ArcGIS QuickCapture Blog
106
309.8K
55
Open | We have an ever changing palette of content required in our emergency response QuickCapture projects. To be able to i... by Embeez New Contributor III 0 0 | 0 | 0 | |
Open | Currently, when using a hi-precision bluetooth receiver (Trimble R1/R12i and Leica GG04 Basic Plus) on Android OS 13 ... by JoelCusick1 New Contributor III 2 3 | 2 | 3 | |
Open | Real-world Problem: In Urban Search and Rescue, we often use photos to document what we are seeing in the field. Then... by pjdohertygis New Contributor III 12 1 | 12 | 1 | |
Open | Since the enhancement of using arcade within quick capture to pull the nearest feature came out, we have used it seve... by ChrisBerryman New Contributor III 0 4 | 0 | 4 | |
Open | This idea relates to the Aerial Survey App that ESRI developed for Nevada Dept of Wildlife a couple of years ago. Our... by BrendanOates New Contributor II 1 0 | 1 | 0 | |
Open | It would be invaluable for our workflows if Location proximity inputs were introduced in tandem with Location alerts.... by WillyG New Contributor III 0 0 | 0 | 0 | |
Open | Please add photo watermarking capabilities to QuickCapture, similar to those available with Survey123. I am specifica... by lah New Contributor III 5 1 | 5 | 1 | |
Open | In capturing data using a QR scanner in the quick capture app, allow 2D barcode / QR for PDF417 format to scan and ca... by PieterHuman New Contributor II 0 1 | 0 | 1 | |
Open | Allow configuration to take photo with side buttons on phone. ( volume up/down power + volume)Users have issues shif... by ashubra New Contributor III 2 0 | 2 | 0 | |
Open | Photos do not appear to be saved to devices photo library. While the photos do get submitted to the database upon sen... by ashubra New Contributor III 8 2 | 8 | 2 | |
Open | Can you please add the option to make a Project user Input read only? our workflow is launching QuickCapture from a ... by WillyG New Contributor III 0 0 | 0 | 0 | |
Open | I would like to create meaningful file names for photos taken with QuickCapture - either by using the date and time o... by BronwenHughes New Contributor III 11 4 | 11 | 4 | |
Open | We have several users collecting the location of their field workers as a lines. However, field workers sometimes fo... by Justin_Greco Occasional Contributor II 3 0 | 3 | 0 | |
Open | I use a photo GPS app to take photos which adds the date, direction, and address and I can edit and add a title to ea... by JenLangevin New Contributor III 5 2 | 5 | 2 | |
Open | I several times came across a scenario where an audio / voice note input type would have been helpful. I imagine this... by Josef_Strobl Occasional Contributor 0 1 | 0 | 1 |
Idea Submission Guidelines
User | Count |
5 | |
2 | |
1 | |
1 | |
1 |
