Option to duplicate existing Saved Searches will be very much helpful.
Thanks for submitting this idea! Can you give me some more information on why this would be helpful for you? If you did duplicate a saved search, what would you do with the second one?
For the duplicated saved search, I'll simply update the FILTER and re-use all the existing DISPLAY FIELDS and DISPLAY NAMES or amend them with little effort if required.
Thanks! So it sounds like you are looking for a better way to create a saved search than what exists now and the duplicate option would provide an easier starting point for that. Does that sound right?
If there were dropdowns for display fields and sort fields, would that help? Plus an easier way of creating filters?
Jonathan
Above will definitely help. However, having an additional duplicate option will make it much quicker to recreate a saved search where only filter can be different.
OK, thanks for the comments @Ranga_Tolapi. We'll keep this under consideration for the time being and will update the status as things change.
Jonathan
This has been implemented at the 11.0 release of ArcGIS Workflow Manager
