Add a Search Bar to ArcGIS QuickCapture to Help Users Find Buttons in Seconds
Real-World Problem Urban Search and Rescue (US&R) teams need to document searches, survivor interactions, hazards, structure damage, worksites, and logistics rapidly and consistently. These users may have limited time to train and may join an incident without prior familiarity with the QuickCapture project configuration.…
Optional confirmation screen before stopping line capture
It would be useful to have an optional confirmation prompt when stopping an active line capture in QuickCapture. Our biosecurity team uses QuickCapture to record GPS tracks while inspecting properties, alongside buttons for rapidly capturing pest locations. Currently, a single tap on the active tracking button stops the…
Access to Field Apps With Retired Versions of ArcGIS Enterprise
When an ArcGIS Enterprise version reaches retirement, according to the product life cycle, support for authenticating using that version is removed in the next release of ArcGIS Survey123, ArcGIS Field Maps, ArcGIS Navigator and ArcGIS QuickCapture. In some cases, support removal may occur in a later release if technical,…
QuickCapture / Survey123 Mobile Needs to Support External Cameras
As great as the iPad cameras are, they are just not good enough for those conducting our inspectioin patrols from helicopter. More and more, they are clamoring to go back to using handheld digital cameras to get the resolution they are looking for. It puts our whole QuickCapture usage processes at risk, or at least…
Subtype & Contingent Value Support in QuickCapture Projects
Projects should fully support subtypes and contingent values when configuring user input. For example, if I hardcode a button to capture a specific subtype, the user input dropdown should pick the appropriate domain to populate the choice list. If this is actually supported in some capacity then the QuickCapture…
What's Next for QuickCapture? Help Shape the Next Generation Experience in Survey123 Mobile
QuickCapture projects in Survey123 Mobile Earlier this year, we announced that the current generation ArcGIS QuickCapture mobile app is being deprecated and will be retired at a future date. Importantly, this is not a deprecation of QuickCapture as a product. QuickCapture projects continue to be authored in the…
Allow option to leave camera preview open between photos when using photo location for captured record
Our crew members take a photo every few seconds while walking around a work site. They each take hundreds of photos during a single inspection. In the resulting layer, each record has one photo and is mapped at the photo's location. The fastest way to achieve this when taking so many photos is to hide the camera preview:…
Bug: opening QuickCapture from FieldMaps link - project user input does not update
Hello QuickCapture Team, I manage a project that uses Field Maps popup link to open a QuickCapture project and fill in project user inputs. Last year this was working great. This summer when we went to collect data we ran into two system bugs. First if QuickCapture is not running in the background the Field Maps link…
Licensing Issue
Good afternoon, I am trying to access Quick capture but am receiving this error. I am an admin and currently licensed for Quick capture. Any idea what is causing this? Thanks
Live occupancy count?
I have created an Occupancy Counter project with ArcGIS QuickCapture, using the Occupancy Counter template. My question: Is there some way to add a "live count" to the main data capture screen? That is, a label that would show a running total of "Ins" minus "Outs" for the current recording session. The key would be to have…
Quickcapture - Adding & refining observation point before notes
The current steps to add an observation in Quick Capture should be changed to make it easier and less time consuming. Current State - when we add an observation, we are forced to add notes about the observation before we can adjust location of the observation on the map while we are flying and sometimes we may have to…
Can I Avoid Multi-Screen Forms and Use a Single View?
Hi 😄 I have a client asking about ArcGIS QuickCapture, and I understand that its logic is to enable very fast data capture with minimal interaction, avoiding complex forms and multiple steps. However, their requirement is the following: they don’t want a form split across different screens (like going step by step).…
Wildlife observations missing data- can I access metadata somehow?
Hi, I am using QuickCapture for a project as a part of my masters. For the project I am walking a transect through a grassland and logging observations of specific bird species. I sued the "wildlife reporter (mobile view)" off AGOL as a basis and built off of it. I created custom buttons for each species and did not…
Increase Photo Limit
Good morning, I manage a QuickCapture application that I created for one of our departments. They love the app and use it on a daily basis. What they do is go to incidents out in the field, fill out a series of attributes/questions regarding the incident and then take photos of the incident. One of the biggest suggestions…
QuickCapture loading everything BUT the Attachment when Offline
We’re currently running into an issue where attachments are the only pieces not coming through to AGOL when capturing offline. I’m wondering if this might be related to spotty service when the Assessors are working in remote areas—for example, the upload may start but then get interrupted. Since the rest of the data is…
When a quick capture project is deleted in AGOL, it doesn't update on the device to be removed and the user can still submit records!
We have an old quick capture project that we don't want users to use anymore. We have unshared this quick capture project with our field worker group however because people have downloaded the project previously it is still showing up on their devices. The problem is they can also still submit records to that project, even…
Quick Capture - records not being sent automatically when online but includes arcade expression
Hi, I have a Quick Capture project that captures a point location. There is an arcade expression which populates the suburb attribute based on the intersecting suburb polygon which is also in the map. I have this arcade expression working correctly and it populates the attribute with the intersecting suburb name. However,…
Gallery of QuickCapture button images?
Hi Community. I'm currently customizing the Love for Walking and Cycling solution for a colleague and would love to be able to quickly reuse the button images that come with this template. Does anyone know if these images (possibly for all solutions) are available somewhere? It may be worth posting as an idea to have these…
Satellite Mode for Field Apps
Real-world Problem Field teams increasingly operate in environments where cellular connectivity is unavailable—such as wilderness SAR, disaster zones, offshore operations, and remote infrastructure sites. As satellite connectivity (satellite-to-cell, NTN, portable hotspots) becomes standard in field devices, there’s a…
Time filter messes with map on the app
Hi all, I´ve been failing at sorting this issue out for a few days now and I´ve run out of ideas so I thought, let me ask the experts here 🙂 So my issue is that I am using a time filter in my webmap that I am using with Quickcapture. The expressions used are: - last edited date - is after - 24/02/2026 and the other one…
Offline Data Upload
Is there a way that you are able to transfer Quick Capture files from phones to a laptop to visualise in ArcGIS Pro without the phone or the laptop being connected to the internet?
Any way to add a graphic to QuickCapture user entry page?
In our QuickCapture app to be used for surveying shorelines during an oil spill response, we have a question that asks the user to determine the percent cover of oil. It would be so helpful if we could display a graphic for this question that guides the user in choosing the appropriate answer. Currently, we do this with a…
Quick Capture error
I keep getting the Error: 'The following items are not shared with project users' I go to the button > then to the Data tab > Choose the Project User Input icon and get the message "No compatible user inputs.' However, I know there are compatible inputs but still get an error. It must be a simple fix but I have not been…
Start time Device Variable Not Working Properly
Hello! I'm working with ArcGIS QuickCapture in ArcGIS Online. I have a Date field called StartTime and it's set to record the Start Time Device Variable in the QuickCapture designer... but it isn't working. It's always recording (roughly) the same time (around 6:55PM). In the image example, all of my line features were…
User receives Error when trying to access project
Error: Can't reach portal make sure the URL is formatted correctly. The URL is formatted correctly and has been verified multiple times. One co-worker cannot access and receives the message underlined above. Another co-worker is able to access the project and add records. Any trouble shooting suggestions?
