Using Near Me Without Looking At Near Me: Triggering Near Me From A Search Bar And Sending The Results To A List (Also, Hidden Widgets)
14199
22
01-19-2024 12:18 PM
JeffreyThompson2
MVP Frequent Contributor
17 22 14.2K
When Near Me came out last summer, I was pretty excited. At the time I was working on a public facing application where people could filter a list of parks by their amenities to figure out which one they should go to. And it would be so nice, if they could put in their address and get the list sorted by their location. But, I was very disappointed by the actual implementation of the Near Me Widget. I wrote up my complaints on the ideas board here, but to summarize I just don't like the user interface of Near Me, especially for a public facing application, and I don't want to give up more screen space to Near Me when I already have a well-designed List Widget. I ended my rant on the Ideas board with this:
For my application, the ideal Near Me widget would just be a search bar with a current location button next to it. The user could enter an address or press the button and see the results in the list widget.
Well, since the October 2023 ArcGIS Online update, it is now possible to build that (or something pretty close to it). Here's how...
Step One: Triggering Near Me From Search
For this recipe, we will need a Map Widget, a Search Widget, a Near Me Widget and a List Widget. Let's drag them all into our Experience now and we'll set them up as we go. Start with your Map Widget and select the webmap you want to use. Then, go the Search Widget and pick a locator source. You'll also want to open the Search Suggestion options and check the Use Current Location option.
In the Action Tab, add a Record Selection Changes > Near Me > Set Location Action. (A Map > Zoom To Action is not necessary, but you'll probably want it, too.)
Step Two: Set Up Near Me
First, I select my Map Widget. At this point, Near Me will display this scary and confusing warning.
This is normal. Near Me is asking you to click on the name of your map again to open up the Analysis settings menu.
In the Analysis settings menu, pick Specify a location, set some sort of buffer distance (I went with 5 miles.) and the click the Add Analysis button.
In the next window, I picked Analysis Type > Proximity and Sort features > Distance. (I also turned off Highlight results on map.)
I also opened the General Settings and set the Sketch Color to rgba(255,255,255,0). (Translation: transparent white.) In testing, I found that the default transparent option made a dark grey circle that was actually still very noticable, but by using transparent white there was just a faint dimming of the map and a barely visible edge of the circle.
Step Three: Send Near Me Results To A List Widget
In the List Widget, click Select Data > Outputs > Near Me > Whatever I Named My Near Me Output. (I'm also going to add a No data message to tell the user to use the Search Widget.)
And there we go, when I search in the search bar the data will be transferred to this List. Style up your List Widget as you see fit. (Here's a post about all the various List Widget options.)
But, why? What was the point of all of this?
  1. A well designed List Widget just looks better and is easier to use than the Near Me Widget interface.
  2. Now that the data is in a List Widget, I can do all the stuff that the List Widget can do including, but not limited to, searching, sorting and filtering within the list, sending to a table, and exporting as CSV, JSON or geoJSON. Near Me can only do one of those things: download as a CSV.
Step Four: Hiding Near Me (Hiding The Widget, Not Hiding Close To Me. That's Creepy. Don't Do That.)
At this point, we have a Search Widget that automatically fills Near Me results into a List Widget. We don't need to look at the Near Me Widget anymore. So what can we do with it? Delete it? Send it to the Pending List? Stick it in a Section or Widget Controller? No, doing any of those things would break this build. We are going to do something far stupider. We are going to make it tiny. In the Style Tab of the Near Me settings, set the Width and Height to 0px. Experience Builder won't truly honor my 0 x 0px request. It seems that the true minimum widget size is 16 x 16px.
See that tiny box I circled in red. That's my Near Me Widget. It will happily do its job even if the user can't read anything in it. Should I need to alter any of my Near Me options later, I can click my little box and the settings panel will appear.
If I was on Developer Edition right now, I'd add this to my CSS to make that little box vanish completely.
.widget-near-me {
   display: none;
But we all know using Developer Edition is cheating, what can we do in ArcGIS Online?
Well, we could be happy with our tiny box taking up some unimportant part of the screen, but if you really want it hidden. You can use a Sidebar Widget.
I've put my tiny Near Me Widget in the collapsable side of a Sidebar Widget. Set its size to 0px, Default state to Collapsed and turned off the Collapse Button.
Tiny Near Me will happily keep doing its job banished to an undefinably thin, unopenable Sidebar Widget and your users will never know exists (unless they inspect your page with their browser's Dev Tools).
I have found hidden custom widgets to be very useful before, but this is my first time hiding a default widget. I've had a flood of ideas during the writing of this post (including that unopenable Sidebar trick) and I think there may be some sequels to this post coming soon. What could you do with a hidden Views Navigation or Timeline Widget?
I am making my demo app publicly available, so you can decide if a Near Me-free Near Me is right for you. The big downside is that I can't find a way to make my List Widget a list of all parks in absence of a Near Me search. (I attempted using the Filter Layers To Only Show Results option within Near Me, but did not get the results I wanted.) Another potential downside is reducing the end user's Near Me options. This demo still doesn't work well enough to have been used in my original park application, but in my opinion, it is a lot closer.
22 Comments
Alan_Halter
This was incredibly helpful. Thank you! I too have found the Near Me widget doesn't behave as one might expect when compared to other applications we use almost daily like Google's simple locator search bar or any number of store finders you'd find online (especially when ordering food).
I second all the issues described. I will add
1) When an address is entered in the search bar and the Near Me widget runs its magic, you would expect the analysis results to simply display a list of nearby locations. However it strangely displays a collapsed summary. You have to click it to display locations. Just show the locations expanded please.
2) Something happens to pop-ups in the analysis results. I've never gotten pop-up details to display as expected in the Near Me widget.
Adding a List widget in place of the Near Me window is a great work around. The window kinda takes up valuable real estate and doesn't really lend itself to any intuitive design. It just hangs out there waiting to be activated or poked by a curious user. I found I had to write specific instructions for users to utilize Near Me and anytime I have to do that it's virtually unusable for non-GIS users. I've got about 5 seconds to hook my audience and prove to them my app is a beneficial wayfinder before they give up and simply Google the info they need. It's just unfortunate users have to stumble over the Near Me widget to get location info. There's so much potential with this widget.
JeffreyThompson2
@Alan_Halter The Expand Analysis Results option should take care of your first complaint.
Alan_Halter
Regarding the List widget results, is there a way to configure Near Me and Filter widgets so the user’s List results remain the same regardless the order of operations executed? For example, filtering then searching an address vs. searching then applying a filter--Near Me spits out a different number of results. The former seems to provide expected results while the latter doesn't actually filter out Near Me results. It looks to only be filtering the features on the map. Ultimately, there's a discrepancy b/w the number of features displayed in the map vs. features displayed in the List widget.
JeffreyThompson2
@Alan_Halter Using the List/Near Me configuration above, the List Widget will show the output of Near Me. If a filter is applied after running Near Me, it won't trigger an update to Near Me, so the List Widget will still be showing items that might be filtered out of the Map.
JeffreyThompson2
JaredPilbeam2
@JeffreyThompson2 Looks like some data is missing in your demo app.
JeffreyThompson2
@JaredPilbeam2 It's still working. It was re-designed in the sequel to this post to take advantage of some new options.
https://community.esri.com/t5/experience-builder-tips-and-tricks/has-arcgis-online-caught-up-to-deve...
CaseySloan
Occasional Explorer
@JeffreyThompson2 , this is a great solution! I do have one issue that you might be able to help with: I am trying to use this functionality to return info on a polygon feature in a layer that the searched address falls within. I only want the one feature's info returned in the list widget, so I was setting my search distance in the Near Me widget to 1 foot. Unfortunately, the map then automatically zooms to the extent of the near me search (i.e., a one foot radius of the searched address). I can't figure out a way to adjust this zooming. What I would really like the app to do is return info on a single polygon feature in the that the searched address falls within and have the map zoom to the extent of that feature. Any suggestions? Thanks in advance for your help!
JeffreyThompson2
@CaseySloan Check out the Zone Lookup post. It's also something of a sequel to this post. It shows how the Search Widget can be used to find polygons with Near Me.
LLyons
@JeffreyThompson2 Amazing!! Thanks so much for sharing this and so much great detail! It was exactly what I was looking to do (with different content)!
TatianaMoger
New Explorer
Hi! I'm running into an issue where the near me & list widgets are not connecting properly. Everything else is working properly, but the list widget will not populate.
JeffreyThompson2
@TatianaMoger It looks like you have the right DataSource. Did you configure the Dynamic Content in the List? https://community.esri.com/t5/experience-builder-tips-and-tricks/working-with-dynamic-content-design...
DaveL
Is there a way to turn off the boundary of the polygon used by the near-me widget? I am working on an app for a non-profit org where users will select a park boundary and it will return features which intersect with the park (eg, congressional districts, trails, etc).
To help deal with some performance issues when dealing with large parks, I simplified the park polygons in Pro to reduce the number of vertices, set the symbology to fully transparent, and use that to drive the near me widget. For the purposes of a nicer looking visual, I duplicated the base park layer and have it symbolized as I'd like it to look and layered it below the transparent version. That way, the user appears to be selecting the visible layer, but they are really selecting the simplified version and triggering the near me widget.
The near me is working well, however I cannot get the polygon to not appear. I've tried setting the search area symbol to zero width and completely transparent and it's still showing up as a thin black line, which looks pretty terrible. I feel like I'm missing something obvious, but just can't figure it out. Any suggestions on where to find this setting?
JeffreyThompson2
@DaveL I just developed a hack with two versions of my map in two Map Widgets inside a Section Widget. The result is a clickable map that still triggers Near Me, but does not make a visible output on the screen. It's a bit too complicated to explain in the comments. So I made a full post.
DaveL
@JeffreyThompson2  Interesting... I'll have to poke around with that a bit. In the meantime, I think I've realized I was overthinking this a bit. The performance issues that I was running into were only really experienced for a few polygons that were detailed, usually due to the boundary following a river or other natural feature. I ended up quickly calculating the number of vertices and then running the simplify tool on that small subset of features over a a somewhat arbitrary threshold. This deals with the problematic polygons, while leaving the smaller features alone.
vijaybadugu
How to get queryParams.where and other input fields like distance,objectIds ,etc.. from Near me output datasource ?
WilliamTarpai
Great post and wonderful discussions, Thanks to everyone in the community responding.   @EzraCheruiyot   Imagine how we have to plan our approaches working with students in the field who may or may not have dependable access to the internet, but are just starting to learn how to build their skill sets
It reminded me of the ESRI START UP page https://www.esri.com/en-us/about/partners/our-partners/startups?rsource=https%3A%2F%2Fwww.esri.com%2...
KevinHitchcock
Something to note: I had the same problem as @TatianaMoger and spent like half a day trying to figure it out. For the Near Me settings in Edit Analysis if you uncheck OBJECTID under "Configure fields to export" it will not populate the results in the List widget even thought the Near Me widget is working as expected. This is true for both Developer Edition 1.20 and ArcGIS Online.
AdrianMarsden
Honored Contributor
Brill - this original example is almost what i want - but any ideas how I can hide this warning when the page starts?
JeffreyThompson2
@AdrianMarsden In a sequel post, I used a second List Widget and a Sidebar to cover over the Near Me Output when it is empty.
KVNSCK
by Esri Contributor
Hi @JeffreyThompson2
I know this is an older forum, but I wanted to share with you that this post, and its prequel, helped me in writing an enhancement request for some of the Near Me functionality you were seeking!
Other users have requested the configuration option to remove the results drop down from Near Me, especially when they already have a list widget to display this information! This would make it as minimal as an address search box, a drop down for units, and an option to clear your results.
If you ever have an Esri Support ticket on this issue, you can ask your analyst to attach your case to the enhancement (ENH-000186352), to increase its visibility further.
Thank you again, and fingers crossed this will be considered going into the future! 🙂
DaveL
Just as a follow-up to my earlier posts, I figured I'd share the app that we produced, thanks in part to some of the tips and tricks discussed in this post.
The ExB app is The National Park Explorer and was developed in partnership with The Fund for People in Parks, facilitated through my GISCorps deployment. The goal for the app was to connect National Park visitors, advocates, and non-profits to their parks and the congressional representatives whose districts intersect these parks.
https://experience.arcgis.com/experience/53fcdfbe41614d11b8d0e23d931ab55a/page/National-Park-Explore...
Contributors
About the Author
A frequently confused rock-hound that writes ugly, but usually functional code.
