After installing ArcGIS 9.3.1 SP2, there are issues opening map documents when clicking on them
599
07-21-2010 11:18 AM
by Anonymous User
Not applicable
0 0 599
esri logo
After installing Service Pack 2 for ArcGIS Desktop 9.3.1, opening a map document from Windows Explorer, ArcCatalog, Windows Desktop, Windows Recent Documents, or the Web does not open it in a new ArcMap session. That is, if you open an existing map document, ArcMap opens as expected. However, if you now open another map document, it will not start a new instance of ArcMap. Instead, the map document is sent to the existing instance.
This is a known issue. For updates on the status, you can use bug number NIM059009. Esri is working on a permanent solution to this issue. In the meantime, please use the following workaround:
  1. Run C:Program FilesCommon FilesArcGISbinArcGISFileHandler.exe.
  2. Click OK to close the ArcGIS File Handler application.
    Map documents should now open correctly.
Esri apologizes for any inconveniece this may have caused you.
- Jeff M., Desktop Development Lead - User Advocacy Group, Esri Support Services
