerably more than machines without a GPU. Do you have advanced Geoprocessing workflows that require hefty computing power, do these workflows run overnight? Check out https://pro.arcgis.com/en/pro-app/get-started/virtualization-overview.htm for more information about running ArcGIS Pro on the cloud.
ArcGIS Server Sites and Portal for ArcGIS Sites
The least difficult method for starting to use the cloud for hosting your own software is perform a lift-and-shift migration, where you move software currently running on-premises to the cloud host. The behavior of the software is precisely the same after moving into the cloud however now it is running with the benefits of underlying cloud infrastructure, such as having affordable and reliable virtual machines that don’t require high upfront purchasing costs and little ongoing maintenance of the infrastructure.
Using specialized deployment tools can make it easier to install and configure the software on certain cloud platforms. You can also create your own machine images to host Esri software in cloud environments. These deployment tools don’t just install and configure the software; they also provision and set up the underlying infrastructure, including the virtual machines, load balancers, networking, and storage.
Bespoke GIS Applications
Whether you have Geocentric applications, Geo-enabled applications, or Composite applications you will need to reassess the architecture of these applications and ensure the compatibility with the new cloud environment. check out developers.arcgis.com for information about our wide coverage of SDKs and APIs.
No single application integration pattern fits all situations. You can use the application pattern that best combines capabilities from ArcGIS and your business system to deliver the greatest impact.
Integration to Other Systems
Application integration lets you deliver solutions that combine data and tools from different systems—including your GIS as well as business systems like permitting, licensing, and asset management systems. With integrated solutions, you can improve cross-functional business processes and provide decision-makers with integrated views of your organization’s information. Insuring that these systems integrate prevents information duplication and enables having the right data available when you need it. You need the option of deploying your integration technology so that it works in both environments. To decide whether your integration technology will reside in the cloud or in a rack in your data center, you have to start with the specific requirements of your business.
Security
Security is not only an important decision to avoid becoming a statistic, but also one that may be government regulated. Depending on your industry, market, and location, you may have to abide by an array of rules determining how you use and store sensitive data. Cloud security has come a long way, though, and is arguably as secure as most private data centers. In either case, security and regulations of your industry are something to think about when considering cloud and on-premise. With either option, security is granularity configurable to meet your security needs. Consider Esri best practices for configuring secure ArcGIS Server and Portal for ArcGIS environments as well as your organization's needs and policies when designing your ArcGIS Enterprise site security.
High Availability and Redundancy
Designing the HA environments in Azure or AWS are somewhat the same design principles as of on-premises however more functionality is provided by cloud providers such as scalability on demand. You can configure your site so that ArcGIS Server machines are added in response to certain triggers, such as CPU usage. New servers can be created in a matter of minutes, allowing your site to gracefully respond to abrupt spikes in traffic. When you no longer need the instances, you can destroy them and incur no further infrastructure charges for them. The installation is much easier as now there are images already provided for faster installation times.
Backups and Disaster Recovery
Cloud computing has led to a new way of preparing for IT disasters by providing secondary environments for backing up and restoring data and failing over business applications. These disaster recovery services are cost-effective and straightforward to set up. ArcGIS Server and Portal for ArcGIS include utilities that you can use to create backups and restore your sites on Azure and AWS.
Access Management Providers
When implementing a cloud-based application it can be a challenge to ensure that information security and access management controls are applied to the cloud application.
Organizations should ensure that the single sign-on (SSO) access management is implemented in the cloud. In particular, organizations need to understand how employees can seamlessly access the various cloud-based applications using their existing access management protocol.
Portal for ArcGIS is compliant with SAML 2.0 and integrates with identity providers that support SAML 2 Web Single Sign-On. The advantage of setting up SAML is that you do not need to create additional logins for users to access your ArcGIS Enterprise portal; instead, they use the login that is already set up in an enterprise identity store. For example, Microsoft Azure Active Directory is a SAML-compliant identity provider. You can configure it as your identity provider for enterprise logins in Portal for ArcGIS on-premises and in the cloud.
I hope you find this helpful, do not hesitate to post your questions here: - Arcgis Architecture Series : Moving to the Cloud
more
10 0 10.8K
JeffDeWeese
Often the term "VDI" is used to define ArcGIS Desktop/ArcGIS Pro deployed as a virtual application. The challenge is understanding what specific virtualization technology is actually being referenced when using this term since VDI, or "Virtual Desktop Infrastructure", represents just one of several desktop virtualization options. So, the intent of this article is define the options and differentiate what VDI truly means.
ArcGIS Desktop has been delivered virtually for over 20 years using what is referred to as "hosted virtual applications" which includes technologies such as Citrix XenApp (recently renamed to Virtual Apps) and Microsoft Remote Desktop Services (RDS). This approach is referred to as "hosted"  because it is being hosted by a singular operating system which users share by initiating individual user sessions. This technology option represents a many-to-one relationship in terms of users and virtual machines. Further, the shared operating system is a server OS, such as Windows 2016 and not a desktop OS, such as Windows 10. Hosted virtual applications provides a means to share a singular server with multiple users and is an attractive option since since each user doesn't require their own dedicated virtual machine. For this approach, system resources are shared including processors, memory, and GPU and there isn't a practical way to assign resources at the individual user session level.
A more recent innovation is to provide individual virtual machines to users as "virtual desktops" where each user accesses a remote desktop deployed with a desktop operating system such as Windows 10. This includes technologies such as Citrix XenDesktop (recently renamed to Virtual Desktops) and VMware Horizon. This approach represents the true meaning of "VDI" as it is defined by a one-to-one relationship between users and virtual machines. Though this approach increases per-user deployment costs, it also provides a more isolated deployment in terms of resources since processors, memory, and GPU resources can be assigned accordingly. The ability to manage GPU resources for the virtual desktops has made this approach an attractive option for ArcGIS Pro which requires a GPU.
So, the next time you hear the term "VDI" used for delivering ArcGIS to users, know that this implies that each user is being presented with their own individual Windows desktop virtual machine with a set of assigned resources as opposed to users accessing a singular server-based virtual machine and sharing it with multiple users, including sharing the server's assigned system resources.
more
6 0 3,252
JacobBoyle412
Amazon and Esri recently published a whitepaper outlining the steps needed to setup and configure Amazon AppStream 2.0 and ArcGIS Pro.
Through testing, Esri and AWS outline the various classes of AppStream hosts:
ArcGIS 2D Workloads – stream.compute.large, stream.memory.large. Compute and Memory optimized instances are perfectly suited for ArcGIS Pro workloads that does not require a GPU.
ArcGIS 3D Workloads (Normal) – stream.graphics-design.xlarge. Graphics Design instances are ideal for delivering applications such as ArcGIS Pro that rely on hardware acceleration of DirectX, OpenGL, or OpenCL. Powered by AMD FirePro S7150x2 Server GPUs and equipped with AMD Multi user GPU technology, instances start from 2 vCPU, 7.5 GiB system memory, and 1 GiB graphics memory, to 16 vCPUs, 61 GiB system memory, and 8 GiB graphics memory.
ArcGIS 3D Workloads (High res) – stream.graphics-design.2xlarge or stream.graphics-pro.4xlarge. The Graphics Pro instance family offers three different instance types to support the most demanding graphics applications. Powered by NVIDIA Tesla M60 GPUs with 2048 parallel 4 processing cores, there are three Graphics Pro instances types starting from 16 vCPUs, 122 GiB system memory, and 8 GiB graphics memory, to 64 vCPUs, 488 GiB system memory, and 32 GiB graphics memory. These instance types are ideal for graphic workloads that need a massive amount of parallel processing power for 3D rendering, visualization, and video encoding, including applications such as ArcGIS Pro.
Please find the full whitepaper here: https://d1.awsstatic.com/product-marketing/AppStream2.0/Amazon%20AppStream%202.0%20ESRI%20ArcGIS%20P...
more
1 3 5,344
133 Subscribers
