ArcGIS Workflow Manager Blog
139
37.3K
40
| POST | I am trying to build a Widget for Experience Builder to integrate with Workflow Manager.My problem is that I can't fi... by IanTidy-ET 0 1 | 0 | 1 | 80 | |
| POST | Hi, I am trying to follow the following steps to trigger Workflow Manager flow from Survey123:Create ArcGIS Workflow ... by VerinaCristie 0 1 | 0 | 1 | 80 | |
| POST | Hi all,We have a workflow manager item deployed on our Enterprise 11.3 environment back in May and it has been runnin... by MargoHuang Occasional Contributor 0 3 | 0 | 3 | 157 | |
| POST | I am attempting to deploy workflow manager through ArcGIS Online. I am an admin in my AGOL organization. When I go to... by mshanaghan Frequent Contributor 1 6 | 1 | 6 | 562 | |
| POST | Hi,We are trying to automatically create jobs in ArcGIS Workflow Manager when a new feature is added to a hosted feat... by TürkerAtaç New Contributor 0 0 | 0 | 0 | 262 | |
| POST | Is it possible to cleanup completed jobs without manually deleting jobs? It would be nice to do a clean up and only... by ChrisBerryman Regular Contributor 0 3 | 0 | 3 | 310 | |
| POST | I am trying to create a version automatically and i have to set the same version on the map, how do to that? i tried ... by angiexx1 Emerging Contributor 0 2 | 0 | 2 | 371 | |
| POST | Hello,We have a ArcGIS enterprise with workflow manager. We did an upgrade from ArcGIS enterprise 11.1 to 11.5 last w... by DiegoLlamas 0 0 | 0 | 0 | 288 | |
| POST | Hi,I am getting the above message after installing Workflow Manager 11.3 and trying to create a workflow item.Everyth... by AdamDavis Frequent Contributor 0 0 | 0 | 0 | 463 | |
| POST | We are migrating from Workflow Manager Classic to Workflow Manager web. In Classic, there is a functionality to set s... by UmmiHamizah Emerging Contributor 0 3 | 0 | 3 | 573 | |
| POST | I have a job that notifies for new account requests and kicks off an approval process, is it possible to have a curre... by ChrisBerryman Regular Contributor 0 1 | 0 | 1 | 300 | |
| POST | We are looking at migrating from ArcGIS Workflow Manager Classic to Workflow Manager Enterprise. As these are two ver... by SachinChand Regular Contributor 0 1 | 0 | 1 | 415 | |
| POST | I am new to Workflow Manager and have reviewed a lot of the trainings and posts here, but I still need some guidance ... by MaxCushner Emerging Contributor 0 0 | 0 | 0 | 459 | |
| POST | Hi,I’m developing custom widgets for ArcGIS Experience Builder using Jimu, React, and Reactstrap (by default). My cli... by GeorgePan Occasional Contributor 0 0 | 0 | 0 | 288 | |
| POST | Using the modern Workflow Manager with Pro 3.3. Our editable layers use NAD83 and a state plane projection. Defining ... by AndreLoerch Occasional Contributor 1 1 | 1 | 1 | 422 |
