ArcGIS JavaScript Maps SDK Ideas
Other Boards in This Place
Latest Activity (165 Idea Submissions)
Sort/Filter :
Under Consideration
I have found discussion on this topic in couple of other threads (Permanently change the order in layer list widget ,...
fdeters
by fdeters Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated Wednesday
0 1
Open
Pretty simple idea. Allow the JS SDK be able to take advantage of network topology.It was to my utter surprise that I...
COSPNWGuy
by COSPNWGuy Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 3 weeks ago
8 6
8
6
Open
When drawing a shape using the sketch component, the lines are labelled with their length. However, once the shape ha...
EricNagel
by EricNagel Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 07-14-2026
2 1
Under Consideration
With the Search component, I want the option to hide the "Search in" sources dropdown menu when the component has mul...
fdeters
in ArcGIS JavaScript Maps SDK Ideas Last Updated 06-10-2026
4 3
Open
Hello Esri team,First of all, thank you for the great work on the ArcGIS Maps SDK for JavaScript. I use it a lot and ...
DaoYu
by DaoYu Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 06-05-2026
2 1
Open
We would like the out-of-the-box Sketch component in the ArcGIS JS API to have to ability to draw and edit polylines,...
GILBERTNG1
by GILBERTNG1 Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 05-20-2026
4 0
Open
When changing a subtype, for example the type of an object, ArcGIS Pro and the JavaScript SDK Editor widget request c...
FabianHannich
by FabianHannich Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 05-13-2026
1 0
Open
This is a request to enhance the Directions widget to display all direction segments and network auxiliary properties...
DanaeeFelix1
by DanaeeFelix1 Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 05-11-2026
0 0
Open
Description:We use a feature service in our ArcGIS Enterprise Portal where a layer contains more than 100 subtypes. I...
FabianHannich
in ArcGIS JavaScript Maps SDK Ideas Last Updated 06-18-2026
4 1
Open
I am a developer of GIS Web components, and I would greatly appreciate it if the logic that converts a MapView into a...
gqzomer
by gqzomer Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated a week ago
5 2
Under Consideration
I am a developer of GIS Webcomponents, and I would like support for printing of graphics that use symbology with prim...
gqzomer
in ArcGIS JavaScript Maps SDK Ideas Last Updated 05-05-2026
4 1
Open
It seems to me that it would be useful if `parseWhereClause` from `@ArcGIS/core/core/sql.js` returned the actual pars...
DanRussell
by DanRussell Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 03-30-2026
1 0
Under Consideration
The Esri attribution at the bottom of the map should allow for custom styling. It is seemingly styled in the arcgis-m...
LMFGeospatial
by LMFGeospatial Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 03-05-2026
2 1
Open
Hi Esri!I made a post in the sdk questions section and made a official ESRI support ticket with this question:https:/...
michaelpoa
by michaelpoa Regular Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 03-02-2026
0 0
Already Offered
Currently it is difficult to generate a custom implementation of a legend for a map layer without relying directly on...
JonathanDawe_BAS
by JonathanDawe_BAS Frequent Contributor
0 4
236 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
Suggest an idea
Top Kudoed Ideas (last 30 days)
Top Kudoed Authors
