ArcGIS Workflow Manager Ideas
Latest Activity (38 Idea Submissions)
Sort/Filter :
Open
We would like to utilise different "reply to" addresses based on different email templates/steps within a workflow so...
DavidMcCorkindale1
by DavidMcCorkindale1 Regular Contributor
in ArcGIS Workflow Manager Ideas Last Updated 11-24-2025
1 0
Open
With the amount of flexibility that is available in creating the built-in emails in a workflow the ability to to crea...
DEWright_CA
by DEWright_CA Frequent Contributor
in ArcGIS Workflow Manager Ideas Last Updated 12-13-2024
1 0
Open
In the Define location step the Pro map_name step is a fixed value. Instead use an arcade expression. This way we can...
StefanDieters1
by StefanDieters1 Regular Contributor
in ArcGIS Workflow Manager Ideas Last Updated 12-03-2024
0 0
Open
When using Workflow Manager Server within ArcGIS Pro, if a user performs the "Define Location" step it automatically ...
GeoffShort2
by GeoffShort2 Emerging Contributor
in ArcGIS Workflow Manager Ideas Last Updated 11-26-2024
4 0
Open
We have a short workflow where all editors have the same privileges for productivity purposes.  Once a job is assigne...
Ulises
by Ulises Frequent Contributor
in ArcGIS Workflow Manager Ideas Last Updated 03-18-2024
0 4
Under Consideration
Holds in WMX should provide functionality to be release depending on time or an action.  It will be useful to have a ...
Ulises
in ArcGIS Workflow Manager Ideas Last Updated 02-06-2024
0 5
Open
When having multiple extended properties configured for a job type you should be able to control privileges for each ...
Ulises
in ArcGIS Workflow Manager Ideas Last Updated 11-07-2023
1 0
Open
Currently, in ArcGIS Enterprise 11.1, there is no direct inbuilt step to display detailed output of standard (not cus...
MarkMindlin_idea
by MarkMindlin_idea Regular Contributor
in ArcGIS Workflow Manager Ideas Last Updated 11-06-2023
0 0
Open
It would be useful from a UI perspective for those designing workflows to have the ability to group specific steps of...
Haley_Clowes
by Haley_Clowes Emerging Contributor
in ArcGIS Workflow Manager Ideas Last Updated 10-03-2023
3 3
Under Consideration
Using ArcGIS Workflow Manager Server 11.1, it is possible to create Extended Properties and define their default valu...
JohnAnderson1
by JohnAnderson1 Regular Contributor
in ArcGIS Workflow Manager Ideas Last Updated 06-28-2023
2 2
Open
I could not find where this is possible, but it would be very convenient to be able to pull job extended properties (...
bbaker_tngeo
by bbaker_tngeo Regular Contributor
in ArcGIS Workflow Manager Ideas Last Updated 02-08-2024
1 1
Open
Defining a start and end date for a step would be something really helpful.  Capability of setting a start and end da...
PabloRebufello
by PabloRebufello Occasional Contributor
in ArcGIS Workflow Manager Ideas Last Updated 11-08-2022
4 2
Open
Hi,Requirement is to open map in ArcGIS Pro.We have 20 different maps and to open maps we have to create 20 different...
sirishb
by sirishb Regular Contributor
in ArcGIS Workflow Manager Ideas Last Updated 06-27-2023
4 1
Closed
I realize this may come across as pedantry but I think names are important. According to the help, "Workflow items ar...
philippenn
by philippenn Regular Contributor
in ArcGIS Workflow Manager Ideas Last Updated 06-16-2022
0 2
Implemented
Option to duplicate existing Saved Searches will be very much helpful.
Ranga_Tolapi
by Ranga_Tolapi Frequent Contributor
in ArcGIS Workflow Manager Ideas Last Updated 02-24-2023
0 8
128 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
Top Kudoed Ideas (last 30 days)
Top Kudoed Authors
