Maps SDK v5.2: components are transparent when building with vite.
I'm using the starter app as an example. npx @arcgis /create -n my-arcgis-app -t vite I remove the :root styles in style.css because i want to use the default css variables When I run npm run dev, the components look okay. When I run npm run build && npm run preview, the components (zoom & search) are transparent. It seems…
Enhanced feature searching with the Maps SDK for JavaScript (5.2)
We recently released ArcGIS Maps SDK for JavaScript version 5.2. This release brought some great layer-based enhancements to the arcgis-search component. This blog covers those enhancements with some background information and practical demos. Blog: Enhanced feature searching with the Maps SDK for JavaScript
@arcgis npm packages being marked as deprecated too quickly
I've been noticing that previous versions of @arcgis packages in npm have started being marked as deprecated as soon as the new version is released. Given the increasing prevalence of packages being compromised, package managers have been adding a minimum release age check to install / update. pnpm now has a 24 hour…
arcgis-print: “Done” button and page size units are not localized (5.1)
We are migrating our app from ArcGIS Maps SDK for JavaScript 4.34 (Print widget) to 5.1 (arcgis-print component). With the page locale set to Czech (cs), the arcgis-print UI is translated, but two texts in the layout template selector stay in English: * The “Done” button that closes the template selector In…
Popup network request cancels after 5 seconds
We've been experiencing 'intermittent popups' in one of our apps for too long. We honestly thought we had something misconfigured — constantly reviewing services, webmaps, and the application code itself after every little change just to throw our hands in the air. How frustrating to discover that this issue plagues:…
Using the new Esri Community
On August 24th, 2026, Esri Community migrated to a new community platform technology. It's very awesome and a little different. See the How to Use the New Esri Community article for resources that can help you get going quickly. The 15-minute recording in the post below walks through the most important things you should…
Move Clear button from arcgis-directions web component from menu
Currently, the only way to clear the route/directions from the component is to click the menu button, then Clear. It would nice to have the button more accessible as I get a lot of support questions on how to clear the route on the map.
GeoDynamics: experimental rockfall, reservoir and SWE simulations in ArcGIS SceneView
GeoDynamics 1.0.0 is an experimental open-source POC exploring how ArcGIS SceneView can be used not only as a visualization environment, but also as the spatial domain for interactive physics and hydraulic simulations. The project combines ArcGIS Maps SDK for JavaScript 5.x, SceneView terrain sampling, RenderNode/WebGL2,…
Tactical building dedication
Hello, does someone have a Tool for creating tactical building dedication for example in ArcGIS enterprise? Thanks Karsten
Feature Request: Official Agent Skill for the ArcGIS Maps SDK for JavaScript
Hello Esri team, Thank you again for the continued work on the ArcGIS Maps SDK for JavaScript. Following up on my earlier suggestion about a "Copy for LLMs" button, I'd like to propose something closely related that I believe matters even more in the current AI era: an official, first-party Agent Skill for the ArcGIS Maps…
Planned support for local LLMs and ArcGIS Enterprise
For developing custom geospatial agents, we require ArcGIS Enterprise connectivity and locally hosted LLMs, such as Qwen through Ollama, to keep data and AI processing within the organization’s infrastructure. My understanding is that these capabilities are not currently supported in the beta. Are they planned for a future…
Map not displaying graphic (React)
Hiya, I'm building a map app in React/TypeScript and I'm struggling with displaying a point on the map. I had several setbacks and errors but the code is clear of errors (for now…). However, I get an error in the console: [@arcgis/core/views/support/LayerViewManager] Failed to create layerview for layer title:'no title',…
Polygon label placement for feature layers in Map Viewer: straight, curved, and along the boundar
Feature layers in Map Viewer only place polygon labels horizontal, at the centroid. That is not enough for parcels and for public-land section grids. Please add these placement options for polygon labels on a feature layer in Map Viewer, and in the ArcGIS Maps SDK for JavaScript labeler that Map Viewer uses: * Straight…
Editor Component & .layerInfos
This is to freshen up the 'solved' question, here: Editor Component and layerInfos - Esri Community And in particular, reviewing the suggested pattern at that time, **Set layerInfos on Editor component —————- Context: The issue (from Javascript through to ExpBuilder): our Services include multiple editable layers that…
Npm app with React template, calcite panels not working
Hello, I have followed the guide here https://developers.arcgis.com/javascript/latest/get-started/#create-an-app-with-npm choosing the React template, I fix some errors on the install and launch the template, which is working as expected. When I try to add calcite components, in particular when I try to follow this guide…
Explain Arcade Cache
Can someone please explain to me what is arcade cache function in javascript sdk and how to use it? I've checked the documentation and there is no further information about it (https://developers.arcgis.com/javascript/latest/references/core/arcade/#ArcadeCache).
Support Identify on Vector Tiles in JavaScript API
As far as I know, identifying Vector Tile layers is not supported in online map viewers that use the JavaScript API. I think that any query could easily be performed on the original data source that the vector tiles are based upon
SDK version 5.1. The popup does not work with GeoJSONLayer in FireFox (Gecko)
Hello, In SDK version 5.1, popups no longer appear when clicking on features in a GeoJSONLayer containing point geometries in Firefox (Gecko) I have not yet tested other geometry types, so I don't know if the issue is specific to points or affects all GeoJSONLayer features. I also haven't tested previous SDK versions. Is…
FeatureTable improvements + based on Calcite instead Vaadin
We suggest some improvements regarding the featureTable: * base it on the calcite design system as every other webComponent instead of currently using vaadin* allowing variable / automatic height * add some more slots (e.g. for actions next to the column selection to work with every selected row) + further ones may be…
Seamless authentication for standalone JS app consuming ArcGIS Enterprise WebMap with SAML
Hello, we have a standalone non-GIS JavaScript application that consumes a WebMap from ArcGIS Enterprise to provide spatial context. Our ArcGIS Enterprise deployment uses SAML for authentication, and the standalone application is also integrated with SAML-based sign-in. At present, when users access the WebMap from the…
Select All on Map Component Feature Table
The Select Features by Rectangle sample has no way to select all in the table. Could this be added as a component option? For example, the column visibility menu allows you to.
Are you ready for some Football?
Enjoy this example of a fun Digital Twin built with data processed using ArcGIS Reality and showcased with the JavaScript Maps SDK. Check out the live app or watch the video demo The app showcases two captures from drone and handheld sensors processed as Gaussian Splat and 3D Mesh layers, georeferenced into a SceneView,…
Select All on Table
https://developers.arcgis.com/javascript/latest/sample-code/highlight-features-by-geometry/ In this sample, you make your selections one at a time in the table. Can a "Select All" be implemented in the table such as it is in AGOL?
How do I replace just the ArcGIS World Geocoding Service when using arcgis-search component?
Using the core Search widget I can use a function with searchViewModel.includeDefaultSources to replace just the default ArcGIS World Geocoding Service with another geocoding instance or remove this geocoder from the Search widgets sources. E.g. search.viewModel.includeDefaultSources = function(sourcesResponse) {…
5.0 -> 5.1: New Error
As the title says, updated the test environment to 5.0 to 5.1 (…99% because we needed the popup.effectiveHeading, a whole 'nother discussion). Now we're getting a really spammy console error, seems to be tied to the LayerList createItem or similar. The error doesn't appear to cause any issues with our app (why would it:…
