ArcGIS QuickCapture Blog
24157
24
Open | Please add an option to watermark photos with date and/or time to photos taken using QuickCapture field applications.... by MeganEngel New Contributor III ArcGIS QuickCapture Ideas Last Updated 4 hours ago 0 0 | 0 | 0 | |
Under Consideration | QuickCapture is a great tool to use to collect rapid field intel with a single big button interface. The new Project ... by PeterVerwey New Contributor II ArcGIS QuickCapture Ideas Last Updated Tuesday 3 3 | 3 | 3 | |
Under Consideration | We need the project user input field to recognize and utilize a field domain. More, pointedly, it needs to recognize... by ToddTurner New Contributor II ArcGIS QuickCapture Ideas Last Updated Sunday 2 2 | 2 | 2 | |
Open | Real-world Problem: In search and rescue (SAR), speed is critical. In wide area search operations however, some field... by PaulDoherty2 Occasional Contributor III ArcGIS QuickCapture Ideas Last Updated Sunday 3 1 | 3 | 1 | |
Under Consideration | We have put together a concept for snow removal where we use Quick Capture to register work performed in the field. W... by ToreJensen2 New Contributor III ArcGIS QuickCapture Ideas Last Updated 12-07-2020 0 1 | 0 | 1 | |
Under Consideration | We have put together a concept for snow removal where we use QuickCapture to register work performed in the field. To... by ToreJensen2 New Contributor III ArcGIS QuickCapture Ideas Last Updated 12-11-2020 8 4 | 8 | 4 | |
Open | It should be usefull to have OCR support in Quick Capture.For example :I want to catpure all streetname signs with ph... by Anonymous User Not applicable ArcGIS QuickCapture Ideas Last Updated 10-14-2020 1 0 | 1 | 0 | |
Under Consideration | It would be nice to be able to adjust the % of the screen devoted to the map and the buttons when in landscape mode o... by MarkC1 New Contributor III ArcGIS QuickCapture Ideas Last Updated 09-21-2020 1 0 | 1 | 0 | |
Open | One of my use cases is collecting the locations of sampling points. The sampling points are all related to one main s... by MarkC1 New Contributor III ArcGIS QuickCapture Ideas Last Updated 09-21-2020 2 0 | 2 | 0 | |
In Product Plan | It would be perfect to add more than one picture when capturing an incident. by AdministrátorJihlava New Contributor III ArcGIS QuickCapture Ideas Last Updated Sunday 7 1 | 7 | 1 |
Idea Submission Guidelines
User | Count |
3 | |
2 | |
2 | |
1 | |
1 |
