ArcGIS for SharePoint 2.1.1 Released!
555
01-27-2012 09:33 AM
by Anonymous User
Not applicable
0 0 555
We would like to notify you about the release of ArcGIS for SharePoint version 2.1.1.  This is a quick-turnaround maintenance release to fix critical bugs that were identified in the 2.1 release.  The ArcGIS for SharePoint team has worked hard to address these issues quickly to minimize their impact on our users.  The issues addressed include:
  • A license timeout that will occur on February 1, 2012.
  • The ArcGIS Location Field does not load on SharePoint subsites.
  • The ArcGIS Map Web Part does not load on Windows XP clients if data containing characters with diacritical marks (e.g. ü, ä, ñ, etc) are included in the map.
Users that are currently using version 2.0, 2.1 beta, or 2.1 final can easily upgrade to the latest version.  To do so, simply run the setup and select the upgrade option.
Note – Users that have version 2.1 installed must upgrade to version 2.1.1 to continue using the product.
You can obtain ArcGIS for SharePoint version 2.1.1 from here: ArcGIS for SharePoint 2.1.1.
Please check out the ArcGIS for SharePoint Resource Center for information on getting started, help using the product, and samples to show you how to build add-ins for the Map Web Part.  If you have questions, be sure to take advantage of the ArcGIS for SharePoint forum to get help from the community.
We’re sorry for causing any inconvenience,The ArcGIS for SharePoint Team
