ArcGIS Workflow Manager Blog
102
20.8K
36
Under Consideration | Holds in WMX should provide functionality to be release depending on time or an action. It will be useful to have a ... by Ulises Occasional Contributor III 0 5 | 0 | 5 | |
Under Consideration | Using ArcGIS Workflow Manager Server 11.1, it is possible to create Extended Properties and define their default valu... by JohnAnderson1 New Contributor III 2 2 | 2 | 2 | |
Under Consideration | Can you please add a 'Delete job' as a step type in Workflow Manager. This seems like it should be an option but it i... by JessePearson New Contributor III 0 4 | 0 | 4 | |
Under Consideration | I would like to see a Job Board added to the Workflow Manager interfaces. Something similar in functionality to the k... by PaulBrandt New Contributor III 4 4 | 4 | 4 | |
Under Consideration | WMX provides the following LOI overlapping options as system settings:allowdisallowdisallow by job typeIn our shop we... by Ulises Occasional Contributor III 1 1 | 1 | 1 | |
Under Consideration | In WMX we have several users that are assigned to different groups. One of those groups have a job type filter defin... by Ulises Occasional Contributor III 4 2 | 4 | 2 | |
Under Consideration | Much like the Link Jobs to Map Types button on the Workflow Manager (Admin) toolbar, it would be great to have a tabu... by AllWeatherHeather Occasional Contributor 2 1 | 2 | 1 | |
Under Consideration | Currently in Workflow Manager if I define a job filter this filter applies to both creating and viewing jobs. I would... by AlisonGaiser Occasional Contributor 6 1 | 6 | 1 |
Idea Submission Guidelines
