ArcGIS JavaScript Maps SDK Ideas
Other Boards in This Place
Latest Activity (165 Idea Submissions)
Sort/Filter :
Under Consideration
I have found discussion on this topic in couple of other threads (Permanently change the order in layer list widget ,...
fdeters
by fdeters Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 10 hours ago
0 1
Open
I am a developer of GIS Web components, and I would greatly appreciate it if the logic that converts a MapView into a...
gqzomer
by gqzomer Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated Monday
5 2
Under Consideration
I am a developer of GIS Webcomponents, and I would like support for printing of graphics that use symbology with prim...
gqzomer
in ArcGIS JavaScript Maps SDK Ideas Last Updated 05-05-2026
4 1
Open
The FeatureTable widget currently uses the table from the Vaadin framework. This leads to a different user experience...
ChristianNitschkowski_AIDB
by ChristianNitschkowski_AIDB Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 11-14-2025
2 0
Open
It would be helpful if the FeatureTable widget (or web component) would provide slots to integrate custom content. At...
in ArcGIS JavaScript Maps SDK Ideas Last Updated 06-08-2026
0 1
Under Consideration
Support animations of glTF objects in a viewer enhances interactivity and makes 3D models more engaging and realistic...
MartinOver
by MartinOver Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 08-28-2025
0 4
Open
## Contour Map Visualization We tried building a contour map feature for a React/Esri JS SDK application that would d...
jacobgqc
by jacobgqc Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 08-06-2025
0 2
Under Consideration
We are building a web front-end to view several raster datasets, which are generally stored/served as COGs.  One of t...
BillMitchell
by BillMitchell Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 04-09-2025
0 1
Open
Instead of restricting vector field symbology to predesigned types, could we enable customizable color options? I am ...
kaander08
by kaander08 Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 12-11-2024
2 0
Open
Integrating ECharts makes it very easy to achieve some cool effects.The effect of integrating Cesium with ECharts is ...
gdnwr
by gdnwr Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 06-24-2024
0 0
Open
I noticed that during i3s requests, usually a node is accompanied by multiple requests such as geometries, textures, ...
海洋2021
by 海洋2021 Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 10-31-2023
0 0
Under Consideration
Remove limitation :See : https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-support-FeatureRed...
FlavieMoraux
by FlavieMoraux Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 06-06-2024
3 5
Needs Clarification
Is it possible to add 2 arrows, a first one who represent the wind direction and strength based on an array, a second...
JohnVanMeenen
by JohnVanMeenen Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 08-10-2023
0 1
Open
Hi everyone,I wanted to bring to your attention a sample example at "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arc...
ManishGohil
by ManishGohil Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 06-29-2023
0 0
Open
Enhancement featureReference Scale based scaling of Graphics in a GraphicsLayer.Enhancement categoryGraphicsLayerEnha...
SebastianFrey1
by SebastianFrey1 Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 03-16-2026
15 2
15
236 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
Top Kudoed Authors
