ArcGIS JavaScript Maps SDK Ideas
Other Boards in This Place
Latest Activity (165 Idea Submissions)
Sort/Filter :
Under Consideration
I have found discussion on this topic in couple of other threads (Permanently change the order in layer list widget ,...
fdeters
by fdeters Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 2 hours ago
0 1
Under Consideration
With the Search component, I want the option to hide the "Search in" sources dropdown menu when the component has mul...
fdeters
in ArcGIS JavaScript Maps SDK Ideas Last Updated 06-10-2026
4 3
Under Consideration
I am a developer of GIS Webcomponents, and I would like support for printing of graphics that use symbology with prim...
gqzomer
by gqzomer Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 05-05-2026
4 1
Under Consideration
The Esri attribution at the bottom of the map should allow for custom styling. It is seemingly styled in the arcgis-m...
LMFGeospatial
by LMFGeospatial Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 03-05-2026
2 1
Under Consideration
Background:With scale dependent symbology it is possible to define visible scale ranges per symbology of the same Fea...
SebastianKrings
by SebastianKrings Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 06-08-2026
6 2
6
Under Consideration
We are using the legend component from the ArcGIS SDK for JavaScript to display data organized in 3-level hierarchies...
stephengsavage
by stephengsavage Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 10-02-2025
5 3
Under Consideration
In the layer list, it would be useful to be able to reorder layers using drag and drop, Move Up, Move Down, etc., but...
SparkyT19
by SparkyT19 Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 10-01-2025
2 1
Under Consideration
Support animations of glTF objects in a viewer enhances interactivity and makes 3D models more engaging and realistic...
MartinOver
by MartinOver Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 08-28-2025
0 4
Under Consideration
Referencing Area and Distance Measurement Components - Esri Community:The current Area and Distance Measurements look...
D_Atkins
by D_Atkins Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 08-06-2025
1 1
Under Consideration
I am just hitting the limitation of labeling polygons which cannot be repeated:https://developers.arcgis.com/javascri...
NicolasGIS
by NicolasGIS Honored Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 08-12-2025
5 5
Under Consideration
We are building a web front-end to view several raster datasets, which are generally stored/served as COGs.  One of t...
BillMitchell
by BillMitchell Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 04-09-2025
0 1
Under Consideration
This is a request to add an enhancement to the Directions widget and this option to carry through to any instant app,...
CarmenDurham
by CarmenDurham Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 03-26-2025
1 1
Under Consideration
We are building an embedded map using the Sketch component and the JavaScript API.All is working fine on desktop, we ...
chitty
by chitty Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 03-20-2025
1 2
Under Consideration
The out of the box widget in Experience Builder includes the option for the person viewing the app to select a scaleb...
Deborah_Roth
by Deborah_Roth Occasional Contributor
1 1
Under Consideration
Hello,Our team has observed a potential accessibility issue with the current design of the toggle button. The toggle ...
PhucDuong
by PhucDuong Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 01-10-2025
2 2
236 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
Top Kudoed Authors
